查看: 1815|回复: 1
生物质锅炉结焦建模
发表于 2007-10-30 11:21:44 |Error| 显示全部楼层 |阅读模式
Dinesh Gera, Fluent Inc.
M.P. Mathur and M.C. Freeman, National Energy Technology Laboratory
Courtesy of the Combustion and Environmental Research Facility at the National Energy Technology Laboratory
The Combustion and Environmental Research Facility (CERF) engineers at the National Energy Technology Laboratory (NETL, Pittsburgh, PA, U.S.A.) are working with Fluent to develop and validate comprehensive combustion sub-models for cofiring biomass in pulverized coal boilers. This fundamental research is focused on developing strategies for NOx reduction by reburning highly volatile, moist bio-fuels in pulverized coal boilers. Minimizing the unburned carbon in ash is one of the factors used to evaluate biomass fuels for utility boilers. Accurate prediction of unburned carbon in a highly fluctuating environment, like that found in utility boilers, requires the use of advanced carbon burnout kinetic models in the CFD simulations.
This study involved the development of FLUENT sub-routines for biomass combustion/cofiring using available experimental data and first-principle mathematical models that provide accurate estimations of kinetic and CFD model parameters for devolatilization and diffusion-controlled char burnout. Two sets of drying functions have been developed to include the effect of moisture present on the surface of the coal/biomass, and embedded in the char, typical of that found in low rank coals. The effect of moisture on the surface of the coal/biomass is incorporated using a droplet/vaporization model in FLUENT. The evaporation of moisture embedded in char is included via a surface reaction in a novel way that accounts for char burnout due to steam gasification. Another key concern in developing an accurate model for biomass combustion is accounting for significant asphericity in biomass char particles, which plays a key role in char burnout. To this end, an enhancement factor that accounts for the large length/ diameter aspect ratio in the burning of biomass particles has been explicitly derived for the FLUENT computations.
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
Moisture =
0%
12%
24%
36%
48%
Effect of moisture on temperature inside NETL’s Pilot Scale
Combustor (110 kW)
A number of interesting exploratory CFD simulations related to the CERF pilot scale combustor geometry and a T-fired industrial boiler have been conducted to examine the effects of biomass particle size and residence time on carbon burnout. Interestingly, despite ten times larger biomass (switchgrass) particle size relative to coal, blending biomass with coal in the boiler actually reduced the unburned carbon. This phenomenon can be attributed to the high volatile content of the switchgrass. A few additional exploratory CFD simulations were performed on the CERF combustor to examine the effect of the O2/CO2 environment on NOxemissions. From the preliminary results, a reduction of 39% in NOx (on lb/MBTU basis) was observed when compared with the combustion of coal in air.
登录/注册后可看大图
登录/注册后可看大图
Temperature contours and velocity vectors on a horizontal plane inside a full-scale T-fired industrial boiler (400MW) using the variable reactivity char modelOver the next year, it is expected that 3D CFD simulations will be conducted for at least three full-scale utility boilers to assess design and operational issues. The validated 3D CFD model, in conjunction with the engineering guidelines for allowable biomass type, particle size, and moisture, will also be related to biomass fuel handling and process economics work for various plant equipment and burner design/ injection schemes. This CFD modeling with new biomass cofiring routines will represent a new capability for commercial software and should nicely complement goals relating to the cofiring of opportunity fuels, and the longer-term need to couple and integrate 3D CFD simulations with plant-modeling software for dynamic simulations. Information from the full-scale demonstrations will also provide feedback for refinement of the CFD model and insight into design and operational issues that are important for planning future utility biomass cofiring demonstration projects
转贴工程流体网
发表于 2007-12-3 15:13:41 |Error| 显示全部楼层
好资料!希望多发些
GMT+8, 2026-11-4 08:59 , Processed in 0.223603 second(s), 23 queries .
