查看: 630|回复: 1
分享: AUTODESK INVENTOR PRO 2013 注册机
发表于 2012-4-2 08:33:27 |Error| 显示全部楼层 |阅读模式
1.Install Autodesk Inventor Pro 2013
2.Use as Serial 666-69696969, 667-98989898, 400-45454545 066-66666666 ..
  or anything matching those templates
3.Use as Product Key 797E1
  If you ant to install Inventor Std use Key 208E1
4.Finish the installation & restart Autodesk Product
5.Before clicking on Activate
  You have 2 options :
   - a) Disable Your network Card, pull the network cable out or block with firewall
     (this is just to disable online serial check)
OR
   - b) Click on Activate and it will tell you that your serial is wrong, simply click
     on close and click on activate again.
Choose option a or b.
6. Select I have an activation code from Autodesk
7.Once at the activation screen:
  start XFORCE Keygen 32bits version or 64bits version
8.Click on Mem Patch (you should see successfully patched)
9.Copy the request code into the keygen and press generate
10.Now copy the activation code back to the activation screen and click Next
  You have a fully registered autodesk product
NB: Make sure you are running the Keygen as administrator and with UAC off on Windows7
    And use the keygen for the right Product
注册机(Win32 and Win64):
Invento_Pro_2013_Crack.part1.rar
1.8 MB, 下载次数: 123
Invento_Pro_2013_Crack.part2.rar
1.01 MB, 下载次数: 100
发表于 2012-8-18 09:45:08 |Error| 显示全部楼层
怎么用不了呀!提示出错
GMT+8, 2026-11-9 22:22 , Processed in 0.257480 second(s), 31 queries .
