- 633
- 70
- 2010-2-11
Private Sub Workbook_SheetSelectionChange(ByVal Sh As Object, ByVal Target As Range)
Call MsoLineRun(Sh, Target)
End Sub
'''增加一个虚箭头
Function AddMsoLine(ByVal s As String, ByVal Sh As Object) As Object
Set AddMsoLine = Sh.Shapes.AddConnector(msoConnectorStraight, 0, 0, 100, 50)
With AddMsoLine.Line
.EndArrowheadStyle = msoArrowheadOpen
.Visible = msoTrue
.DashStyle = msoLineDashDot
.ForeColor.RGB = RGB(255, 0, 0)
.Weight = 0
.Parent.AlternativeText = s
.Parent.Name = s
End With
End Function
''判断虚箭头是否存在,不存在则添加
Function MsoLineExist(ByVal s As String, ByVal Sh As Object) As Object
For Each X In Sh.Shapes
If X.Name = s And X.AlternativeText = s Then Set MsoLineExist = X: Exit For
Next
End Function
'''小平箭头Hor1,竖直箭头Ver1
Sub MsoLineRun(ByVal Sh As Object, ByVal Target As Range)
Dim obj As Object
Dim Left1&, Top1&, Column1&, Row1&
Application.ScreenUpdating = False
Application.EnableEvents = False
If Target.Rows.Count = 1 And Target.Columns.Count = 1 Then
Application.ScreenUpdating = True
With ActiveCell
Left1 = .Left
Top1 = .Top
Column1 = .Column
Row1 = .Row
End With
Set obj = MsoLineExist("Hor1", Sh)
If obj Is Nothing Then Set obj = AddMsoLine("Hor1", Sh)
With obj
.Left = Left1 + ActiveCell.Width * 0.5
.Top = Sh.Cells(1, Column1).Top
.Width = 0
.Height = Top1
End With
Set obj = MsoLineExist("Ver1", Sh)
If obj Is Nothing Then Set obj = AddMsoLine("Ver1", Sh)
With obj
.Left = Sh.Cells(Row1, 1).Left
.Top = Top1 + ActiveCell.Height * 0.25
.Width = Left1
.Height = 0
End With
End If
Application.EnableEvents = True
End Sub
'''箭头删除
Sub KillMsoLine()
For Each X In ActiveSheet.Shapes
If X.Type = msoAutoShape Then
If InStr(X.Name, "Hor") > 0 Or InStr(X.Name, "Ver") > 0 Then X.Delete
End If
Next
End Sub
