- 141
- 30
- 2007-8-26
楼主 |
发表于 2008-1-31 13:15:08
|Error|
显示全部楼层
;Semi-auto placement of D.I.P. Hatch pattern in profile. (on MHP sewers)
; AUTHOR: HENRY C. FRANCIS
; 425 N. ASHE ST.
; SOUTHERN PINES, NC 28387
; All rights reserved without prejudice.
; Copyright: 1-30-96
; Edited: 1-30-96
(defun c:diph (/ solss ss count sslen dimsc curel dipx2 whend howm)
(setq solss (ssget '((0 . "SOLID")))
ss (ssadd)
count 0
sslen (sslength solss)
dimsc (getvar"dimscale")
curel (getvar"elevation")
colr "3"
llt "-"
prod "SSWR"
modf "PATT"
);setq
(setvar"elevation"(* 1002 dimsc))
(setvar"hpang"0)
(setvar"hpname""ansi31")
(setvar"hpscale"(/ dimsc 2))
(c:svlayr)
(c:mklayr)
(if (eq sslen 1)
(progn
(setq sent (entget(ssname solss count))
plp1 (cdr(assoc 10 sent))
plp1 (list(car plp1)(cadr plp1)(* dimsc 1002))
plp2 (cdr(assoc 11 sent))
plp2 (list(car plp2)(cadr plp2)(* dimsc 1002))
plp3 (cdr(assoc 12 sent))
plp3 (list(car plp3)(cadr plp3)(* dimsc 1002))
plp4 (cdr(assoc 13 sent))
plp4 (list(car plp4)(cadr plp4)(* dimsc 1002))
);setq
(setq howm (ukword 1 "All Part" "All or Part DIP?" "All"))
(cond
((eq howm "Part")
(setq dipx (upoint 1 "" "Station of End Between Manholes" nil nil)
dipx (list(car dipx)(cadr dipx)(* dimsc 1002))
colr "2"
modf "NEWW"
);setq
(c:mklayr)
(setq whend (ukword 1 "Right Left Distance" "Right, Left or Distance" "Distance"))
);cond
(cond
((and(eq howm "Part")(eq whend "Distance"))
(setq distx (ureal 1 "" "Distance (+ right, - left)" (if distx distx nil)))
(setq dipx2 (list(+(car dipx)distx)(cadr dipx)(caddr dipx))
plp1 (inters plp1 plp2 dipx (polar dipx (/ pi 2) 1) nil)
plp2 (inters plp1 plp2 dipx2 (polar dipx2 (/ pi 2) 1) nil)
plp3 (inters plp4 plp3 dipx (polar dipx (/ pi 2) 1) nil)
plp4 (inters plp3 plp4 dipx2 (polar dipx2 (/ pi 2) 1) nil)
);setq
(command ".line" plp1 plp3 "")
(command ".line" plp2 plp4 "")
((and(eq howm "Part")(eq whend "Right"))
(setq plp1 (inters plp1 plp2 dipx (polar dipx (/ pi 2) 1) nil)
plp3 (inters plp3 plp4 dipx (polar dipx (/ pi 2) 1) nil)
);setq
((and(eq howm "Part")(eq whend "Left"))
(setq plp2 (inters plp1 plp2 dipx (polar dipx (/ pi 2) 1) nil)
plp4 (inters plp3 plp4 dipx (polar dipx (/ pi 2) 1) nil)
);setq
);cond
(setq colr "3"
modf "PATT"
);setq
(c:mklayr)
(command ".pline" plp1 plp2 plp4 plp3 "c")
(setq ss (ssadd (entlast) ss))
);progn
(while (not(eq count sslen))
);setq
count (1+ count)
);setq
);while
);if
(command ".hatch" "" "" "" "l" "")
(c:rslayr)
(command ".erase" ss "")
(setvar"elevation"curel)
(princ)
);defun |
