查看: 1989|回复: 0
[求助与讨论] 如何打开exp文件
发表于 2008-10-1 11:30:13 |Error| 显示全部楼层 |阅读模式
如何打开exp文件
A .exp file is usually a CATIA "Export" file.
  Close CATIA and double-click on the "CatUtil"
icon. Select CATIMP and then fill in the blanks.
1. IMPORT
2. MODEL
3. Path and name of file (if it's in your home directory
   then you only need name -- case sensitive)
4. ALL
5. ALL
6. Not used with ALL
7. Not used with ALL
8. Select desired directory
9. These two items are the names of lookup tables.
    Type in VENDPRJ and VENDFIC, or something that
    is not cryptic, as they are re-usable, but only for
    a specific site that sends you files. If BMW seds you files,
    then name them BMWPRJ and BMWFIC. If Chrysler sends
    you files, then name them CHRYPRJ and CHRYFIC. 8 character
    limit.
10. Set both to NO (must be admin to use yes - not advised)
11. Set both to NO (must be admin to use yes - not advised)
12. Set to NO.
13. Set to NO - Normally. Use YES wisely.
14. Click on EXECUTE button.
15. If all goes well, then close panels, open CATIA, and open model.
An other way is to include some code in the shortcut icon that opens CatiaV5.
Normal:
"D:\Program Files\Dassault Systemes\B07\intel_a\code\bin\CNEXT.exe" -env CATIA.V5R7.B07 -direnv "C:\WINNT\Profiles\All Users\Application Data\DassaultSystemes\CATEnv"
Include:
-batch -e ExtractModelFromSequential
New:
"D:\Program Files\Dassault Systemes\B07\intel_a\code\bin\CNEXT.exe" -batch -e ExtractModelFromSequential -env CATIA.V5R7.B07 -direnv "C:\WINNT\Profiles\All Users\Application Data\DassaultSystemes\CATEnv"
GMT+8, 2026-11-4 06:13 , Processed in 0.219163 second(s), 23 queries .
