查看: 2331|回复: 3
[已解决] autocad2006安装问题
发表于 2007-10-7 10:37:06 |Error| 显示全部楼层 |阅读模式
以前这台机子也出现过这样的问题,
打开安装文件,自动检测支持的部件.然后就终止了,说检查
C:\DOCUME~1\jia\locas~1\temp\autocad2006.setup.log
以下是打开后的
[10/7/2007 10:19:06] === Installation started on C7C20E80954A4F9 by jia ===
[10/7/2007 10:19:09] [Info] Windows Installer upgrade is not required
[10/7/2007 10:19:09]   System Version = 3.1.4000.2435
[10/7/2007 10:19:09] Installation skipped: MSI Runtime 3.0
[10/7/2007 10:19:09] [Info] .NET Framework Runtime upgrade is not required
[10/7/2007 10:19:09]   System Version = 2.0.50727.42
[10/7/2007 10:19:09] Installation skipped: .NET Framework Runtime 1.1
[10/7/2007 10:19:09] Installation started: .NET Framework Runtime 1.1 Language Pack
[10/7/2007 10:19:09]   Command = "support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[10/7/2007 10:19:12] [Error: 1603] 安装时发生严重错误
[10/7/2007 10:19:12] Installation failed: .NET Framework Runtime 1.1 Language Pack
[10/7/2007 10:19:12] Installation aborted
[10/7/2007 10:21:37] === Installation ended ===
各位高手们,帮帮忙!!!谢谢了~~~
发表于 2007-10-21 07:00:17 |Error| 显示全部楼层
把注册表里的遗留垃圾清理干净,重新安装.一般都可搞定.(我也出现过这样的事)
发表于 2007-10-21 09:34:31 |Error| 显示全部楼层
是正版的还是D版的,
D版的用注册机就可以了嘛.其实2006和2004没有什么区别的
发表于 2007-10-22 11:32:06 |Error| 显示全部楼层
求激活码
P8S6 YYCN 521E PFUP W7K5
ES6X AESC的申请号
GMT+8, 2026-11-4 07:44 , Processed in 0.222582 second(s), 23 queries .
