查看: 7254|回复: 1
AIP2008_SP1 已发布
发表于 2007-7-11 11:57:02 |Error| 显示全部楼层 |阅读模式
AIP2008_SP1 已发布下载地址:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9852114&linkID=9242019
Autodesk Inventor Professional 2008 SP1 (build #284)
July 10, 2007
            Notice to Autodesk Inventor Customers
In a continuing effort to provide high quality products, Autodesk has released Autodesk Inventor 2008 Service Pack 1, which fixes or addresses a variety of issues pertaining to Autodesk Inventor 2008. This README file highlights how to install the patch, what has been fixed, and how to download the update.
CONTENTS
- General Notes
- Installation Instructions
- Summary of issues addressed by this Service Pack
- Service Pack Download information
GENERAL NOTES
1. This patch update applies to all flavors of Autodesk Inventor 2008.
2. This patch cannot be un-installed by itself.  You need to un-install Autodesk Inventor 2008 completely.
3. This patch does not address the “End of Evaluation Period” error with the AOEMView 2008.  Please refer to the details and follow instructions provided by the links below:
    - Uninstalling a legacy AOEM Viewer from a 64-bit operating system
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=9784185&linkID=9242018
    - Hotfix - End of Evaluation Period error during DWGIN
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9741651&linkID=9242019
INSTALLATION INSTRUCTIONS
(1) Download the Autodesk Inventor 2008 Service Pack 1 patch file "Inventor2008_SP1.msp"
**You must have Administrator privileges on your local machine to install Autodesk Inventor 2008 Service Pack 1**
(2) Double-click on the downloaded file to start the install. You will also have a progress meter on your screen while the setup program is updating the files on your system.  Click Finish when done.
(3) If requested, please reboot your system after the service pack is installed.
*For final verification, from within Autodesk Inventor, select "About Autodesk Inventor" from the Help menu.  If Autodesk Inventor 2008 Service Pack 1 has been successfully installed, the About box displays: "Build: 284, Release: 2008 SP1 - Date: Fri 07/06/2007."
Summary of issues addressed in Autodesk Inventor 2008 Service Pack 1 include:
NOTE: CER stands for Crash Error Report and NG stands for News Group
AUTODESK INVENTOR PROFESSIONAL 2008 – MODULES
CABLE & HARNESS
Fixed the following issue:
- On Windows Vista, with “User Account Control (UAC)” on, if Nailboard is created once from Cable and Harness panel bar, corresponding template tab will be missing on creating Nailboard in the future.
TUBE & PIPE
Fixed the following issues:
- Close assembly after populating hose or tube and pipe segment with bends does not remove all documents from memory.
- Not all the documents are removed from memory upon closing some legacy Tube & Pipe files.
- Route not marked as comatose although show violation can list the violations as Gender or end condition errors.
STRESS ANALYSIS
- Cannot edit loads or boundary conditions defined in Inventor 11 in some cases.
AUTODESK INVENTOR 2008
API
- CER: Crash on close after using FileManager.GetDWGDocumentReferences.
- Sketch.Dependents property returns an error.
- On Windows Vista, iPartMember.Name doesn't contain file extension.
- Centermark.ModelWorkFeature and Centerline.ModelWorkFeature should return proxies where applicable.
- PartsListColumn.CustomPropertyName returns the Title string instead of property name.
ASSEMBLY MODELING
- Poor performance with Zoom all when a LOD is active on certain assemblies.
- NG: Crash on applying an assembly constraint to Z-axis in certain files.
- NG: Cannot calculate mass props on an assembly that contains assembly feature or on a weldment assembly that contains machining or preparation operations.
- In some cases the hospital behavior is incorrect.  It shows a redundant Red Cross and redundant "Missing edge" error message.
CONTENT CENTER
- All Lock Washer Dimensions Series come in as the same size.
- Library migration failure in some custom Autodesk Inventor 10 libraries.
- CER: Crash when publishing an iPart with no Member and Part Number parameters.
- CER: Crash in Content Center Favorites.
DESIGN ACCELERATOR, FRAME GENERATOR, INVENTOR STUDIO
- Bolted Connection does not update to the new position after a part is edited.
- Grip for Keyway length for a shaft is missing.
- IS Standards are missing in Frame Generator of AIP 2008.
- B_L value of a frame member does not get updated while change its size or offset.
- On Windows Vista, the tooltip of type in Insert and Change dialog flickers which makes the preview of profile disappear.
- Truncation numbers in Animation Timeline dialog box on Windows Vista.
- Error for rename in Studio Browser on 64 bit Windows Vista.
- Double-click doesn't work on studio browser on 64 bit Windows Vista.
- On Windows Vista, numbers are partially cut-off in Animation Timeline dialog.
- On Windows Vista, double-clicking doesn't take effect on the Studio browser nodes.
DRAWING MANAGER
- The balloon text justification is not always correct when exporting to DWG.
- When views created from two different exploded presentation views based on LOD are ballooned, the second exploded view launches the BOM properties dialog.
- Defer updates doesn't prevent Parts List from being updated.
- CER: Crash when adding text.
- Crash when migrating certain drawing files.
- Missing warning prompts in the drawing when assembly needs update.
- The language switch does not apply when pressing "ALT+SHIFT" if Regional Settings are changed to Hebrew.
- Annotations are lost when an Inventor DWG is opened in AutoCAD.
- CER: Crash in some cases when migrating a drawing that contains a BOM.
- CER: Crash in some cases when recovering model sketches.
- CER: Crash in some cases when creating a section view
- CER: Crash in some cases when printing drawing files.
- CER: Crash in some cases when creating dimensions.
- CER: Crash in some cases when adding dimensions to centerlines.
- CER: Crash in some cases when modifying dimension styles.
- CER: Crash in some cases when retrieving dimensions in a drawing.
- CER: Crash in some cases when migrating drawings that contain a table.
- CER: Crash in some cases when saving drawing files.
- CER: Crash in some cases when opening Inventor drawing files.
- NG: Cannot delete sheet if it was not activated in a current Inventor release
- NG: ISO View dimension help does not work
- NG: Incorrect symbol attachment to half diameter dimension
- NG: View block name is wrong when the view contains a space at the starting of the view name
- NG: Default Gap for breakout is wrong for inches or mm
- NG: Cannot open certain drawing files after migration to Inventor 2008.
- NG: Crash updating views in certain drawing files.
- NG: Opening the dwg file in AutoCAD via the "Open in AutoCAD" command causes a read-only attribute to be set on the dwg file projects in Inventor
- NG: random error opening drawing files from prior release(s).
- NG: Incorrect visibility of new components in a view when view has component hidden line visibility turned on for specific components.
- NG: Line weight not maintained while printing.
- On Windows Vista, it is not able to create projected view.
- On Windows Vista, Open in AutoCAD cannot find an installed AutoCAD version.
- On Windows Vista, bold text is illegible.
- Rebuild of thread in iFeatures, iPart, derived part or derived assembly caused hole note in drawing to disappear.
- Defer update shifts rendered drawing views.
DWG/DWF/AEC Exchange
- On Windows Vista,  MSP can only use default printer to plot.
- Crash when exporting certain drawings to DWG.
- On Windows Vista, closing Inventor after DWF publish does not terminate the process.
- On Windows Vista, Model/Layout1 tab is missing when an AutoCAD dwg file is imported.
- On Windows Vista, cannot save copy as AutoCAD Mechanical file.
- On Windows Vista, cannot translate MDT files.
GENERAL
- NG: Importing XML from Inventor 11 to Inventor 2008 generates invalid Command Aliases/Shortcuts.
- Crash on placing a component created on student version in commercial version.
- NG: certain command aliases do not persist between Inventor sessions.
- On Windows Vista, browser shading can barely be seen using LCD screen.
- Crash when multi-selecting part features in the browser followed by a double click.
- CER: Crash while closing documents.
- CER: Crash moving between windows with faces selected.
- OLE attachments in part and drawing files do not update.
- Some controls on a dialog may disappear when Alt key is pressed on Windows Vista.
- Some customized Command Aliases will be reset after closing Inventor session.
IGS/STEP/SAT
- CER: Crash on Boundary Trim command in Construction Edit environment with certain files.
- On Windows Vista, can't open translation report in Inventor browser.
PART MODELING
- CER: Crash on extending extrusion surface to work plane in a customer file.
- Pipe threads Class B crashes for certain values.
- Wrong mass properties in sheet metal part after changing material in the flat.
PRESENTATIONS
- CER: Crash when closing the Animation dialog.
TASK SCHEDULER
- Cannot Publish DWF from Task Scheduler for files that have components suppressed.
- On Windows Vista, task will not run after you re-schedule it.
KNOWN ISSUES ON WINDOWS VISTA
- Shell Extensions (e.g. Design Assistance, iProperties, Pack & Go, …) may not be shown in the Inventor file context menu after Service Pack 1 is applied. You may need to run Inventor using Admin account to correct it (Select Inventor application icon using Windows Explorer, then Right Mouse Button click, select “Run as…”).
- Style Library Manager may generate an error during initialization. You may need to reboot your system then launch stand-alone Project Editor (from Windows Start menu) and close it to correct this.
- On Windows Vista, Import image into a sketch will fail when MS Paint is not the default editor. You may have to disable “User Account Control (UAC)” to register MS Paint as your default editor.
- On Windows Vista, the layer list may not populate correctly on DWGIN Wizard DWG Preview Page. Please turn off Vista “User Account Control (UAC)” and register the file DxOemViewer.Arx in AOEMVIEW 2008 installation folder to proceed.
Notes:
Autodesk Inventor 2008 and Autodesk Inventor 2008 Service Pack 1 use the same file formats (.iam, .ipt, .idw, .ipn, .idv, .ide). All file types can be interchanged between these versions.
The size of Autodesk Inventor 2008 Service Pack 1 is approximately 30 MB. You must have a minimum of 60 MB of free disk space on the drive where your temporary files are directed for the update to complete successfully.
SERVICE PACK DOWNLOAD LOCATION
Locate the Autodesk Inventor 2008 Service Pack 1 file at:
    http://www.autodesk.com/inventor-updates
We want to thank all our customers who identified these issues and reported them to us.  These reports give us the opportunity to improve the product and provide you, our customers, with the best solution in mechanical design. Autodesk would also like to take this opportunity to thank you for your continued business and for the feedback regarding the content of this update release.
Thank you!
Respectfully,
Autodesk Inventor Product Team
发表于 2007-8-14 15:27:51 |Error| 显示全部楼层
Autodesk Inventor Professional 2008 SP1(版本号 284)
2007 年 7 月 10 日
Autodesk Inventor 客户通知
为了不断提供高质量的产品,Autodesk 发布了 Autodesk Inventor 2008 Service Pack 1,它对 Autodesk Inventor 2008 中发现的各种问题进行了修复或解决。本自述文件重点说明了如何安装修补程序、对哪些问题进行了修复以及如何下载更新。
目录
- 通用注释
- 安装说明
- 此 Service Pack 所解决的问题的摘要
- Service Pack 下载信息
通用注释
1. 此修补程序更新适用于各种版本的 Autodesk Inventor 2008。
2. 此修补程序不能单独卸载。您需要完全卸载 Autodesk Inventor 2008。
3. 此修补程序不会解决 AOEMView 2008 的“评估周期终止”错误。请参考以下链接中所提供的详细信息并遵循其中的说明:
        - 从 64 位操作系统上卸载旧的 AOEM Viewer
http://usa.autodesk.com/adsk/ser ... &linkID=9242018
        - 即时补丁程序 – 执行 DWGIN 命令期间发生“评估周期终止”错误
http://usa.autodesk.com/adsk/ser ... &linkID=9242019
安装说明
(1) 下载 Autodesk Inventor 2008 Service Pack 1 修补程序文件“Inventor2008_SP1.msp”
**您必须拥有本地计算机的管理员权限,才能安装 Autodesk Inventor 2008 Service Pack 1**
(2) 双击下载的文件开始安装。安装程序更新系统中的文件时,屏幕上还会显示一个进度条。完成安装时请单击“完成”。
(3) 如果在安装 Service Pack 后请求您重新启动系统,请执行该操作。
*要进行最终验证,请从 Autodesk Inventor 的“帮助”菜单中选择“关于 Autodesk Inventor”。如果已成功安装 Autodesk Inventor 2008 Service Pack 1,则“关于”框将显示以下信息:“版本号:284,版本:2008 SP1 - 日期:2007 年 7 月 6 日,星期五。”
Autodesk Inventor 2008 Service Pack 1 中所解决问题的摘要包括:
注意:CER 代表“崩溃错误报告”,NG 代表“新闻组”
AUTODESK INVENTOR PROFESSIONAL 2008 – 模块
三维布线
已修复以下问题:
- 在 Windows Vista 上,当“用户帐户控制 (UAC)”打开时,如果曾经从“三维布线”工具面板中创建过钉板,则在以后创建钉板时相应的模板选项卡将丢失。
三维布管
已修复以下问题:
- 填充带有折弯的软管或三维布管管段后,关闭部件不会从内存中删除所有文档。
- 关闭某些旧的三维布管文件时不会从内存中删除所有文档。
- 尽管显示不符合规格的项可以列出不符合规格的项(例如种类或端部条件错误),但并未将管线标为失效。
应力分析
已修复以下问题:
- 在某些情况下,无法编辑在 Inventor 11 中定义的载荷或边界条件。
API
已修复以下问题:
- CER:使用 FileManager.GetDWGDocumentReferences 后,关闭时发生崩溃。
- Sketch.Dependents 特性返回错误。
- 在 Windows Vista 上,iPartMember.Name 不包含文件扩展名。
- Centermark.ModelWorkFeature 和 Centerline.ModelWorkFeature 应在合适时返回代理。
- PartsListColumn.CustomPropertyName 返回标题字符串而不是特性名称。
部件造型
已修复以下问题:
- 当特定部件上有激活的详细等级时,“全部缩放”的性能不佳。
- NG:将装配约束应用到某些文件中的 Z 轴时发生崩溃。
- NG:无法计算包含部件特征的部件或在包含加工或准备操作的焊接件部件的质量特性。
- 在某些情况下,检查工具不正确的。它显示多余的“红十字”和多余的“缺少边”错误消息。
资源中心
已修复以下问题:
- 所有锁紧垫圈尺寸系列的大小都相同。
- 某些自定义 Autodesk Inventor 10 库中的库移植失败。
- CER:发布没有“成员”和“零件代号”参数的 iPart 时发生崩溃。
- CER:资源中心收藏夹中发生崩溃。
设计加速器、结构件生成器、INVENTOR STUDIO
已修复以下问题:
- 编辑零件后,螺栓联接不会更新到新位置。
- 缺少轴的键槽长度的夹点。
- AIP 2008 的结构件生成器中缺少 IS 标准。
- 在更改了结构件的大小或偏移后,其 B_L 值不会更新。
- 在 Windows Vista 上,“插入和更改”对话框中的类型的工具提示闪烁,导致截面轮廓的预览消失。
- 在 Windows Vista 上,“动画时间轴”对话框中的数字被截断。
- 在 64 位 Windows Vista 上,在 Studio 浏览器中重命名时出错。
- 在 64 位 Windows Vista 上,双击 Studio 浏览器无反应。
- 在 Windows Vista 上,“动画时间轴”对话框中的数字被部分截断。
- 在 Windows Vista 上,双击 Studio 浏览器节点无反应。
工程图管理器
已修复以下问题:
- 当输出到 DWG 时,引出序号文本对齐有时不正确。
- 为从两个不同分解表达视图基于详细等级创建的视图添加引出序号时,二级分解视图将启动“BOM 表特性”对话框。
- 延时更新不会阻止明细表更新。
- CER:添加文本时发生崩溃。
- 移植某些工程图文件时发生崩溃。
- 部件需要更新时工程图中缺少警告提示。
- 如果将“区域设置”更改为“希伯来语”,则当按“ALT+SHIFT”时语言切换无效。
- 在 AutoCAD 中打开 Inventor DWG 会丢失标注。
- CER:某些情况下移植包含 BOM 表的工程图时发生崩溃。
- CER:某些情况下恢复模型草图时发生崩溃。
- CER:某些情况下创建剖视图时发生崩溃
- CER:某些情况下打印工程图文件时发生崩溃。
- CER:某些情况下创建尺寸时发生崩溃。
- CER:某些情况下将尺寸添加到中心线时发生崩溃。
- CER:某些情况下修改尺寸样式时发生崩溃。
- CER:某些情况下在工程图中检索尺寸时发生崩溃。
- CER:某些情况下移植包含表的工程图时发生崩溃。
- CER:某些情况下保存工程图文件时发生崩溃。
- CER:某些情况下打开 Inventor 工程图文件时发生崩溃。
- NG:如果图纸未在当前 Inventor 版本中激活,则无法将其删除
- NG:等轴测视图尺寸帮助不起作用
- NG:到半径尺寸的符号附着不正确
- NG:当视图名称的开头包含空格时,该视图的视图块名称错误
- NG:局部剖视图的默认间隙对于英寸或 mm 是错误的
- NG:某些工程图文件在移植到 Inventor 2008 后无法打开。
- NG:在某些工程图文件中更新视图时发生崩溃。
- NG:通过“在 AutoCAD 中打开”命令在 AutoCAD 中打开 dwg 文件时,会为 Inventor 中的 dwg 文件项目设置只读属性
- NG:打开以前版本的工程图文件时发生随机错误。
- NG:当视图中针对特定零部件打开了零部件隐藏线可见性时,该视图中的新零部件的可见性不正确。
- NG:打印时不会保持线宽。
- 在 Windows Vista 上,无法创建投影视图。
- 在 Windows Vista 上,执行“在 AutoCAD 中打开”命令时找不到安装的 AutoCAD 版本。
- 在 Windows Vista 上,粗体文本难以辨认。
- 在 iFeature、iPart、衍生零件或衍生部件中重建螺纹导致工程图中的孔注释消失。
- 延时更新会更改渲染的工程视图。
DWG/DWF/AEC 交换
已修复以下问题:
- 在 Windows Vista 上,MSP 只能使用默认的打印机出图。
- 将某些工程图输出到 DWG 时发生崩溃。
- 在 Windows Vista 上,DWF 发布后关闭 Inventor 不会终止进程。
- 在 Windows Vista 上,输入 AutoCAD dwg 文件时,“模型/布局 1”选项卡丢失。
- 在 Windows Vista 上,无法保存副本为 AutoCAD Mechanical 文件。
- 在 Windows Vista 上,无法转换 MDT 文件。
常规
已修复以下问题:
- NG:将 XML 从 Inventor 11 输入到 Inventor 2008 将产生无效的命令别名/快捷键。
- 将学生版中创建的零部件放置在商业版中时发生崩溃。
- NG:某些命令别名在 Inventor 进程之间不会保持不变。
- 在 Windows Vista 上,使用 LCD 屏幕几乎看不到浏览器着色。
- 当在浏览器中选择多个零件特征然后双击时发生崩溃。
- CER:关闭文档时发生崩溃。
- CER:选定多个面之后在窗口间移动时发生崩溃。
- 零件和工程图文件中的 OLE 附件不会更新。
- 在 Windows Vista 上,按 Alt 键时对话框中的某些控件可能消失。
- 关闭 Inventor 进程时,一些自定义的命令别名将重置。
IGS/STEP/SAT
已修复以下问题:
- CER:在“构造编辑”环境内对某些文件执行“边界修剪”命令时发生崩溃。
- 在 Windows Vista 上,无法在 Inventor 浏览器中打开转换报告。
零件造型
已修复以下问题:
- CER:在用户文件中将拉伸曲面延伸到工作平面时发生崩溃。
- 对于某些值,管螺纹等级 B 发生崩溃。
- 在展开模式中更改材料后,钣金零件中的质量特性错误。
表达视图
已修复以下问题:
- CER:关闭“动画”对话框时发生崩溃。
任务调度器
已修复以下问题:
- 无法为那些已经抑制了零部件的文件从任务调度器发布 DWF。
- 在 Windows Vista 上,任务在重新调度后不会运行。
WINDOWS VISTA 的已知问题
- 应用了 Service Pack 1 后,外壳扩展(如设计助理、iProperty、打包…)可能不会显示在 Inventor 文件关联菜单中。您可能需要使用管理员帐户运行 Inventor 来进行修正(使用 Windows 资源管理器选择 Inventor 应用程序图标,然后单击鼠标右键,选择“运行方式…”)。
- 样式库管理器可能在初始化期间产生错误。您可能需要重新启动系统,然后启动单机项目编辑器(从 Windows“开始”菜单中启动)并将其关闭来修正此问题。
- 在 Windows Vista 上,如果 MS Paint 不是默认编辑器,则将无法将图像输入到草图中。您可能必须禁用“用户帐户控制 (UAC)”以将 MS Paint 注册为默认编辑器。
- 在 Windows Vista 上,在 DWGIN 向导 DWG 预览页面上,可能不会正确填充图层列表。请关闭 Vista“用户帐户控制 (UAC)”并在 AOEMVIEW 2008 安装文件夹中注册“DxOemViewer.Arx”文件以继续。
注意:
Autodesk Inventor 2008 和 Autodesk Inventor 2008 Service Pack 1 使用相同的文件格式(.iam、.ipt、.idw、.ipn、.idv、.ide)。所有文件类型均可以在这些版本之间交换。
Autodesk Inventor 2008 Service Pack 1 的大小约为 30 MB。在保存临时文件的驱动器上,至少需要 60 MB 的可用磁盘空间来保证成功完成更新。
SERVICE PACK 下载位置
可以在以下位置找到 Autodesk Inventor 2008 Service Pack 1 文件:
我们向所有发现这些问题并报告给我们的客户致以由衷的感谢。这些报告使我们有机会改善产品,为您提供机械设计的最佳解决方案。Autodesk 还要借此机会感谢您能继续使用我们的产品并就此更新版本的内容提供宝贵意见。
非常感谢!
顺祝商祺!
Autodesk Inventor 产品团队
GMT+8, 2026-11-4 05:22 , Processed in 0.219886 second(s), 23 queries .
