查看: 975|回复: 0
瘫 船 试 验
发表于 2009-3-27 17:32:16 |Error| 显示全部楼层 |阅读模式
一.
试验前准备
Preparing before test.
1.任一主空气瓶内压力为0。应急空气瓶内压力为0。主机起动空气管内压力为0。
Any a main air bottle pressure is 0 MPa. Emergency air bottle pressure is also 0 MPa as well as starting art pipe of M/G.
2.应急空压机,主空压机(3台)控制放在自动。
Emergency air compressor and main air compressor (3) is in the Auto-position for controlling.
二.
瘫船试验
           Test for dead ship.
机旁启动应急发电机组,同时开始按秒表计时,启动应急空压机,使应急
空压机向应急空气瓶充气。当达到主发电机起动压力后立即就地手动启动一台主发电机组,向主空气瓶充气,当主空气瓶压力达到主机启动压力后,集控室起动主机,主机开出后,按停秒表,秒表读数须不超过30分钟。
Starting emergency generator panel, meantime, to start recording time by watch. In this way, emergency bottle has been pumped by emergency air compressor, when reaching start pressure for M/G, the moment to operate a M/G panel by hand in order to pump to main air bottle , when pressure of main air bottle reaching to the starting pressure of M/G, then, to start M/G in ECR, the moment to stop watch, the time is limited to 30 minutes.
GMT+8, 2026-11-4 05:31 , Processed in 0.216786 second(s), 23 queries .
