查看: 2550|回复: 4
燃稻壳锅炉 |(转载)
发表于 2008-4-23 00:31:57 |Error| 显示全部楼层 |阅读模式
燃稻壳锅炉
登录/注册后可看大图
流化床稻壳燃烧锅炉
泰国是世界知名的稻米生产国,大型碾米厂配有带蒸汽轮机的稻壳燃烧锅炉,利用他们的副产品稻壳来发电。主要有2种系统用于燃烧稻壳。一种是Yoshimine锅炉厂设计的移动式倾斜分阶炉排,稻壳会从分阶炉排的顶部进入,燃烧时向下反转,当其挥发物全部燃尽后,稻壳成为碳带出。这种碳在日本、德国等其他国家拥有市场。 如果你不需要销售稻壳的碳渣,那么我们采取流化床燃烧方法,充分燃烧稻壳至微细的白色灰烬。
由于稻壳燃烧两个阶段的特性,即第一阶段,加料后挥发气体的提取,第二阶段是相当长一段时间的稻壳碳燃烧。如果需要完全燃烧,不可使用传统的点火方法。流化床被认为是可供范围的最佳选择。
配有空气喷雾器的移动式倒转炉条
稻壳具有非常特殊的特性,挥发物将先燃烧几秒钟,剩余的碳将经若干时间完成燃烧。因此,采用配有空气喷雾器的移动式倒转炉排,悬浮燃烧挥发物,剩余的碳将继续下落至移动式炉排上以完成燃烧。
[ 本帖最后由 qimingxing 于 2008-4-23 00:33 编辑 ]
 楼主| 发表于 2008-4-23 00:32:25 |Error| 显示全部楼层
(转载)
RICE HUSK FIRED REVERSE CHAIN GRATE BOILER 35 TON/H 39 KG/CM2 450 °C
TURBINE GENERATOR 6 MW 100% CONDENSING TURBINE
登录/注册后可看大图
6MW RICE HUSK POWER PLANT with 35 TON/H BOILER(Model UG series)
登录/注册后可看大图
6MW RICE HUSK POWER PLANT installed at THE ROYAL LOTUS RICE MILL located at Roi Et provice of Thailand which commenced operation in March, 2004
登录/注册后可看大图
Rice hust comsumption of this power plant of 6MW is 7.5 ton of husk per hour or 180 tons per day.
登录/注册后可看大图
From total of 6 MW, This rice mill uses 3 MW for own use and see to the national grid remaining 3 MW at Bhat 1.7/kw (US$0.0425). 3MW will make them US$127.50 per every hour, US$3,060- a day or US$91,800- a month.
登录/注册后可看大图
Electrostatic Precipitator is used to capture flying particle after the boiler
登录/注册后可看大图
From left to right, Mr. Boontham of Hi-Beam Energy, Mr. Kazuhiro Hamada-chairman of Hamada Boiler, Mr. Sommai Somsap=owner of the power plant, Mr. Lokin-from Hamada Boiler factory in China, and Mr. Itivatt of Hi-Beam Energy.
登录/注册后可看大图
This type of modified truck is being used to haul rice husk from the rice mill to the husk users. It can carry 16-17 tons of rice husk at a time.
登录/注册后可看大图
Rice Husk is completely burnt with this reverse chain grate method. Rice husk contains; C=34.42% H=4.25% O=30.41% N=0.22% S=0.54% Ash==20.16% Water=10% Low calorific Value=3,031 Kcal/Kg
登录/注册后可看大图
View from the peeping hole at the side of the chain grate. Rice Husk is burnt in suspension above the chain grate when sprayed by the pheumatic spreader by its high volatile matter and fall onto the other end of the chain grate which is moving from the rear to the front (reverse). Final ash is drop at the front ash pit.
登录/注册后可看大图
Pneumatic spreader of the rice husk 3 meter above the reverse chain grate
登录/注册后可看大图
SCADA Automatic Control system with monitor
 楼主| 发表于 2008-4-23 00:54:30 |Error| 显示全部楼层
稻壳固形燃料
稻壳固形燃料用松散的稻谷壳制成。稻壳固形燃料是一种廉价、易燃、燃烧充分、热效率高的环保型燃料。
稻壳固形燃料可用于家庭、中小型企业作燃料,特别适宜用作锅炉燃料(对锅炉结构无特殊要求)。用稻壳固形燃料代替烟煤烧锅炉,易点火、易燃、升压快、停火容易。用稻壳固形燃料代替烟煤烧锅炉,每产千克蒸汽节约烟煤约0.33 公斤。
稻壳固形燃料具有下列特点:
1. 稻壳是再生资源,使用稻壳固形燃料有利于节约能源。
2. 使用稻壳固形燃料有利于环境保护。用稻壳固形燃料代替烟煤烧锅炉,其烟尘排放量、烟尘排放浓度、SO2排放量、SO2排放浓度均比燃烧烟煤时低得多。稻壳固形燃料的烟尘排放量是烟煤的64.29%, 烟尘排放浓度是烟煤的37.07%,SO2排放量是烟煤的6.67 %,SO2排放浓度是烟煤的8.45 %。
3. 稻壳固形燃料燃烧充分,烟煤燃烧不充分。稻壳固形燃料燃烧后的稻壳灰大大少于烟煤燃烧后的煤灰,稻壳灰约是煤灰的25%。
4. 稻壳固形燃料燃烧热效率高。同一锅炉在相同工况下测试比较,燃烧稻壳固形燃料比燃烧烟煤时的热效率提高了12.05 %,每产千克蒸汽能节约标煤0.0455 公斤。
5. 稻壳固形燃料作燃料与松散稻谷壳相比,具有耐烧(密实)、体积小(约为松散稻谷壳体积的1 / 7 )、便于运输、降低劳动强度、无粉尘飞扬等优点。
生产稻壳固形燃料的利润空间大。当生产用电为0.22元 / 度时,净利润为110元 / 吨稻壳。
发表于 2008-4-23 10:24:10 |Error| 显示全部楼层
生物质发电现在很热啊,学习一下!
发表于 2009-9-28 14:52:56 |Error| 显示全部楼层
生物质发电现在很热啊,学习一下!
GMT+8, 2026-11-4 03:23 , Processed in 0.211978 second(s), 23 queries .
