- 1532
- 80
- 2006-7-4
TPU 树脂 (Thermoplastic Polyurethane) ,由在1950年时即由 Schollenberger 等人开发出来,由于其具有优异之机械性质和弹性 (excellent mechanical and elastic property),极具耐磨耗性 (high abrasion) 和抗化学性质 (high chemical resistance),以及其与血液和细胞组织有很好的兼容性…等等特殊性质,因此迅速的发展成为一种日生活中和医疗上极为重要的材料。又因为TPU具有上述之优越性能,所以其应用范围相当广泛,如皮革工业、接着剂、弹性纤维 (elastic fiber、Spandex fiber) 、生医材料 (biomaterial) ,橡胶业改质剂…等等皆有其产品。另外,TPU之加工技术亦极为容易,使用一般之聚合物加工设备便可以加工之,如:射出成型 (injection molding)、挤压成型 (extrusion)、延压成型 (calendar)、纺丝 (spinning)、溶剂浇铸 (solvent casting)…皆可。
树脂与橡胶系树脂之硬度比照表
Polyurethane Block Copolymer
Polyurethane/urea Elastomers
Thermoplastic Polyurethane Elastomers
Belt/Extruder (Semi-Continuous) Process
Belt/Oven (Batch) Process
Reactive Extrusion (Continuous) Process
Hardness (ASTM-2240)
Polyether PolyolPolyester Polyol 70A-65D75A-65D
TPU供货商之介绍
SOME SUPPLIERS OF COMMERCIAL TPU s
1.Trade name of series Supplier
DesmopanElastolanCaprolanJectothaneTexinEstane BayerElastogranElastogranAlbis Plastics (UK)MobayBF Goodrich
2.韩日:SK,KOLON,DIC,大日精化
3.台湾:优德,大颖,高鼎,健日佳,虹溢,益晃,南亚,展宇,永纯,日胜,国庆,政侨,欣顺..
4.大陆:昆胜(台,福州),旭得(优德,广东),蓝宝(健日佳, 广东),茂永(台, 广东),华大,华鑫,…
典型TPU之射出成型的加工条件
TYPICAL INJECTION MOULDING CONDITIONS FOR A TPU
Mould temperature (℃)Period of maximum injection pressure (s)Period of holding pressure (s)Cooling time (s)Screw speed (rpm)Cylinder zone temperature (℃)Feed chamberTransfer area of screwCompression area of screwInjection nozzle 405104080150170180190
o TPU in pellet form must be completely dry, otherwise porosity will result in the moulded product.
o TPU pellets can be pre-dried by heating for 2h at 80℃ in a hot air circulatory drier.
TPU射或挤压成型时壁厚度与硬度及收缩率之关系
TPU射成型之螺杆及转速设计
TPU Feed Middle Front Nozzle
hardness(IRHD) zone zone zone
85 170 190 200 190
90 175 200 210 205
95 190 205 220 210
TPU之射出成型产生缺陷时之改进对策
Typical defect →Cause of problem ↓ Voids Splintering and flaking Surface blisters Flow lines and marks Burns, burn streaks Sink spots Flash formation Part adheres to mould
Material temperature too high × × × × × ×
Material temperature too low ×
Mould temperature too high × ×
Mould temperature too low ×
Granulate too moist × × ×
Follow-up pressure too low × ×
Clamping pressure too low ×
Injection pressure too low × ×
Injection speed too slow ×
Some causes of typical moulding defects in injection moulded TPU.
TPU加工条件之设计
? TPU 粒子加工前,必须充分干燥,水份最好维持在 0.03 以下。
? TPU 粒子之回收料加工,一般以不超过总量的 25% 为原则。
? 为了提高 TPU 之加工成型品的条件及物性,可加入 BS/PVC予以改变其流动性或物性,但以不超过总量的 15% 为原则。
? TPU 加工时碰到换色的场合,建议使用 PP/LDPE 来清洗料管,可获得最佳之利益。
TPU 射出成品之收缩率约在 0.3-0.8% 之间,在射出时增大模具浇口之口径、增长保压时间及射出压力及降低模具温度,都能有效减少成型品的收缩率。
WORLD CONSUMPTION OF POLYURETHANES
INDUSTRY % of Total
Furniture and MattressesAutomotiveBuildingRefrigerationShoeTextilesCoatingsOthers 39161374678
(1).鞋材:
1. 鞋底:
足球鞋底,高尔夫球底: 90A, 95A
高尔夫球鞋钉: 95A, 98A , 60D
一般鞋底 : 60A-70A (超软规格)
特殊鞋底 : 65A--85A (聚醚)
多色成型
2.天 皮 60D, 64D, 72D
3.鞋 饰:
饰 片: 80A--64D ( 本色, 半色, 全透),抗UV(4级以上)
气 袋(air bag): 85A-- 95A, TPU薄膜
TPU薄膜
4.标 签: TPU薄膜
5.雪 靴: 60D, 64D
6.皮面TPU膜贴合
7.TPU注塑发泡鞋底
(2).运动器材:?直排溜冰鞋轮 →90A、95A
?直排溜冰鞋芭扣条 →60D、64D
?直排溜冰鞋鞋壳 →64D、72D
?雪靴 →64D、72D
?滑板车轮 →85A,90A、95A
(3)工业机械零件?密封件 →85A、90A
?汽配件 →80A、85A、90A、95A
?管件 →85A、90A、95A、98A
?减震件 →85A、90A
(4)脚轮、行李轮 →80A、90A、95A
(5)表带 →80A、85A、90A(不渗粉,聚醚)
(6)电线、电缆: 雾面 →85A、90A、95A
亮面 →85A、90A、95A
阻燃
(7)空押管 →95A、98A
(8)押条 →85A、90A、95A
(9)消防水管 →90A、95A(聚醚,聚碳酯)
(10)薄膜 →78A、85A、92A、95A
(11)输送带 →85A、92A
(12)糊剂
(13)SPANDEX弹性纱
The Technology Trend
Environment:环保
? no ODP blowing agent:不使用 ODP 发泡剂 (不破坏臭氧层)
? water or HFC, liquid CO2 blown. recyclable, using natural fiber or polyol. 使用水气、HFC 或二氧化碳发泡?使用天然纤维或多元醇、回收再利用
Comfort:舒适性
? energy absorption, better humid compression set for HR cushion, gel, sound insulation. 吸震、防湿、隔音
Special functions:特殊机能
high ball rebound, transparent. 高回弹性、透明性
Lower cost:低价位
? lower density. 低密度
Strength:强度
? replace steel, engineering plastic. 取代钢材、工程塑料
Production efficiency:生产效率
? faster cycle time, using IMR. 更短工作周期
Working conditions:工作环境
? using MDI system instead of TDI system. 使用 MDI 取代 TDI
Energy saving:
VIP, other low K value material. 使用低 K 值材料
台湾优德TPU产品型号说明:
硬 度 ?? U(S,H) UF U-P UB UE UTX UTY
Shore A 60
Shore A 65
Shore A 70 UE-70A
Shore A 75 U-75AP UE-75A
Shore A 80 US-80A U-80AP UE-80A
Shore A 85 U-85A UF-85A U-85AP UB-85A UE-85A UTY-85A
Shore A 90 U-90A UF-90A U-90AP UB-90A UE-90A UTY-90A
Shore A 95 U-95A UF-95A U-95AP UB-95A UE-95A UTX-95A UTY-95A
Shore A 98 U-98A UF-98A U-98AP UB-98A UE-98A UTY-98A
Shore D 60 UH-60D UF-60D U-60DP UB-60D UE-60D UTX-60D UTY-60D
Shore D 64 UH-64D UF-64D U-64DP UB-64D UE-64D UTX-66D UTY-64D
Shore D 71 UH-71D UE-71D UTX-71D UTY-71D
Shore D 74 UE-75D
特性 一般???品 ??型 耐?性耐水解性佳 耐寒? 透明性耐水解性佳抗菌性佳 超透明? 透明?
肺? StandardEster EconomicEster SpecialEster SpecialEster Ether Ester Ester
硬 度 ?? UTC UT1C UT5C UT UT1 UHE US
Shore A 60 US-60A
Shore A 65 US-65A
Shore A 70 US-70A
Shore A 75 UHE-75A
Shore A 80 UTC-82A UT-80A
Shore A 85 UTC-85A UT1C-85A UT-85A UT1-85A
Shore A 90 UTC-90A UT1C-90A UT-90A UT1-90A UHE-88A
Shore A 95 UTC-95A UT1C-95A UT5C-95A UT-95A UT1-95A UHE-95A
Shore A 98 UTC-98A UT5C-98A UT-98A
Shore D 60 UTC-60D UT5C-60D UT-60D UT1-60D
Shore D 64 UTC-64D UT5C-64D UT-64D UT1-64D
特性 超透明?成形性佳 透明?成形性佳 透明性佳耐寒? ??型透明? 吹出成形 ?性好回?性佳 ?化?易成形
肺? SpecialEster SpecialEster SpecialEster Ester SpecialEster SpecialEther SpecialEster
硬 度 ?? USH UT7 UM UA U3 UC URG
Shore A 60 USH-60A
Shore A 65 USH-65A
Shore A 70 USH-70A UT7-70A UA-70AR
Shore A 75 UT7-78A UA-75AR
Shore A 80 UT7-83A
Shore A 85 UT7-85A UC-85A
Shore A 90 UT7-90A UM-88AE UA-90AR U3-90A UC-90A
Shore A 95 UT7-95A UHM-88AE
Shore A 98 UT7-98A U3-98A
Shore D 60 UT7-60D
特性 ?化?耐磨性佳 T-Die薄膜?格 透?薄膜?格 耐磨性特佳 劫晶性佳 耐?性耐水解性耐化?性 玻厉?化
肺? SpecialEster SpecialEster SpecialEther Ester SpecialEster SpecialEster SpecialEster
德国巴斯夫TPU:
主要适用于电线、电缆、电子插头、终端器、螺旋弯管、雪鞋外壳、动物用耳朵标识及各种技术产品。
Elastollan S规格系列 B规格系列(1、2) C规格系列(1、2) R规格系列
500规格 600规格 1100规格系列(1、2):
685A、690A、C60AW、C76AW、C75AW、C78W、C80A、C85A、C90A、C95A
C98A、C59D、C60D、C64D、C74D、1175AW、1180A、1185AW、1185A
1185AM、1185AFHF、1190A、1195A、1174D
应用: 运动休闲用品(鞋底、绑腿、旱冰滑板等)
汽车(排档仪表板、侧面仪表板、雪地防滑链、轴承、轴瓦等)
工程塑料制品(动力工具的手柄、传动带、轮胎、小车脚轮轮胎、导引辊、筛滤元件、密封元件等)
电线电缆(汽车电话线、盘绕电线、动力电缆、海底电缆等)
软管和短管(液压油管、压缩风管、可收放空气软管等)
其他(薄膜片、手表表带、牲畜标识牌、双筒望远镜外壳等)
特徵及优点:
Elastollan产品的硬度指标可供范围为从邵氏硬度60 A到74 D。
- 可以供应以聚醚或聚酯为主体结构、或玻璃纤维增强的、或含紫外线稳定剂的透明牌号等各种牌号等级的Elastollan产品。
* 聚醚基产品-Elastollan 1100牌号。
* 聚酯基产品-Elastollan C,B,S和500牌号。
* 玻璃纤维增强产品-Elastollan R牌号。
* 透明产品-Elastollan 600牌号。
Elastollan产品可以在注塑、挤出和吹塑等各种成型机械上加工成型。
- Elastollan产品的供货形式为方形或圆柱形小颗粒,均可完全回收循环使用。
- 性质:
* 高耐磨蚀性
* 高拉伸强度,对撕裂缝的扩展有极其突出的抵抗力
* 优异的阻尼性能
* 非常良好的低温柔软性
* 对油脂、氧和臭氧均有很强的抵抗力
福建昆胜TPU:
一般射出级用TPU:
物性 检测方式 NX-70A NX-80A NX-85A NX-90A NX-95A NX-98A NX-64D NX-72D
硬度 ASTM D-2240 70±2A 80±2A 85±2A 90±2A 95±2A 98±2A 64±2D 72±2D
比重 ASTM D-792 1.14 1.18 1.18 1.18 1.19 1.20 1.21 1.22
100%模数 ASTM D-412 30±15 50±15 60±15 85±15 115±15 140±15 200±20 260±20
抗张力 ASTM D-412 250±150 300±150 350±150 350±150 350±150 400±150 500±150 450±200
伸长率 ASTM D-412 800-1200 700-1000 600-900 500-800 500-800 500-800 400-700 200-500
撕裂强度 ASTM D-624/Die C 50±15 65±15 70±15 85±15 95±15 110±15 130±20 170±20
摩擦损耗 DIN 53516 55±5 50±5 40±5 40±5 45±5 45±5 55±5 60±5
建议烘干温度 100 100 105 105 105 110 110 110
烘干时间 3-5 3-5 3-5 3-5 3-5 3-5 3-5 3-5
建议射出温度 170-190 175-195 180-200 185-205 190-210 190-210 195-215 200-220
PU类型 Polyester
特性 一般性、物质性、结晶成型快、经济性
用途 鞋材、鞋饰片配件、背包背带、脚踏车配件、表带、机械用零配件、运动器材品、各种射出轮
备注 1.测试试片为厚度3mm或6mm之射出试片。2.除以上所列产品,可依客户需求添加抗氧化剂、抗UV、透明剂、抗水截剂等助剂。3.可依客户需求,配合设计开发其他规格产品。
管材类押出用TPU:
物性 检测方式 EX-80A EX-85A EX-90A EX-95A EX-98A EX-62D
硬度 ASTM D-2240 80±2A 85±2A 90±2A 95±2A 98±2A 62±2D
比重 ASTM D-792 1.22 1.22 1.22 1.22 1.22 1.22
100%模数 ASTM D-412 50±15 60±15 80±15 50±15 100±15 200±20
300%模数 ASTM D-412 80±25 105±25 120±25 160±30 180±30 250±40
抗张力 ASTM D-412 300±150 350±150 400±150 400±150 450±150 350±150
延伸率 ASTM D-412 650-1000 600-900 600-900 550-850 500-800 400-700
撕裂强度 ASTM D-624/Die C 70±15 80±15 85±15 90±15 95±15 110±20
建议烘干温度 105 105 105 105 110 110
螺杆转速 25-40 25-40 25-40 25-40 25-40 25-40
PU类型 Polyester Polyester Polyester Polyester Polyester Polyester
特性 一般级、物性优、易加工、经济性
用途 一般押出级水管、风管、包纱管、实心条、刚线披覆、电线电缆、异形押出
备注 1.滤网尺寸建议使用80、100或120筛目。2.建议押出成形加工温度(℃):175~230℃。3.测试试片为厚度3mm或6mm之射出试片。4.以上所列产品,本公司可依客户需求添加抗氧化剂、抗UV、透明剂、抗水解剂等助剂。5.本公司可依客户需求,配合设计开发其他规格产品。 |
