查看: 2700|回复: 2
[求助] 这安装全得搞吗?还是就做第一个就够了
发表于 2007-8-21 07:46:01 |Error| 显示全部楼层 |阅读模式
Pro/ENGINEER WILDFIRE 3.0 Mxxx lic gen
1. use keygen.exe to get your Host_ID license.dat then install proe wildfire3.0 Mxxx with this nodelocked lic.NO need to install lic server.
2. put proe.patch.of.wildfire.3.0.exe into the <installed location>\\proeWildfire 3.0\i486_nt\obj directory then Run and press the PATCH button.Don't use keygen.exe's patch.it will not backup any modified file.
2. put mech.patch.of.wildfire.3.0.exe into the <intalled location>\\mechWildfire 3.0\i486_nt\bin directory then Run and press Patch Button
That's all.
1.当锁定lic安装wildfire3.0Mxxx时使用keygen.exe获得你的网卡license.dat。不需要安装lic服务。
2.放置proe.patch.of.wildfre.3.0.exe文件到 安装位置\\proeWildfire 3.0\i486_nt\obj下点PATCH键动行.不要使用keygen.exe的patch去这样做将不能备份和修正文件。
2.放置mech.patch.of.wildfire.3.0.exe文件到 安装位置\\mechWildfire 3.0\i486_nt\bin下点PATCH键动行。
发表于 2007-8-21 08:02:24 |Error| 显示全部楼层
我是新手
我被搞糊涂了,
发表于 2007-12-13 16:53:01 |Error| 显示全部楼层
什么意思???论不明白
GMT+8, 2026-11-4 04:49 , Processed in 0.215576 second(s), 22 queries .
