查看: 2284|回复: 2
[求助] 如何创建这样的标注样式,嵌套式的?
发表于 2007-10-20 11:19:56 |Error| 显示全部楼层 |阅读模式
这样的标注样式具体创建步骤是?
发表于 2007-10-27 10:18:33 |Error| 显示全部楼层
;★创建标注样式
          (if (not (tblsearch "dimstyle" "STANDARD"))   ;创建主标注
        (command "dimstyle" "S" "STANDARD")
          (if (not (tblsearch "dimstyle" "STANDARD$0")) ;创建线性标注
            (command "dimstyle" "S" "STANDARD$0")
          (if (not (tblsearch "dimstyle" "STANDARD$2")) ;创建角度标注
            (progn
            (setvar "DIMTIH" 1)
            (setvar "dimtad" 2)
            (command "dimstyle" "s" "STANDARD$2")
            (setvar "DIMTIH" 0)
            (setvar "dimtad" 1)
          (if (not (tblsearch "dimstyle" "STANDARD$3")) ;创建直径标注
            (progn
            (setvar "dimupt" 1)
            (setvar "DIMTOH" 1)
            (command "dimstyle" "S" "STANDARD$3")
            (setvar "dimupt" 0)
            (setvar "DIMTOH" 0)
          (if (not (tblsearch "dimstyle" "STANDARD$4")) ;创建半径标注
            (progn
            (setvar "dimupt" 1)
            (setvar "DIMTOH" 1)
            (command "dimstyle" "S" "STANDARD$4")
            (setvar "dimupt" 0)
            (setvar "DIMTOH" 0)
发表于 2007-10-27 14:02:10 |Error| 显示全部楼层
看不懂
GMT+8, 2026-11-4 04:01 , Processed in 0.291783 second(s), 32 queries .
