- 112
- 30
- 2008-1-16
发表于 2010-12-4 13:03:26
|Error|
显示全部楼层
孔口与排气量对照表
在 14.7psia(1 kg/cm^2 a) 与 70 ℉ ( 21℃ ) 之大气压下每分钟自由空气之 M^3
孔口前表压力 孔 口 直 径 (mm)
0.397 0.794 1.588 3.175 6.35 9.525 12.7 15.875 19.05 22.225 25.4
kg/cm^2 psi 排气每分钟之自由空气 l/min 排气每分钟 M3 之自由空气 m3/min
0.068 1 0.793 3.172 12.744 50.976 0.203 0.459 0.813 1.274 1.832 2.495 3.257
0.136 2 1.133 4.475 17.927 71.65 0.286 0.646 1.147 1.793 2.583 3.512 4.588
0.211 3 1.36 5.494 21.948 87.792 0.351 0.787 1.402 2.195 3.144 4.305 5.607
0.272 4 1.586 6.315 25.261 100.819 0.405 0.909 1.614 2.526 3.625 4.956 6.46
0.34 5 1.756 7.023 26.423 112.43 0.45 1.011 1.798 2.812 4.05 5.522 7.193
0.408 6 1.926 7.703 30.867 122.909 0.493 1.107 1.968 3.087 4.418 6.032 7.873
0.476 7 2.067 8.298 33.134 132.538 0.53 1.195 2.124 3.313 4.758 6.514 8.496
0.612 9 2.351 9.374 37.382 150.096 0.598 1.351 2.399 3.738 5.409 7.363 9.6
0.816 12 2.69 10.733 43.046 171.902 0.688 1.546 2.749 4.305 6.174 8.411 10.988
1.02 15 2.974 11.894 47.578 190.31 0.762 1.713 3.059 4.758 6.853 9.317 12.988
1.36 20 3.483 13.905 55.507 222.595 0.889 2.002 3.568 5.551 8.015 10.93 14.245
1.701 25 3.965 15.916 63.72 254.314 1.017 2.291 4.078 6.372 9.147 12.461 16.284
2.041 30 4.475 17.927 71.65 286.032 1.147 2.58 4.588 7.165 10.337 14.047 18.351
2.381 35 4.984 19.909 79.579 320.016 1.274 2.86 5.098 7.958 11.47 15.604 20.39
2.721 40 5.494 21.92 87.792 351.168 1.405 3.172 5.607 8.78 12.631 17.19 22.458
3.061 45 5.975 23.93 95.722 382.32 1.532 3.455 6.117 9.572 13.792 18.748 24.497
3.401 50 6.485 25.941 103.65 416.304 1.66 3.738 6.655 10.365 14.953 20.334 26.564
4.082 60 7.476 30.019 119.794 478.608 1.914 4.305 7.675 11.979 17.247 23.449 30.642
4.762 70 8.496 33.984 135.653 543.744 2.172 4.899 8.694 13.565 19.541 26.592 34.749
5.442 80 9.487 37.949 151.795 606.048 2.427 5.466 9.714 15.18 21.835 29.736 38.827
6.122 90 10.478 41.914 167.654 671.184 2.685 6.032 10.733 16.765 24.16 32.8 42.933
6.803 100 11.498 45.878 183.797 736.32 2.945 6.627 11.753 18.38 26.451 36.023 47.04
7.483 110 12.489 49.843 199.656 798.624 3.2 7.193 12.801 19.966 28.773 39.167 51.146
8.163 120 13.48 54.091 215.798 863.76 3.455 7.76 13.82 21.58 31.067 42.31 55.252
8.503 125 13.99 56.074 223.728 894.912 3.568 8.043 14.3 22.373 32.228 43.868 57.291
• 根据百分之百之流量系数,设若进口极圆时,则以 0.97 乘以值,设若为一锐缘孔口时,则乘数用 0.65
• 此表仅能产生近似之结果,若欲作精确之测量,则请见 ASME 动力试验规格流动容积速度之测量。
• 1 至 15psig 压力值之计算,系使用标准绝热公式。
超过 15psig 压力值之计算,系使用此近似之公式 : w= 0.5303a cp/ √ T 。
其中 w= 每秒排出之磅数, a= 孔口面积,平方吋, c = 流量系数, p = 上流总压力, psia , T = 上流温度 , F 绝对。
上述情况值之计算系 c =1.0 , p = 表压 +14.7psia , T = 530F 绝对。
重量数改为容量时,则使用每立呎 0.0749 磅 密度因素,此系用于 14.7psia 则 此 70F 干空气之修正。
此公式不能用于 p 少于两倍大气压。 |
