查看: 151|回复: 2
请教各位老师,以下英文参数代表什么意思?
发表于 2012-10-5 09:40:21 |Error| 显示全部楼层 |阅读模式
Length   4,245m
Lift    -33m
Speed   4.4m/s
Width   1600mm
Design Capacity    4,000tph
Belt Type   SW-8000 (spliced)
Tripper    Location  1,345m In-bye of Jib Carry Side.
Removed when LW is 400m in-bye of tri
Power  2 x 320kW
Brake   2 x 22.5kN.m (on 900mm Pulleys)
Head  Power  3 x 250kW
    Brake    2 x 20kN.m (on 800mm Pulleys)
       Located on return side after Take-Up
其中胶带型号:SW-8000 (spliced)代表什么意思?是带强为8000吗,但是据我验算有2000就足够
还有就是tripper是卸料车吗,感觉也不太像,其中Removed when LW is 400m in-bye of tri 又是什么意思,?
请教各位老师
发表于 2012-10-7 10:23:29 |Error| 显示全部楼层
回复 1# wxd0408 Length   4,245m (机长)
Lift    -33m (提升高度)
Speed   4.4m/s (带速)
Width   1600mm (带宽)
Design Capacity    4,000tph (输送量)
Belt Type   SW-8000 (spliced) (输送带型号-估计是外国的)
Tripper    Location  1,345m In-bye of Jib Carry Side. (个人理解是卸料器设置位置)
Power  2 x 320kW (功率)
Brake   2 x 22.5kN.m (on 900mm Pulleys) (制动器-制动轮直径900mm)
Head  Power  3 x 250kW (头部驱动)
不知道是否正确?
其余的有待高手来解决
 楼主| 发表于 2012-10-10 14:50:16 |Error| 显示全部楼层
回复 2# dcdyc
   谢谢,没翻译的是难点啊!坐等高手出现
GMT+8, 2026-11-9 21:09 , Processed in 0.209649 second(s), 23 queries .
