- 115
- 30
- 2006-2-8
<h6><font face="Tahoma" size="2">看到一个国外的输送机设计软件,不知有用过的没效果如何</font></h6><h6><font face="Tahoma" size="2"><br/><b>Highlights of the new delta-T version 5 program include:</b><br/><br/><a href="http://chempute.com/gifs/helixt1.gif"><img hspace="10" src="http://chempute.com/tgifs/helixt1.jpg" align="left" vspace="10" border="0" alt=""/></a>- Automatic Selection of Belt and Tension, Power Calculations<br/>- Equipment Selection from Databases for Belts, Idlers, Pulleys & Shafts, Gearboxes, Motors, Fluid Couplings, Brakes etc.<br/>- Create a 3D model of the conveyor<br/>- Calculate Vertical Curve radii and super-elevation (banking) angles for Horizontal curves<br/>- Add any number of Conveyor Pulleys, Drives, Loading points, Trippers, Brakes etc.<br/>- Over 60 reports can be viewed, printed or exported to Word, PDF files or Excel etc.<br/><br/>Helix delta-T has been used as the design tool and proven in many hundreds of real conveyor installations in more than 25 countries around the world for than 10 years. The latest version Helix delta-T 5 brings you even more power and flexibility in your conveyor designs.<br/><br/>The program will automatically calculate the belt tensions in the system, select a suitable belt from the database, calculate the pulley and shaft sizes required, select a suitable electric motor, fluid coupling and gearbox from the databases, calculate the idler shaft deflections and bearing life and then present the full conveyor design in reports which can be viewed, printed or exported to Word for Windows®, Excel®, PDF® files and other applications.<br/><br/>Belt tensions can be viewed graphically, and the Calc section provides useful procedures for calculating discharge trajectories, vertical curve radii and other frequently performed routines. Context sensitive on screen Help will guide you through the operating procedures and provide the formulae used in the calculations.<br/><br/><a href="http://chempute.com/gifs/helixt2.gif"><img hspace="10" src="http://chempute.com/tgifs/helixt2.jpg" align="left" vspace="10" border="0" alt=""/></a>You can also create and view a 3D model of the conveyor and merge in a digital terrain model. The program also allows you to dynamically calculate vertical and Horizontal curve geometry for the conveyor.<br/><br/>In addition, delta-T provides an in-depth analysis of conveyor belt tensions under different operating conditions such as running fully loaded, running empty, starting fully loaded, starting empty, braking fully loaded, braking empty and coasting. A new sketch facility allows users to sketch the conveyor profile and enter data in tabular format.<br/><br/>Delta-T will save you time and reduce your plant capital, maintenance and operating costs!<br/><br/><br/><br/><b>New Features in delta-T version 5</b><br/><br/>- Powerful OpenGL 3D modeling of the conveyor and terrain<br/>- Completely New design report formats - over 50 reports can be generated easily, with excellent presentation of the design.<br/>- Belt Tension calculations for Running, Starting and Braking including accelerating and stopping times.<br/>- Calculation to ISO and CEMA standards with auto friction factor calculation.<br/>- Bar and 3 D line graphs of belt tensions under different loading and starting and braking conditions.<br/>- Improved Braking calculations including a Brake database and Brake Selection routines.<br/>- Improved equipment database for Belts, Idlers, Motors, Gearboxes, Fluid Couplings, Brakes etc. Copy and Paste data from Excel.<br/>- New Database system compiled directly into the program - this eliminates previous issues with the MS MDB files system.<br/>- Ability to import or copy and paste data directly from Excel spreadsheets to conveyor design or equipment databases.<br/>- New Sketching facility to quickly add pulleys, hoppers and drives to your conveyor<br/>- New scale drawing system for live feedback on Vertical curve radii - just drag an intersection point on the screen and the vertical curve is redrawn in front of you so that you can see immediately if you can fit the radius into the geometry.<br/>- New Horizontal Curve Calculation routines - belt drift and banking angle calculations, with live on-screen feedback about radii.<br/>- Completely New design report formats - over 50 reports can be generated easily, with excellent presentation of the design.<br/>- Export design reports directly to MS Word® Excel® or PDF® file formats plus others.<br/>- Improved Belt Selection routines with diagrammatic feedback on belt width vs. load area and edge distance.<br/>- Estimating and Costing schedules for all conveyor equipment from civil & electrical to conveyor components.<br/>- New comprehensive instruction and context sensitive help files<br/>- New Belt Feeder / Hopper pullout calculations.<br/>- Software Operation & Technical conveyor Design support.<p><i><b>Differences Between Versions:</b></i></p><p>- Lite version can calculate up to 200 tonnes per hour and one drive pulley. <br/>- Standard version can calculate up to 1000 tonnes per hour and one drive pulley. <br/>- Professional version can calculate unlimited tonnes per hour and drives. </p></font></h6><p><i><b>Differences Between Versions:</b></i></p><p>- Lite version can calculate up to 200 tonnes per hour and one drive pulley. <br/>- Standard version can calculate up to 1000 tonnes per hour and one drive pulley. <br/>- Professional version can calculate unlimited tonnes per hour and drives. </p> |
