楼主: zgnyjswl
U型皮带机的应用情况
 楼主| 发表于 2012-12-19 10:36:23 |Error| 显示全部楼层
U型皮带机可以实现小半径水平转弯,普通皮带机水平转弯需要的半径很多。应该各有适合使用的地方吧。
发表于 2013-1-6 16:24:40 |Error| 显示全部楼层
北京约基工业做过不错的U型机,技术比较先进!
发表于 2013-1-7 19:39:51 |Error| 显示全部楼层
U型的和普通的比较起来也没什么
发表于 2013-4-7 18:51:37 |Error| 显示全部楼层
U型带很独特,只是还没有为大家所熟悉。
乌海安装有2台,一台长1km,B1000mm,运量900tph,水平曲线半径200m,另一台长3.5km,B1200mm,带速4m/s,运量1800t/h,水平曲线半径700m。
可以去参观下。我看过,感觉很震撼,与老外应有很强竟争力!
 楼主| 发表于 2013-4-10 14:34:09 |Error| 显示全部楼层
回复 19# 山外来客
能否介绍一些去参观的线路?能贴上些设配照片就更好了。
发表于 2013-8-19 22:23:04 |Error| 显示全部楼层
在乌海机场附近,飞机上看很清楚。
发表于 2013-8-21 08:58:57 |Error| 显示全部楼层
以下是国外公司对管状和U型带输送机的介绍。
Pipe and U-type Conveyors
Application:
Pipe and U-type conveyorsor combination of both types is suitable for ecological transportation of thebulk materials within all branches of industry. Most common transportedmaterials are cement, gypsum, ore, fertilizers, coal, wooden chips, grains andetc. The pipe conveyor design eliminates problems related to the operation ofthe classic belt conveyors as e.g. material spillage, restricted angles oftransportation, horizontal and vertical curve difficulties.
Technical parameters
The structure of pipe conveyor as well as structure ofclassic type conveyor  consists of:
Drive station
·        One drum type
·        Two drum type
·        Belt turn station for U-type conveyors
Return stations
Tension stations
·        Gravitation type with drums
·        Carriage type with gravitation weight
Conveyor line
·        Steel structure with self-supporting structure up to 24m
The pipe conveyor route can be designed with curve inhorizontal and vertical plane, which decrease number of the transfer points onconveyor route. The pipe conveyor structure design allows overcome horizontaland vertical curves with 80m or greater radius.
The pipe conveyors can achieve up to 50% highercapacity of vertically conveyed material compared to classic belt conveyors.
The conveyed material is protected against externaleffects and dusting related to conveyor operation is minimized.
The closing of the belt into pipe shape, belt turn andfolding into U shape in conveyor carrying and return run prevents materialspillage under conveyor and environment pollution. During belt closing, thebelt closes with “dirty” surface inside and it prevents sticking o material onrollers.
 楼主| 发表于 2013-8-21 10:00:42 |Error| 显示全部楼层
山外来客 发表于 2013-8-19 22:23
在乌海机场附近,飞机上看很清楚。
谢谢啦。知道这家使用单位叫什么名字吗?
 楼主| 发表于 2013-8-21 10:10:03 |Error| 显示全部楼层
long650101 发表于 2013-8-21 08:58
以下是国外公司对管状和U型带输送机的介绍。Pipe and U-type ConveyorsApplication:[/backcolo ...
谢谢龚总提供的资料。
发表于 2013-8-26 13:08:00 |Error| 显示全部楼层
学习了,谢谢龚总提供的资料!
GMT+8, 2026-11-10 09:55 , Processed in 0.263980 second(s), 25 queries .
