查看: 2053|回复: 0
[求助] 压力谱随机振动分析被删掉荷载是否正常
发表于 2008-1-24 11:43:04 |Error| 显示全部楼层 |阅读模式
压力谱随机振动分析被删掉荷载是否正常
   做一个压力谱随机振动分析时候,加完压力谱表格后,接着使用lvscale,l时ANSYS就弹出WARNING:
   "To avoid duplication when using the LVSCAL command, delete all loads unless already deleted. "
    这是不是意味着 ANSYS自动把模态分析中加的面力都删除了?
    后来在 error文件里看到很多类似的WARNING:
    " Cumulative iteration 1 may have been solved using different model or boundary condition data than currently stored.  POST1 results may be  erroneous unless you RESUME from a Jobname.DB file for this substep"
     对压力谱随机振动分析这正常么?不是不出错了?
     期待高手指点!
GMT+8, 2026-11-2 00:12 , Processed in 0.201336 second(s), 22 queries .
