查看: 1147|回复: 5
[文章] Shenzhen Wandaer Industrial Equipment Co.,Ltd.
发表于 2008-8-14 15:15:24 |Error| 显示全部楼层 |阅读模式
WANDA’ER Industrial Equipment Co., Ltd. was founded in 1963 in Taipei. It has a long history in manufacturing industrial automatic equipment. Since 1987, WANDA’ER has become professional in coating engineering, purification engineering, and logistic engineering.
As a large enterprise of integrating research, design, development, production and after-sale service, WANDA’ER owns complete technical proposal, design talents and technique strength in manufacture. We can provide you with such contracting services as analysis, planning, design, manufacture, installation, electro-control, operation, test and training of systems engineering in more than ten superior products.
Our philosophy is “Customers first.” Our objective is to try our best to satisfy customers. We have constituted a set of virtue circling system according to customers’ satisfaction, which ensures that every customer can get attention and reply. Through many processes from preliminary planning to fine design, professional management, social affairs, maintenance service, and relationship with customers, we have won customers by quality products and perfect after-sale service.
We can provide you with technology support and consultation without any fees. Your consultation on phone or visit to us is both welcome. Please feel free to contact us.
 楼主| 发表于 2008-8-14 15:16:33 |Error| 显示全部楼层
深圳万达尔工业设备有限公司
深圳万达尔工业设备有限公司于1963年在中国台北成立,在制造工业自动化设备方面已有较长的历史。1987年,迈达尔专业承揽涂装工程、净化工程、物流工程。
作为一家集研究、设计、开发、生产、服务为一体的大型企业,万达尔工业设备有限公司拥有齐全的技术方案,设计专才,拥有营造各方面技术工程的实力。我们可以为您提供整体性的承揽业务:系统工程分析、规划、设计、制造、安装、电控、施工、测试、教育培训及售后服务。
企业宗旨:客户是公司的一切,达到客户的满意是我们的宗旨,我们根据客户满意调查,建立了一整套良性循环体系使每一位客户都能得到回复。经过初步规划到细致设计、专业化管理、交际、维护服务、客户关系,我们以优质的产品,完善的售后服务系统赢得了客户的满意。
我们可以为您免费提供技术支持和咨询。诚挚欢迎您的致电及来访。
 楼主| 发表于 2008-8-14 15:19:28 |Error| 显示全部楼层
The spraying equipment for exterior ornaments of vehicle
Rapid contact between flame and work piece interface can selectively oxidize surface molecular of plastic work piece and improve wet ability and stick ability of surface so as to increase the adhesion of work piece coating by enhancing surface roughness and polarity of work piece surface.
The manual or robot spraying equipment for exterior ornaments of vehicle, with ground chain or anti-surface chain plus trolley system in transmission and special water spraying room is applicable to spraying top-grade bumpers and skirt of different specifications.
 楼主| 发表于 2008-8-14 15:55:40 |Error| 显示全部楼层
DISK Spraying
DISK Spraying
“Ω” spray room plus rotary spraying is a kind of spraying method high in efficiency, wide in scope of application and low in cost. The workpieces can be transmitted around the rotary cup along “Ω” tracks through aerial line. The rotary cup can work up and down according to the actual demand of workpiece.
The large workpiece can be coated in the form of aerial transmission, which is a general but practical method. With experience of many years in manufacture of transmission equipment, we can be in our element in such a field.
 楼主| 发表于 2008-8-14 16:05:32 |Error| 显示全部楼层
Curing Room
Curing Room:
   The temperature is decided by your company’s production requirement because of different function of each kind of surface coating of work piece and different sizes of cabinet. Generally speaking, the curing for  metal plastic spraying is within at 150℃-250℃, plastic and wooden furniture is within at 50-100℃. It is normally use CSR rock wool to be the insulating layer for the metal curing. If the metal curing is over 250℃, it will be needed to add the aluminum silicate wool with favorable heat-preservation. The plastic and wooden furniture generally use low-density CSR wool. The surface and bile is produced with SS41 cold board and SGP galvanized board. The interior bile is also made of various model stainless steel with perfect structure, excellent heat preservation, wide application, especially for coating. We will design a full set of equipment according to your requirement for coating.
发表于 2008-8-17 15:29:43 |Error| 显示全部楼层
严重抗议在论坛上打广告,版主请删除这种帖子
GMT+8, 2026-10-30 03:10 , Processed in 0.217080 second(s), 22 queries .
