3.1 Woodchips - Mobile Plough The very first application for the aeroconveyor was in the woodchips industry in 1981. After 12 years, the conveyors are still running well and its total enclosure has ensured a great reduction in dust pollution in its immediate environment. The ease of installation and easy enclosure due to self-supporting structures was impressive and the saving of costs on support structures was evident to this customer. Soon afterwards, Aeroconveyors supplied two 40 m conveyors to a manufacturer stockpiling large quantities of wood chips within an enclosed area. The manufacturer required a compact system allowing for reduced head room, increased storage capacity and a clean and smooth operation. Two aeroconveyors below the roof line were suspended from the roof trusses. Both conveyors were fitted with a mobile Fig. 1: An aeroconveyor mobile plough in operation The aeroconveyor mobile plough has a low profile as the track section for the plough is secured to the standard box section. The sideskirts of the plough ensure that the material is carried free of the box section as these extend past the conveyors preventing build-up of material on the conveyor structure. The material is removed from the belt by the floating plough and discharged off either side. An even distribution of the material is achieved by a bed of rollers in the section where the belt is flattened. Longitudinal travel of the plough is obtained through its own drive motor enabling continuous stockpiling of 36 m. The ploughs run parallel to one another and are manufactured from steel to take the brunt of the wear. The actual bearing surfaces against the belt, however, are made of Vulealon, a low friction material normally used on belt cleaners. Also, a special seal beneath one plough controls the air escape for a smooth operation of the remainder of the aeroconveyor, after it has moved through the plough. Eight years later, 10 more conveyors were supplied to this wood board manufacturer which are incorporated with the existing aeroconveyors, improving and extending the running of this product. A feature of this installation is the tripper discharge running at a speed of 1 m/min which functions for the distribution of the product over a 40 m 3.2 Chemical Industries: Glassworks and Dust-Proofing Several applications have taken place in the chemical industry, amongst others, at a glass-making industry where soda-ash, feldspar and calcite are handled. (These chemicals are used in the glass-making process). The system starts with the underground hopper where bottom-opening railway trucks dump the products. A cross-feed arrangement takes the products to the main conveyor which car- ries it to 138 m high silos. Here a special cross feed shuttle arrangement transports the product to one of a number of silos. The system can carry up to 120 t/h. There is a convex curve as well (with a few rollers on the curved section only) to take the conveyor into the penthouse at the top of the silos. As a result of the good performance and iow maintenance costs that these conveyors have incurred, the manufacturer was recently prompted to place another order for 3 more conveyors and a complex shuttle conveyor arrangement. Probably the most valued asset of the aeroconveyor here is its ability for total enclosure since there are several food processing plants in this area and the products being conveyed are powdery. This protection offered by the covered conveyors, i.e. the protection of the environment from the product or, vice versa, the product from the elements, has made a profound impression on clients and has played a major role in influencing their decision in choosing the aeroconveyor as opposed to conventional or other conveyors. Environmental conditions and climate are particularly dusty and dry in the Northern part of South Africa where most of the general industry and mining is to be found and there has been a substantial increase in the demand for dust preventive measures and general increased interest in environmental friendly products (for which the aeroconveyor certainly does qualify). Aeroconveyors has also found a solution for extreme dustiness including a high-rised cover on which a dust-extractor may be superimposed positioned at a prescribed distance form the loading point. Fig. 2: An aeroconveyor significantly inclined, feeding a set of silos |
