- 54
- 30
- 2007-10-17
我在作设计时,检查工作区图纸的要求。
1.
Dose the location of wall arrangement, light support arrangement, platform arrangement, duct arrangement, ceiling filter arrangement, plenum arrangement fit the layout, general arrangement (for each WA) or not?
壁板系统、灯架系统、平台系统、风管系统、顶部过滤系统、静压系统是否与平面布置图和每台设备的总图相配?
2.
Does the detail drawing and common file fit each system arrangement (light support, wet pan and so on)?
零件图和通用图是否与各系统图(例如灯架系统、接水盘等等)相配?
3.
Does the detail drawing follow the Spec. from customer and minutes of meeting which was approved by customer?
零件图是否满足客户或经客户认可的会议纪要的技术要求?
4.
Is the material in detail drawing available in china BOM?
零件图上的材料是否能在中国采购到?
5.
Is there any mark for PPL or import part in detail drawing? Check quantity of material list, PPL and import part list.
零件图上是否有关于PPL或进口零部件的标示?检查材料清单,PPL和进口零部件清单。
6.
Is the reference drawing mentioned and shown correctly?
参考图的表述是正确的吗?
7.
Is the color code shown on platform, light support, access stair and so on?
平台、灯架、通道楼梯等部位标示有颜色代码吗?
8.
Dose the quantity number of item in material list match the drawing?
材料表上的类别数量与图纸相符吗?
9.
Is the drawing No. in detail drawing match with drawing list?
零件图的图号与图纸清单上的图号相符吗?
10.
Are the Contract No., ID No., FGR No., Position No. completely shown on the drawing?
合同号、ID号、FGR号和位置号都完整地标示在图上了吗?
11.
Are the title, revision, scale, issue and description correct?
标题、修订号、比例、表述等是否正确?
12.
Key plan (right hand column) marked to show arrangement?
设计要点是否在部件图上做了标示?
13.
Are the general notes in place and complete?
总体要求是否给出?是否完整?
14.
Is conveyor arrow shown at match-lines?
输送机的运动方向箭头是否标示在了相应的线上?
15.
Are all item numbered? Show part insulation if required.
所有的项目都编号了吗?如有需要,须表示出零件的保温设计。
16.
Does drain pots of wet pans match pit of building drawing?
水池和接水盘与建筑图上的地坑相配吗? |
