- 87
- 30
- 2008-3-15
Tall Emu (www.TallEmu.com)是澳大利亚软件开发商,其产品Online Armor是一个提供防御最新网络威胁的综合保护解决方案,Online Armor防御所有类型的恶意代码、基于网络“驱动”下载、间谍程序和网络钓鱼的攻击.最新的V2版,还提供完全的内核保护和强大的网络防火墙.免费版去掉了WebShield、MailShield、Keyloggers,和防火墙的高级设置(不能在规则里设置IP地址),但是保留了Program Guard,在HIPS和Leaktests上和收费版本一样.Online Armor在最近的Leaktests有极佳的表现,收费版获得第一名好成绩,足可见这款防火墙的实力.
It should fix up the following couple of issues:
1) Hosts bug (location, missing hosts file can cause error)
2) Bugfix: Sometimes wrong process identification
3) An Access violation in OAUI
4) Possible OAdriver BSODs are fixed
5) "SmartSeek" in grids activated
6) Allow default browser to be untrusted
7) Improved data restore (all valid data should be restored)
8) Desktop Switch (ScreenSaver) - fixed
9) Fix bug with lower services priority in case HIPS is disabled
10) Installer and all the modules are digitally signed
11) Fixes the excessive handle consumption noted by some people,
12) Additional self-protection features.
13) Taskbar "Close" button now just hides UI to tray
14) Exception message : Control 'PnlEditor' has no parent window. - fixed
15) Find dialog wording fixed
16) Several potential leak methods are catered for
17) "Trusted app wants to run" bug - fixed
18) ScRegSetValueExW access denied - fixed
19) When deleting a rule program is silently allowed to run (or blocked) with no chance to correct it - now rule will be re-created if needed.
We don't disclose the actual leaks method because many firewalls do not catch them.
官方主页:http://www.online-armor.com/
下载地址:Online Armor Personal Firewall
http://dl1.online-armor.com/downloads/OnlineArmor_Setup_Trial.exe Online Armor Personal Firewall AV+
http://dl1.online-armor.com/down ... p_AV-Plus_Trial.exe
Online Armor Personal Firewall (Free edition)
http://dl1.online-armor.com/downloads/OnlineArmor_Setup_Free.exe |
