查看: 1639|回复: 6
[求助] 带式输送机技术要求的翻译!
发表于 2008-7-21 20:40:47 |Error| 显示全部楼层 |阅读模式
由于我不是高这行的,翻译出来怪怪的,请高手给一个合适的翻译!谢谢!
CV-506B
DRYER FEED BELT CONVEYOR
1.materail: calcined petroleum coke.
2.flow rate: 3MTPH.( Metric Ton Per Hour缩写:MPTH)
3.bulk density:520kg/cu-m.
4.distance:3710mm.
5. belt speed:0.508m/sec.
6.belt onveyor,450mm wide x 3710mm long pulley c/c to convey 45#/cu.ft.calcined petroleum coke at a rate of 3mpth using 0.508m/sec belt speed.angle of incline o degree.
Head section : to include 400mm dia.lagged pulley,50mm dia.shaft ,ball bearings ,motor mount,assembled on channel frame to bolt to intermediate section of conveyor.
Tail section : to include 400 dia.winged tall pulley ,50mm dia.shaft ,ball bearings,300mm screw take-up all assembled on formed channel frame to bolt to intermediate section of conveyor.
Conveyor frame :150mm formed channel frame ,5mm thick steel with heavy pipe dividers.
Troughing idler: 20 degrees 100mm dia.rolls,ball bearings,spaced on 900mm centers with two idlers mounted at impact roller bearings spaced on 3m centers,idlers greaseable from either side.
Power requirements :0.75kw.
Belt specifications: cema grade 1
Type 2 ply
N/MM 25
Top cover thickness 3mm
Material polyester/hytrel or eq.
7.drive:class Ⅱ torque-arm reducer.v-belt drive and enclosed grard.
8.instrumentation:
Emergency pull cord switch .(2 sides)
Manual control – emergency shutdown sequence.
Zero speed .
Positive indication required sequential start-up.
On-delay required for speed activation.
 楼主| 发表于 2008-7-23 21:01:17 |Error| 显示全部楼层
怎么就没好心人给帮忙一下呢!急求啊!
发表于 2009-6-15 10:04:41 |Error| 显示全部楼层
不会啊
不是没好心人,只是不会啊
发表于 2009-6-15 17:07:15 |Error| 显示全部楼层
基本上很难
发表于 2010-6-9 12:02:58 |Error| 显示全部楼层
真的很难啊!
发表于 2010-6-9 12:11:04 |Error| 显示全部楼层
忘完了,在拾起来翻译最少等个把年
发表于 2010-6-9 14:28:39 |Error| 显示全部楼层
我们公司的翻译,也是翻译出来怪怪的,我都习惯了
GMT+8, 2026-11-4 06:41 , Processed in 0.214357 second(s), 23 queries .
