以下是ansys计算用的命令流,计算的是一个三磁极系统,计算结果是两边的磁极通过的磁力线比中间磁极通过的多了很多,请问这是为什么?为什么不是均匀的?还有,我怎么样才能使中间的磁极通过的磁力线比两边的多呢?谢谢各位的指教。
/BATCH
/CWD,'D:\ANSYS\shiyan'
/NOPR
/PMETH,OFF,1
KEYW,PR_SET,1
KEYW,PR_STRUC,0
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,1
KEYW,MAGNOD,1
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,0
/GO
/COM,
/COM,Preferences for GUI filtering have been set to display:
/COM, Magnetic-Nodal !电磁场模型
/PREP7
ET,1,PLANE53 !53号单元
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,1,,1 !材料属性
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,2,,2000
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,3,,1
/REPLOT,RESIZE
RECTNG,0,0.1,0,0.02, !建模型
RECTNG,0,0.1,0.08,0.1,
RECTNG,0,0.02,0,0.1,
RECTNG,0.08,0.1,0.06,0.1,
RECTNG,0.08,0.1,0,0.03,
RECTNG,0.08,0.0825,0.03,0.045,
RECTNG,0.0875,0.0925,0.03,0.045,
RECTNG,0.0975,0.1,0.03,0.045,
RECTNG,0.08-0.0004,0.08,0.03,0.042, !线圈模型
RECTNG,0.0825,0.0825+0.0004,0.03,0.042,
RECTNG,0.0875-0.0004,0.0875,0.03,0.042,
RECTNG,0.0925,0.0925+0.0004,0.03,0.042,
RECTNG,0.0975-0.0004,0.0975,0.03,0.042,
RECTNG,0.1,0.1+0.0004,0.03,0.042,
RECTNG,-0.03,0.13,-0.03,0.13, !空气模型
/REPLOT,RESIZE
FLST,2,15,5,ORDE,2 !选择图形
FITEM,2,1
FITEM,2,-15
AOVLAP,P51X !面塔接
FLST,2,12,5,ORDE,4
FITEM,2,16
FITEM,2,-20
FITEM,2,27
FITEM,2,-33
AADD,P51X !相加操作
/DIST,1,0.924021086472,1
/REP,FAST
CM,_Y,AREA
ASEL, , , , 34
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 1, , 1, 0, !指定面单元属性
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 2, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,6,5,ORDE,2
FITEM,5,21
FITEM,5,-26
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 3, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SMRTSIZE,3 !设置智能单元划分等级
MSHKEY,0
FLST,5,8,5,ORDE,4
FITEM,5,1
FITEM,5,21
FITEM,5,-26
FITEM,5,34
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1 !自由划分网格
CMDELE,_Y !CM将几何元素分组形成组元
CMDELE,_Y1
CMDELE,_Y2
/REP,FAST
/REP,FAST
/DIST,1,1.08222638492,1
/REP,FAST
/PNUM,KP,0 !PNUM设置图形显示风格
/PNUM,LINE,0
/PNUM,AREA,0
/PNUM,VOLU,0
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0 !设置显示实体编号时,编号与颜色是否一起显示
/PNUM,MAT,1
/REPLOT !重新生成当前显示
FLST,2,4,4,ORDE,2
FITEM,2,57
FITEM,2,-60
DL,P51X, ,ASYM !边界条件
FLST,2,3,5,ORDE,3
FITEM,2,21
FITEM,2,23
FITEM,2,25
BFA,P51X,JS, , ,-360000,0 !在面上施加体载荷
FLST,2,3,5,ORDE,3
FITEM,2,22
FITEM,2,24
FITEM,2,26
BFA,P51X,JS, , ,360000,0
FINISH
/SOL
ANTYPE,0
NROPT,AUTO, ,
EQSLV,FRONT, ,0, !选择求解器
PRECISION,0
MSAVE,0
PIVCHECK,1
MAGSOLV,0,3,0.001, ,25,
FINISH
/POST1
PLF2D,27,0,10,1 !生成磁力线
SAVE |
