查看: 2504|回复: 3
[求助] 英文技术要求请大家帮忙翻译
发表于 2007-6-22 10:08:16 |Error| 显示全部楼层 |阅读模式
3. ALL VENDORS MUST COAT INTERNAL THREADS WITH OIL/RUST INHIBITOR TO PREVENT CORROSION.
4.CARBONITRIDE ENTIRE PART TO  .015/ .025EFFECTIVE CASE DEPTH - SLOW COOL. LABCERTIFY CASE DEPTH.
5.INDUCTION HARDEN AREA SPECIFIED TO Rc 60MINMUM.
这几个句子中文是什么意思?
发表于 2007-6-22 11:56:15 |Error| 显示全部楼层
all vendors must coat internal threads with oil/rust inhibitor to prevent corrosion 所有供应商提供的内螺纹必须有防锈涂层以防腐蚀
carbonitride enter part to .015/ .025 effective case depth-slow cool, lab certify case depth ?
碳氮化进入零件.015/ .025有效深度-慢冷  实验室核实的深度
induction harden area specified to rc 60 minimum
硬化感应区精确到最小60
发表于 2007-6-22 17:20:14 |Error| 显示全部楼层
整个碳氮的有效部分的深度为0.015 / 0.25缓慢冷却. 实验室核实的深度 Labcertify零件的深度.
硬化感应区精确到洛氏硬度为60
发表于 2007-6-24 18:32:17 |Error| 显示全部楼层
指定位置硬化感应区硬度最小为RC60
GMT+8, 2026-11-4 05:48 , Processed in 0.220432 second(s), 23 queries .
