查看: 1294|回复: 0
[图片] The spraying equipment for exterior ornaments of vehicle
发表于 2008-8-14 15:25:20 |Error| 显示全部楼层 |阅读模式
Rapid contact between flame and work piece interface can selectively oxidize surface molecular of plastic work piece and improve wet ability and stick ability of surface so as to increase the adhesion of work piece coating by enhancing surface roughness and polarity of work piece surface.
The manual or robot spraying equipment for exterior ornaments of vehicle, with ground chain or anti-surface chain plus trolley system in transmission and special water spraying room is applicable to spraying top-grade bumpers and skirt of different specifications.
GMT+8, 2026-10-30 04:02 , Processed in 0.315944 second(s), 31 queries .
