- 1532
- 80
- 2006-7-4
#1 G 化工 橡胶制品及其辅助材料
1 GB/T 517-1991 畜力车轮胎 Animal vehicle tyres
2 GB/T 519-1993 充气轮胎物理机械性能试验方法 Test method of the physical mechanical properties for pneumatic tyres
3 GB/T 521-1993 轮胎外缘尺寸测定方法 Method of measuring tyre peripheral dimensions
4 GB/T 524-1989 普通平带 General flat belting
5 GB/T 525-1965 平型胶带物理机械性能试验方法 Test methods for physical and mechanical properties for flat rubber belts
6 GB/T 529-1991 硫化橡胶撕裂强度的测定 (裤形、直角形和新月形试样) Rubber, vulcanized—Determination of tear strength (trouser, angle and crescent test pieces)
7 GB/T 531-1992 硫化橡胶邵尔A硬度试验方法 Rubber, vulcanized—Determination of shore A hardness
8 GB/T 1171-1996 一般用普通V带 Classical V-belts for general use
9 GB/T 1186-1992 压缩空气用橡胶软管 (2.5 MPa 以下) Rubber hose for compressed air (up to 2.5 MPa)
10 GB/T 1190-1991 工程机械轮胎 Off-the-road tyres
11 GB/T 1192-1991 农业轮胎 Agricultural tyres
12 GB/T 1232-1992 未硫化橡胶门尼粘度的测定 Rubber, unvulcanized—Determination of mooney viscosity
13 GB/T 1233-1992 橡胶胶料初期硫化特性的测定 门尼粘度计法 Rubber, unvulcanized--Determination of prevulcanization characteristics--Shearing disk method
14 GB/T 1682-1994 硫化橡胶低温脆性的测定 单试样法 Rubber, vulcanized--Determination of low-temperature brittleness(single test piece method)
15 GB/T 1687-1993 硫化橡胶在屈挠试验中温升和耐疲劳性能的测定 第二部分: 压缩屈挠试验 Rubber, vulcanized--Determination of temperature rise and resistance to fafigue in flexometer testing--Part 2: Compression flexometer
16 GB/T 1690-1992 硫化橡胶耐液体试验方法 Rubber, vulcanized-Determination of the effect of liquids
17 GB/T 1692-1992 硫化橡胶绝缘电阻率测定 Vulcanized rubber--Determination of the insulation resistivity
18 GB 1795-1996 轮胎气门芯 Tyre valve core
19 GB 1796-1996 轮胎气门嘴 Tyre valve
20 GB/T 2438-1981 硬质橡胶压碎强度的测定方法 Ebonite--Determination of crushing strength
21 GB/T 2439-1981 导电和抗静电橡胶电阻率(系数)的测定方法 Conducting and antistatic rubber--Determination of resistivity
22 GB/T 2550-1992 焊接及切割用橡胶软管 氧气橡胶软管 Specification for hose for equipment for gas welding, cutting and related processes—Oxygen rubber hose
23 GB/T 2551-1992 焊接及切割用橡胶软管 乙炔橡胶软管 Specification for hose for equipment for gas welding, cutting and related processes—Acetylene rubber hose
24 GB/T 2883-1993 工程机械轮辋规格系列 Series of off-road rims
25 GB/T 2941-1991 橡胶试样环境调节和试验的标准温度、湿度及时间 Rubber—Standard temperatures, humidities and times for the conditioning environmental and testing of test pieces
26 GB/T 2942-1991 硫化橡胶与织物帘线粘合强度的测定 H抽出法 Rubber, vulcanized—Determination of static adhesion to textile cord—H-pull test
27 GB/T 2979-1991 农业轮胎系列 Series of agricutural tyres
28 GB/T 2980-1991 工程机械轮胎系列 Series of off-the-road tyres
29 GB/T 2981-1991 工业车辆轮胎 Industrial tyres
30 GB/T 2982-1991 工业车辆轮胎系列 Series of industrial tyres
31 GB/T 3372-1989 拖拉机和农业、林业机械用轮辋系列 Rims series for tractors, agricultural and forestry machines
32 GB 3452.1-1992 液压气动用O形橡胶密封圈尺寸系列及公差 Fluid systems--Sealing devices--O-rings--Inside diameters, cross-sections, tolerances and size identification code
33 GB/T 3452.2-1987 O 形橡胶密封圈外观质量检验标准 Appearance quality acceptance criteria for rubber O-rings
34 GB/T 3452.3-1988 液压气动用O形橡胶密封圈 沟漕尺寸和设计计算 Fluid power systems--O-ring--Design criteria for O-ring housing--Basic calculation
35 GB/T 3510-1992 生胶和混炼胶的塑性测定 快速塑性计法 Rubber, unvulcanized--Determination of plasticity-Rapid plastimeter method
36 GB/T 3511-1983 橡胶大气老化试验方法 Rubber, vulcanized--The test method of resistance tonatural weathering
37 GB/T 3512-1983 橡胶热空气老化试验方法 Rubber, vulcanized--Accelerated ageing or heat-resistance test--Air-oven method
38 GB/T 3513-1983 橡胶与单根钢丝粘合强度的测定 抽出法 Rubber, vulcanized--Determination of adhesion to singlewire--Pull out test
39 GB/T 3514-1992 硫化橡胶中游离硫含量的测定 亚硫酸钠法 Rubber, vulcanized--Determination of free sulphur content--Sodium sulphite method
40 GB/T 3515-1983 硫化橡胶中炭黑含量的测定--热解法 Rubber,vulcanized--determination of carbon black content--pyrolytic method
41 GB/T 3516-1994 橡胶中溶剂抽出物的测定 Rubber--Determination of solvent extract
42 GB/T 3517-1992 天然生胶塑性保持率的测定 Rubber, raw natural--Determination of plasticity retention index
43 GB/T 3672-1992 模压、压出和压延实心橡胶制品的尺寸公差 Dimensional tolerances for moulded, extruded and calendered solid rubber products
44 GB/T 3683-1992 钢丝增强液压橡胶软管和软管组合件 Rubber hoses and hose assemblies--Wire reinforced hydraulic type
45 GB/T 3684-1983 运输带导电性规范和试验方法 Conveyor belts--Electrical conductivity--Specification and method of test
46 GB/T 3685-1996 输送带酒精喷灯燃烧性能规范和试验方法 Conveyor belts--Flame retardation--Specifications and test method
47 GB/T 3687-1989 V 带的层间粘合强度测定方法 V belts—Determination of ply adhesion
48 GB/T 3690-1994 织物芯输送带拉伸强度和伸长率测定方法 Conveyor belts of textile carcase--Test method for tensile strength and elongation
49 GB/T 3777-1996 橡胶用炭黑标准分类命名系统 Standard classification system for carbon blacks used in rubber products
50 GB 3778-1994 橡胶用炭黑 Carbon black for use in rubber industry
51 GB/T 3780.2-1994 炭黑邻苯二甲酸二丁酯吸收值的测定 Carbon black--Determination of dibutylphthalate absorption number
52 GB/T 3780.4-1994 炭黑(压缩试样)邻苯二甲酸二丁酯吸收值测定方法和试样制备 Carbon black--Preparation of sample and determination of dibutylphthalate absorption number(compressed sample)
53 GB/T 3780.5-1991 橡胶用炭黑比表面积测定 CTAB法 Carbon black used in rubber products--Determination of specific surface area—CTAB test method
54 GB/T 3780.7-1996 炭黑pH值的测定 Carbon black--Determination of pH value
55 GB/T 3780.8-1992 炭黑加热减量的测定 Carbon black—Determination of loss on heating
56 GB/T 3780.10-1992 炭黑灰分的测定 Carbon black—Determination of ash content
57 GB/T 3780.11-1995 炭黑筛余物的测定 Carbon black--Determination of sieve residue
58 GB/T 3780.12-1995 炭黑杂质的检查 Carbon black--Inspection of impurity material
59 GB/T 3780.13-1983 炭黑 (粒状) 倾注密度的测定 Carbon black (pelletized)--Determination of pour density
60 GB/T 3780.14-1995 炭黑硫含量的测定 Carbon black--Determination of sulphur content
61 GB/T 3780.16-1983 炭黑单个粒子压碎强度的测定 Carbon black--Determination of individual pellet crush strength
62 GB/T 3780.17-1995 炭黑粒径的间接测定 反射率法 Carbon black--Indirect determination of particle size--Reflectance method
63 GB/T 3780.21-1991 橡胶用炭黑筛余物测定 水冲洗法 Carbon black used in rubber products--Determination of sieve residue--Water washing method
64 GB/T 3781.4-1993 乙炔炭黑pH值的测定 Acetylene black--Determination of pH value
65 GB/T 3781.5-1993 乙炔炭黑粗粒分的测定 Acetylene black--Determination of grit content
66 GB/T 3781.6-1993 乙炔炭黑视比容的测定 Acetylene black--Determination of apparent specific volume
67 GB/T 3781.7-1993 乙炔炭黑吸碘值的测定 Acetylene black--Determination of iodine absorption number
68 GB/T 3781.8-1993 乙炔炭黑盐酸吸液量的测定 Acetylene black--Determination of hydrochloric acid absorption number
69 GB/T 3781.9-1993 乙炔炭黑电阻率的测定 Acetylene black--Determination of resistivity
70 GB/T 3782-1993 乙炔炭黑技术条件 Acetylene black--Specification limits
71 GB/T 4489-1984 平型传动带的宽度和长度 Flat transmission belts widths and lengths
72 GB/T 4490-1994 输送带尺寸 Conveyor belts--Dimensions
73 GB 4491-1993 橡胶输血胶管 Rubber transfusion tubes
74 GB/T 4497-1984 硫化橡胶全硫含量的测定 氧瓶燃烧法 Vulcanized rubber--Determination of total sulphur content--Oxygen combustion flask method
75 GB/T 4500-1984 硫化橡胶中锌含量的测定 火焰原子吸收光谱法 Vulcanized rubber--Determination of zinc content--Flame atomic absorption spectrometric method
76 GB/T 4503-1996 轿车轮胎强度试验方法 Strength test method for passenger car tyres
77 GB/T 5562-1985 胶管胶层物理试验方法 Methods of physical tests for rubber ldyers from finished hoses
78 GB/T 5563-1994 橡胶、塑料软管及软管组合件 液压试验方法 Rubber and plastics hoses and hose assemblies--Hydrostatic testing
79 GB/T 5564-1994 橡胶、塑料软管低温曲挠试验 Rubber and plastics hoses--Subambient temperature flexibility tests
80 GB/T 5565-1994 橡胶或塑料软管及纯胶管 弯曲试验 Rubber or plastics hoses and tubing--Bending tests
81 GB/T 5566-1985 胶管耐压扁试验方法 Rubber hose--Test method for crush resistance
82 GB/T 5567-1994 橡胶、塑料软管及软管组合件 真空性能的测定 Rubber and plastics hoses and hose assemblies--Determination of suction resistance
83 GB/T 5568-1994 橡胶、塑料软管及软管组合件 无屈挠液压脉冲试验 Rubber or plastics hoses and hose assemblies--Hydraulic impulse test without flexing
84 GB/T 5574-1994 工业用橡胶板 Industrial rubber sheet
85 GB/T 5719-1995 橡胶密封制品术语 Rubber sealings articles-Terminology
86 GB/T 5720-1993 O形橡胶密封圈试验方法 Test methods for rubber O rings
87 GB/T 5721-1993 橡胶密封制品标志、包装、运输、贮存的一般规定 General rules of identification, packaging, transportation and storage for rubber sealing products
88 GB/T 5723-1993 硫化橡胶或热塑性橡胶 试验用试样和制品尺寸的测定 Rubber, vulcanized or thermoplastic--Determination of dimensions of test pieces and products for test purposes
89 GB/T 5752-1992 输送带标志 Conveyor belts—Marking
90 GB/T 5753-1994 钢丝绳芯输送带覆盖层厚度的测定 Steel cord conveyor belts--Cover thickness measurement
91 GB/T 5754-1986 钢丝绳芯输送带纵向拉伸强度的测定 Steel cord conveyor belts—Longitudinal traction test—Measurement of tensile strength
92 GB/T 5755-1986 钢丝绳芯输送带钢丝绳粘合强度的测定 Steel cord conveyor belts—Cable-to-coating bond test
93 GB/T 5756-1986 输送带与传动带术语 Terms of conveyor belts and transmission belts
94 GB/T 6029-1996 硫化橡胶中促进剂的检定 薄层色谱法 Vulcanized rubber-Determination of accelerant-Thin layer chromatographic method
95 GB/T 6030-1985 硫化橡胶中炭黑分散度的测定 显微照相法 Vulcanized rubber--Determination of carbon black dispersion--Micrographic method
96 GB/T 6033-1985 硫化橡胶赵氏及邵坡尔硬度试验方法 Vulcanized rubber--Test method for the determination of Jones and Schopper hardness
97 GB/T 6034-1985 硫化橡胶压缩耐寒系数的测定 Vulcanized rubber--Determination of coefficient of cold-resistance under compression
98 GB/T 6035-1985 硫化橡胶拉伸耐寒系数的测定 Vulcanized rubber--Determination of coefficient of low temperature resistance at extention
99 GB/T 6036-1985 硫化橡胶低温刚性的测定 吉门试验 Vulcanized rubber--Determination of low temperature stiffening (Gehman test)
100 GB/T 6037-1985 硫化橡胶高温拉伸强度和扯断伸长率的测定 Vulcanized rubber--Determination of tensile strength and ultimate elongation at high temperatures
101 GB/T 6038-1993 橡胶试验胶料的配料、混炼和硫化设备及操作程序 Rubber test mixes--Preparation, mixing and vulcanization--Equipment and procedures
102 GB/T 6326-1994 轮胎术语 Tyre terms
103 GB/T 6327-1996 载重汽车轮胎强度试验放方法 Strength test method for truck and bus tyres
104 GB/T 6757-1986 输送带贮存和搬运通则 Conveyor belts--Guide to storage and handling
105 GB/T 6759-1986 输送带的层间粘合强度测定方法 Conveyor belts--Determination of ply adhesion
106 GB/T 6760-1986 平带的层间粘合强度测定方法 Flat belts--Determination of ply adhesion
107 GB/T 6761-1986 平带全厚度拉伸强度和伸长率测定方法 Flat transmission belting--Test method of full thickness tensile strength and elongation
108 GB/T 7035-1993 轻型载重汽车轮胎高速性能试验方法 转鼓法 High speed performence test for light truck tyres Drum method
109 GB 7037-1992 翻新和修补轮胎(斜交) Retreading and repair of tyres (Diagonal)
110 GB/T 7044-1993 色素炭黑技术条件 Colour black-Specification
111 GB/T 7045-1993 色素炭黑pH值的测定 Colour black--Determination of pH value
112 GB/T 7046-1995 色素炭黑邻苯二甲酸二丁酯吸收值的测定 Colour carbon black--Determination of dibutyl phthalate absorption number
113 GB/T 7047-1993 色素炭黑挥发分含量的测定 Colour black--Determination of volatile content
114 GB/T 7048-1993 色素炭黑黑度的测定 Colour black--Determination of blackness
115 GB/T 7050-1993 色素炭黑着色力的测定 Colour black--Determination of tinting strength
116 GB/T 7052-1995 色素炭黑流动度的测定 Colour carbon black--Determination of flow characteristic
117 GB 7127-1986 汽车液压制动胶管 Rubber hose for automotive hydraulic brake system
118 GB 7128-1986 汽车气压制动胶管 Rubber hose for automotive air brake system
119 GB/T 7129-1986 汽车液压制动胶管内容积膨胀测定方法 Determination of volumetric expansion of rubber hose for automotive hydraulic brake system
120 GB/T 7528-1987 橡胶软管术语 Rubber hose--Glossary of terms
121 GB/T 7535-1996 硫化橡胶分类 分类系统说明 Rubber, vulcarized--Classification--Description of the classification system
122 GB 7542-1987 铁路机车车辆制动用橡胶软管 Rubber brake hoses for railway locomotive and car
123 GB 7543-1996 橡胶医用手套 Rubber surgical gloves
124 GB/T 7755-1987 硫化橡胶透气性的测定 恒容法 Rubber, vulcanized--Determination of permeability to gases--Constant volume method
125 GB/T 7756-1987 硫化橡胶透气性的测定 恒压法 Rubber, vulcanized--Determination of permeability to gases--Constant pressure method
126 GB/T 7757-1993 硫化橡胶或热塑性橡胶压缩应力应变性能的测定 Rubber,vulcanized or thermoplastic--Determination of compression stress-strain properties
127 GB/T 7758-1987 硫化橡胶低温特性的测定 温度回缩法 (TR试验) Rubber, vulcanized--Determination of low temperature characteristics--Temperature-retraction procedure(TR test)
128 GB/T 7759-1996 硫化橡胶、热塑性橡胶 常温、高温和低温下压缩永久变形测定 Rubber, Vulcanized or thermoplastic Determination of compression set at ambient elevated or low temperatures
129 GB/T 7760-1987 硫化橡胶与金属粘合的测定 单板法 Rubber, vlcanized--Determination of adhesion to metal--One-plate method
130 GB/T 7761-1987 橡胶与刚性材料粘合强度的测定 圆锥形件法 Rubber--Determination of adhesion to rigid materials using conical shaped parts
131 GB/T 7762-1987 硫化橡胶耐臭氧老化试验 静态拉伸试验法 Rubber, vulcanized--Resistance to ozone ageing--Static strain test method
132 GB/T 7763-1987 硫化橡胶溶胀指数测定方法 Rubber, vulcanized--Determination method of swelling index
133 GB/T 7764-1987 橡胶鉴定 红外分光光度法 Rubber--Identification--Infrared spectrometric method
134 GB/T 7765-1987 橡胶中铜含量的测定 二乙基二硫代氨基甲酸锌光度法 Rubber--Determination of copper content--Zinc diethyldithiocar bamate photometric method
135 GB/T 7766-1987 硫化橡胶中炭黑含量的测定 硝酸消化法 Rubber, vulcanized--Determination of carbon black content--Nitric acid digestion method
136 GB/T 7767-1994 炭黑术语 Standard terminology relating to carbonblack
137 GB/T 7983-1987 输送带成槽性试验方法 Conveyor belts--Troughability--Method of test
138 GB/T 7984-1987 普通用途织物芯输送带 Conveyor belts of duck construction for general use
139 GB/T 7985-1987 输送带带芯抗撕裂性试验方法 Conveyor belts--Carcass tear resistance--Method of test
140 GB/T 9571-1988 橡胶、塑料软管静态条件下耐臭氧性能的评定 Rubber and plastics hoses--Assessment of ozone resistance under static conditions
141 GB/T 9572-1988 橡胶塑料软管和软管组合件电阻的测定 Rubber and plastics hoses and hose assemblies--Determination of electrical resistance
142 GB/T 9573-1988 橡胶、塑料软管和软管组合件尺寸测量方法 Rubber and plastics hoses and hose assemblies--Methods of measurement of dimensions
143 GB/T 9574-1988 橡胶、塑料软管和软管组合件试验压力、爆破压力与设计工作压力的比率 Rubber and plastics hoses and hose assemblies--Ratios of proof and burst pressure to design working pressure
144 GB/T 9575-1988 橡胶、塑料软管内径尺寸和长度公差 Rubber and plastics hoses--Bore diameters and tolerances on length
145 GB/T 9577-1988 橡胶、塑料软管和软管组合件标志、包装和运输规则 Rubber and plastics hoses and hose assemblies--Specification for mar king, package and transportation
146 GB/T 9578-1988 标准参比炭黑 Standard reference black
147 GB/T 9580-1988 标准参比炭黑的鉴定方法 Standard practice for carbon black--Evaluation of a standard reference black
148 GB 9745-1995 航空轮胎 Aircraft tyre
149 GB/T 9746-1995 航空轮胎系列 Series of aircraft tyres
150 GB/T 9747-1988 航空轮胎动力模拟试验方法 Dynamometer test methods for aircraft tyres
151 GB/T 9766-1994 轮胎气门嘴试验方法 Test method for tyre valve
152 GB/T 9767-1994 轮胎气门芯试验方法 Test method for tyre valve core
153 GB/T 9768-1988 轮胎使用与保养规程 Regulation of application and maintenance of tyres
154 GB/T 9769-1988 轮辋轮廓检测 Rim contour inspection
155 GB/T 9770-1988 钢丝绳芯输送带 Steel cord conveyor belts
156 GB 9865-1988 硫化橡胶样品和试样的制备 Rubber, vulcanized--Preparation of samples and test pieces
157 GB/T 9865.1-1996 硫化橡胶或热塑性橡胶样品和试样的制备 第一部分: 物理试验 Rubber, vulcanized or thermoplastic--Preparation of samples and test pieces--Part1: Physical tests
158 GB/T 9867-1988 硫化橡胶耐磨性能的测定 (旋转辊筒式磨耗机法) Rubber--Determination of abrasion resistance using a rotating cylinderical drum device
159 GB/T 9868-1988 橡胶获得高于或低于常温试验温度通则 Rubber--General directions for achieving elevated or subnormal temperatures for test purposes
160 GB/T 9870-1988 弹性体动态试验的一般要求 Elastomers--General requirements for dynamic testing
161 GB/T 9871-1988 硫化橡胶老化性能的测定 (拉伸应力松弛试验) Rubber,vulcanized--Determination of ageing characteristics by measurement of stress at a given elongation
162 GB/T 9873-1988 橡胶中铅含量的测定 双硫腙光度法 Rubber--Determination of lead content--Dithizone photometric method
163 GB/T 9874-1988 硫化橡胶中金属含量的测定 火焰原子吸收光谱法 第三部分: 铅含量的测定 Vulcanized rubber--Determination of metal content--Flame atomic absorption spectrometric method--Part 3: Determination of lead content
164 GB/T 9875-1988 硫化橡胶中聚合物的鉴定 化学方法 Vulcanized rubber--Identification of polymers--Chemical method
165 GB/T 9877.1-1988 旋转轴唇形密封圈结构尺寸系列 第一部分: 内包骨架旋转轴唇形密封圈 Rotary shaft lip seals--Design criteria for standard applications--Part 1: rubber covered rotary shaft lip seals
166 GB/T 9877.2-1988 旋转轴唇形密封圈结构尺寸系列 第二部分: 外露骨架旋转轴唇形密封圈 Rotary shaft lip seals--Design criteria for standard applications--Part 2: Metal cased rotary shaft lip seals
167 GB/T 9877.3-1988 旋转轴唇形密封圈结构尺寸系列 第三部分: 装配式旋转轴唇形密封圈 Rotary shaft lip seals--Design criteria for standard applications--Part 3: assembled rotary shaft lip seals
168 GB/T 9881-1988 橡胶与橡胶制品通用术语 Rubber and rubber products general-purpose terms
169 GB/T 9882-1988 再生橡胶术语及定义 Reclaimed rubber terms and definitions
170 GB/T 9885-1988 食品用及医用橡胶制品术语 Terms of rubber products for foodstuff and medicine
171 GB/T 9887-1988 胶乳制品术语 Rubber latices products terms
172 GB/T 9900-1988 抽出式难燃橡胶导风筒 Extractable ventilation rubber ducting of the fire retardant
173 GB 10213-1995 一次性使用橡胶检查手套 Singie-use rubber examination glove-Specification
174 GB/T 10541-1989 近海停泊排吸油橡胶软管的分类、规格和基本技术要求 Classification, dimension and basic requirements for rubber hose—Oil suction and discharge—Offshore mooring
175 GB 10543-1989 飞机地面加油和泄油用橡胶软管 Rubber hoses for aircraft ground fuelling and defuelling
176 GB/T 10544-1989 钢丝缠绕增强外覆橡胶的液压橡胶软管和软管组合件 Rubber hoses and hose assemblies—Rubber-covered,spiral wire reinforced, hydraulic type—Specification
177 GB 10546-1989 液化石油气 (LPG) 橡胶软管 Liquid petroleum gas rubber hose
178 GB/T 10652-1989 高聚物多孔弹性材料弹性的测定 Polymeric materials, cellular flexible—Determination of resilience
179 GB/T 10653-1989 高聚物多孔弹性材料压缩永久变形的测定 Polymeric materials, cellular flexible—Determination of compression set
180 GB/T 10654-1989 高聚物多孔弹性材料拉伸强度和扯断伸长率的测定 Polymeric materials, cellular flexible—Determination of tensile strength and elongation at break
181 GB/T 10655-1989 高聚物多孔弹性材料空气透气率的测定 Polymeric materials, cellular flexible—Determination of air flow permeability
182 GB/T 10707-1989 橡胶燃烧性能测定 氧指数法 Rubber—Determination of flammability by oxygen index
183 GB/T 10708.1-1989 往复运动橡胶密封圈结构尺寸系列 第一部分: 单向密封橡胶密封圈 Reciprocating rubber seals—Design criteria for standard applications—Part 1: Rubber seals of act on single seal
184 GB/T 10708.2-1989 往复运动橡胶密封圈结构尺寸系列 第二部分: 双向密封橡胶密封圈 Reciprocating rubber seals—Design criteria for standard applications—Part 2: Rubber seals of act on doubls seal
185 GB/T 10708.3-1989 往复运动橡胶密封圈结构尺寸系列 第三部分: 橡胶防尘密封圈 Reciprocating rubber seals—Design criteria for standard applications—Part 3: rubber seals for wipers
186 GB/T 10714-1989 V 带难燃性规范和试验方法 V-belts—Specification of the fire-resistivity and the test method
187 GB/T 10715-1989 抗静电环形V带导电性规定值和试验方法 Antistatic endless V-belts—Electrical conductivity —Characteristic and method of test
188 GB/T 10716-1989 同步带拉伸性能试验方法 Synchronous belt—Test method for tensile properties
189 GB/T 10717-1989 同步带齿剪切强度试验方法 Synchronous belt—Test method for tooth shearing strength
190 GB/T 10718-1989 同步带包布剥离强度试验方法 Synchronous belt—Test method for fabric stripping strength
191 GB/T 10719-1989 同步带绳抽出强度试验方法 Synchronous belt—Test method for cord pull-out strength
192 GB/T 10722-1989 炭黑比表面积的测定 氮吸附方法 Carbon black—Determination of specific surface area —Nitrogen adsorption method
193 GB/T 10723-1989 用ASTM标准参比炭黑改善炭黑试验再现性的标准方法 Standard method for carbon black—Improving test reproducibility using ASTM reference blacks
194 GB/T 10821-1993 农业机械用V带尺寸 V-belts for agricultural machinery-Dimensions
195 GB/T 10822-1989 一般用途难燃输送带 Frame retardant conveyor belts for general use
196 GB/T 10823-1996 充气轮胎轮辋实心轮胎系列 Series of solid tyres for pneumatic tyres rims
197 GB/T 10824-1996 充气轮胎轮辋实心轮胎 Solid tyres for pneumatic tyres rims
198 GB/T 11063-1989 聚酰胺片基平带 Polyamide plate based flat belt
199 GB/T 11191-1989 航空轮胎爆破压力试验方法 Burst pressure test method for aircraft tyre
200 GB/T 11192-1989 航空轮胎静负荷性能试验方法 Test method of static loaded perfor mance for aircraft tyre
201 GB/T 11194-1989 航空无内胎轮胎气密性能试验方法 Air retention test method for tubeless aircraft tyre
202 GB/T 11196-1989 航空轮胎断面分析测量方法 Section diagnose and measure method for aircraft tyre
203 GB/T 11201-1989 硫化橡胶中金属含量的测定 火焰原子吸收光谱法 第四部分: 铁含量的测定 Vulcanized rubber—Determination of metal content—Flame atomic absorption spectrometric method—Part 4: Determination of iron content
204 GB/T 11202-1989 橡胶中铁含量的测定 1,10-菲罗啉光度法 Rubber—Determination of iron content—1,10-Phenanthroline photometric method
205 GB/T 11203-1989 硫化橡胶中锌含量的测定 EDTA 滴定法 Vulcanized rubber—Determination of zinc content—EDTA titrimetric method
206 GB/T 11204-1989 橡胶国际硬度(30~90 IRHD)的测定 袖珍硬度计法 Rubber—Determination of hardness (30~90IRHD)—Poket hardness meter method
207 GB/T 11205-1989 橡胶热导率的测定 瞬态热丝法 Rubber—Determination of thermal conductivity by means of transient hot-wire method
208 GB/T 11206-1989 硫化橡胶老化表面龟裂试验方法 Rubber vulcanized—The test method of deteration surface cracking
209 GB/T 11208-1989 硫化橡胶滑动磨耗的测定 Rubber, vulcanized—Determination of abrasion resistance under slipping
210 GB/T 11209-1989 磁性橡胶磁性能的测定方法 Magnetic rubber—Determination method of magnetic properties
211 GB/T 11210-1989 硫化橡胶抗静电和导电制品电阻的测定 Rubber, vulcanized—Antistatic and conductive products—Determination of electrical resistance
212 GB/T 11211-1989 硫化橡胶与金属粘合强度的测定 拉伸法 Rubber, vulcanized—Determination of adhesion to metal—Tension method
213 GB/T 11545-1996 汽车V带疲劳试验方法 V-belt drives for the automotive industry--Fatigue test
214 GB/T 11616-1989 同步带尺寸 Synchronous belts—Dimensions
215 GB/T 12584-1990 橡胶或塑料涂覆织物低温冲击试验 Rubber or plastics coated fabrics—Low temperature impact test
216 GB/T 12585-1990 硫化橡胶涂覆织物挥发性液体蒸气透过速率的测定 质量法 Fabrics coated with vulcanized rubber—Determination of vapour transmission rate of volatile liquids—gravimetric technique
217 GB/T 12586-1990 橡胶或塑料涂覆织物耐屈挠破坏性能的测定 动态法 Rubber or plastics coated fabrics—Determination of resistance to damage by flexing(Dynamic method)
218 GB/T 12587-1990 橡胶或塑料涂覆织物抗压裂性能的测定 Rubber or plastics coated fabrics—Determination of crush resistance
219 GB/T 12588-1990 塑料涂覆织物 聚氯乙烯涂覆层快速测融法 Plastics coated fabrics—Polyvinyl chloride coatings—Rapid method for checking fusion
220 GB/T 12721-1991 橡胶软管 外胶层耐磨耗性能的测定 Rubber hoses—Determination of abrasion resistance of the outer cover
221 GB/T 12722-1991 橡胶和塑料软管组合件 屈挠液压脉冲试验(半Ω试验) Rubber and plastics hose assemblies—Flexing combined with hydraulic impulse test (Half omega test)
222 GB/T 12730-1991 窄V带 Narrow V-belt
223 GB 12731-1991 难燃V带 Fire resistant V-belt
224 GB 12732-1996 汽车V带 Automotive V-belts
225 GB/T 12733-1994 工业用变速宽V带尺寸 Size-Speed-chaingers wide V-belts for industry
226 GB/T 12734-1991 汽车同步带尺寸 Automotive synchronous belt—Dimensions
227 GB/T 12735-1991 农业机械用V带疲劳试验方法 Fatigue test method for agricultural V-belts
228 GB/T 12736-1991 输送带机械接头强度的测定 静态试验方法 Conveyor belts—Determination of strength of mechanical fastening—Static test method
229 GB/T 12825-1991 高聚物多孔弹性材料凹入度法硬度试验 Polymeric materials, cellular flexible—Determination of hardness (indentation technique)
230 GB/T 12827-1991 标准参比乙炔炭黑及鉴定方法 Standard reference acetylene black and standard practice for evaluation
231 GB/T 12828-1991 生胶和混炼胶塑性值及复原值的测定 平行板法 Rubber, raw and unvuicanized compounded—Determination of plasticity number and recovery number—Parallel plate method
232 GB/T 12829-1991 硫化橡胶小试样(德尔夫特试样)撕裂强度的测定 Rubber, vulcanized—Determination of tear strength of small test pieces (Delft test pieces)
233 GB/T 12830-1991 硫化橡胶与金属粘合剪切强度测定方法 四板法 Rubber, vulcanized—Determination of adhesion to metal plates in shear—Quadruple shear method
234 GB/T 12831-1991 硫化橡胶人工气候(氙灯)老化试验方法 Rubber, vulcanized—Test method of resistance to artificial weathering (xenon are lamp)
235 GB/T 12832-1991 橡胶结晶效应的测定 硬度测量法 Rubbers—Determination of crystallization effects by hardness measurements
236 GB/T 12833-1991 橡胶和塑料撕裂强度及粘合强度多峰曲线的分析方法 Rubber and plastics—Analysis of multi-peak traces obtained in determinations of tear strength and adhesion strength
237 GB/T 12834-1991 硫化橡胶 性能优选等级 Rubber, vulcanized—Preferred gradations of properties
238 GB 12835-1991 胶座气门嘴 Rubber base valves
239 GB 12836-1991 无内胎气门嘴 第一部分: 卡扣式气门嘴 Tubeless valves—Part 1: Snap-in valves
240 GB 12837-1991 大芯腔轮胎气门嘴 Tyre valves for large core chamber
241 GB 12838-1991 大芯腔轮胎气门芯 Tyre valve cores for large core chamber
242 GB/T 12939-1991 工业车辆轮辋规格系列 Rim contours for industrial trucks
243 GB/T 13203-1991 摩托车轮胎强度性能试验方法 Strength test for motorcycle tyres
244 GB/T 13204-1991 磨托车轮胎高速性能试验方法 转鼓法 High speed performance test for motorcycle tyres—Drum method
245 GB/T 13205-1991 磨托车轮胎耐久性能试验方法 转鼓法 Endurance test for motorcycle tyres—Drum method
246 GB/T 13248-1991 硫化橡胶中锰含量的测定 高碘酸钠光度法 Vulcanized rubber—Determination of manganese content—Sodium periodate photometric methods
247 GB/T 13249-1991 硫化橡胶中橡胶含量的测定 管式炉热解法 Rubber vulcanized —Determination of rubber content—Furnace tube pyrolytic method
248 GB/T 13250-1991 硫化橡胶中总硫量的测定 过氧化钠熔融法 Vulcanized rubber—Determination of total sulfur content—Sodium peroxide fusion method
249 GB/T 13253-1991 硫化橡胶中金属含量的测定 火焰原子吸收光谱法 第五部分: 锰含量的测定 Vulcanized rubber—Determination of metal content—Flame atomic absorption spectrometric method--Part 5: Determination of manganese content
250 GB/T 13352-1996 汽车V带尺寸 Automotive V-belts-Dimensions
251 GB/T 13460-1992 再生橡胶 Reclaimed rubber
252 GB/T 13487-1992 一般传动用同步带 Synchronous belts for general drive
253 GB/T 13488-1992 橡胶燃烧性能测定 垂直燃烧法 Rubber—Determination of the burning behaviour of vertical specimens
254 GB/T 13489-1992 橡胶涂覆织物燃烧性能测定 Rubber coated fabrics—Determination of the burning behaviour
255 GB/T 13490-1992 V 带均匀性规范和试验方法 中心距变化量法 V-belts—Uniformity of belts—Centre distance variation—Specification and test method
256 GB/T 13642-1992 硫化橡胶耐臭氧老化试验 动态拉伸试验法 Rubber, Vulcanized--Resistance to ozone ageing-Dynamic strain test method
257 GB/T 13643-1992 硫化橡胶或热塑性橡胶 压缩应力松弛的测定 环状试样 Rubber, vulcanized or thermoplastic--Determination of compression stress relaxation(rings)
258 GB/T 13644-1992 硫化橡胶中镁含量的测定 CyDTA 滴定法 Vulcanized rubber--Determination of magnesium content—CyDTA titration
259 GB/T 13645-1992 硫化橡胶中钙含量的测定 EGTA滴定法 Vulcanized rubber—Determination of calcium content—EGTA titration
260 GB/T 13646-1992 橡胶中结合苯乙烯含量的测定 分光光度法 Rubber—Determination of bound styrene content—Spectrophotometric method
261 GB/T 13647-1992 橡胶制品用原材料筛余物的测定 水冲洗法 Compounding ingredients for rubber products--Determination of sieve residue—Water-flushing method
262 GB/T 13652-1992 航空轮胎表面质量 Surface quality of aircraft tyre
263 GB/T 13653-1992 航空轮胎X射线检测方法 X-ray inspection method for aircraft tyre
264 GB/T 13654-1992 航空轮胎全息照像检测方法 Method of holographic inspection for aircraft tyre
265 GB/T 13655-1992 航空轮胎静平衡差度试验方法 Static unbalance test method for aircraft tyre
266 GB/T 13656-1992 航空轮胎物理性能试验方法 Physical properties test method for aircraft tyres
267 GB 13871-1992 旋转轴唇形密封圈基本尺寸和公差 Rotary shaft lip type seals--Nominal dimensions and tolerances
268 GB/T 13934-1992 硫化橡胶屈挠龟裂的测定 Rubber, vulcanized--Determination of flex cracking
269 GB/T 13935-1992 硫化橡胶裂口增长的测定 Rubber, vulcanized--Determination of crack growth
270 GB/T 13936-1992 硫化橡胶与金属粘接拉伸剪切强度测定方法 Rubber, vulcanized--Method for determination of strength properties of adhesive to metal in shear by tension loading
271 GB/T 13937-1992 分级用硫化橡胶动态性能的测定 强圃积弦剪切应变法 Rubber--Determination of dynamic properties of vulcanizates for classification purposes (by forced sinusoidal shear strain)
272 GB/T 13938-1992 硫化橡胶自然贮存老化试验方法 Rubber,vulcanized--Test method of natural storage aging
273 GB/T 13939-1992 硫化橡胶热氧老化试验方法 管式仪法 Rubber, vulcanized--Test method of heat and oxygen--Tube tester ageing method
274 GB/T 14273-1993 旋转轴唇形密封圈性能试验方法 Rotary shaft lip type seals--Performance test proceduces
275 GB/T 14274-1993 高聚物多孔弹性材料加速老化试验 Polymeric materials cellular flexible--Accelerated ageing tests
276 GB/T 14562-1993 普通V带和窄V带疲劳试验方法 Fatigue test methods for classical V-belts and narrow V-belts
277 GB 14646-1993 翻新和修补轮胎(子午线轮胎) Retreading and repair of tyres(radial tyres)
278 GB/T 14828-1993 农业轮胎牵引性能试验方法 Testing methods of traction performance for agricultural tyres
279 GB/T 14829-1993 农业机械用变速(半宽)V带 Variable-speed(half wide)V-belts for agricultural machinery
280 GB 14830-1993 单个包装的避孕套技术要求 Requirements of condoms in individual packages
281 GB/T 14831-1993 胶乳制品蒸汽老化试验方法 Rubber latex products--Test method for resistance to steam ageing
282 GB/T 14832-1993 橡胶材料与液压流体的相容性试验 Test of compatibility between rubber material and hydraulic fluid
283 GB/T 14834-1993 硫化橡胶与金属粘附性及对金属腐蚀作用的测定 Rubber, vulcanized--Determination of adhesion to, and corrosion of metals
284 GB/T 14835-1993 硫化橡胶在玻璃下耐阳光曝露试验方法 Rubber,vulcanized--Test method of exposure for resistance daylight under glass
285 GB/T 14836-1993 硫化橡胶灰分的定性分析 Vulcanized rubber--Qualitative analysis of ash
286 GB/T 14837-1993 橡胶及橡胶制品组分含量的测定 热重分析法 Rubber and rubber products--Determination of composition by thermogravimetry
287 GB/T 14838-1993 橡胶与橡胶制品 试验方法标准 精密度的确定 Rubber and rubber products--Determination of precision for test method standards
288 GB/T 14853.1-1993 橡胶用造粒炭黑倾注密度的测定 Rubber compounding ingredients--Carbon black, pelletized--Determination of pour density
289 GB/T 14853.2-1993 橡胶用造粒炭黑细粉含量的测定 Rubber compounding ingredients--Carbon black, pelletized--Determination of fines content
290 GB/T 14853.3-1993 橡胶用造粒炭黑粒子磨损量的测定 Rubber compounding ingredients--Carbon black, pelletized--Determination of pellet atrition
291 GB/T 14853.4-1993 橡胶用造粒炭黑堆积强度的测定 Rubber compounding ingredients--Carbon black, pelletized--Determination of mass strength
292 GB/T 14853.5-1993 橡胶用造粒炭黑粒子尺寸分布的测定 Rubber compounding ingredients--Carbon black, pelletized--Determination of pellet size distribution
293 GB/T 14853.6-1993 橡胶用造粒炭黑单个粒子破碎强度的测定 Rubber compounding ingredients--Carbon black, pelletized--Determination of individual pellet crushing strength
294 GB/T 14853.7-1994 橡胶用造粒炭黑技术条件 Rubber compounding ingredient--Carbon black, pelletized--Specification
295 GB/T 14904-1994 钢丝增强的橡胶、塑料软管和软管组合件 屈挠液压脉冲试验 Rubber and plastics hose and hose assemblies--Wire reinforced--Hydraulic impulse test with flexing
296 GB/T 14905-1994 橡胶和塑料软管各层间粘合强度测定 Rubber and plastics hose--Determination of adhesion between components
297 GB/T 15251-1994 橡胶 游离硫的测定 铜螺旋法 Rubber--Determination of free sulphur--Copper spiral method
298 GB/T 15252-1994 橡胶中硫化物型硫含量的测定 碘量法 Rubber--Determination of sulfide sulfur content--Lodometric method
299 GB/T 15253-1994 橡胶 游离硫的测定 电位滴定法 Rubber--Determination of free Sulpher--Potentiometic titration method
300 GB/T 15254-1994 硫化橡胶与金属粘接180°剥离试验 Rubber, vulcanized--Determination of adhesion to metal--180°Peel test method
301 GB/T 15255-1994 硫化橡胶人工气候老化(碳弧灯)试验方法 Rubber, vulcanized--Test method for artifical weathering(carbon-arc lamp)
302 GB/T 15256-1994 硫化橡胶低温脆性的测定(多试样法) Rubber, vulcanized--Determination of low-temperature brittleness(multiple test piece method)
303 GB 15323-1994 航空轮胎内胎 Inner tube for pneumatic tyre of aircraft
304 GB/T 15324-1994 航空轮胎内胎物理性能试验方法 The physical properties test method for inner tube of aircraft tyre
305 GB/T 15325-1994 往复运动橡胶密封圈外观质量 Appearance quality for reciprocating rubber seals
306 GB/T 15326-1994 旋转轴唇形密封圈外观质量 Appearance quality for rotary shaft lip seals
307 GB/T 15327-1994 工业用变速宽V带及其尺寸 Variable speed-changers wide V-belts and size for industry
308 GB/T 15328-1994 普通V带疲劳试验方法(无扭矩法) Classical V-belts--Fatigue test(non-loading method)
309 GB/T 15329-1994 织物增强液压橡胶软管和软管组合件 Rubber hoses and hose assemblies-Textile-reinforced hydraulic type
310 GB/T 15338-1994 炭黑试验方法精密度和偏差的确认 Standard guide for carbon black--Validation of test method precision and bias
311 GB/T 15339-1994 炭黑在丁腈橡胶中配方及鉴定方法 Carbon black in NBR (acrylonitrile-butadiene rubber)--Recipe and evaluation method
312 GB/T 15340-1994 天然、合成生胶取样及制样方法 Rubber, raw, natural and synthetic sampling and further preparative procedures
313 GB/T 15584-1995 硫化橡胶在屈挠试验中温升和耐疲劳性能的测定 第一部分:基本原理 Rubber, vulcanized--Determination of temperature rise and resistance to fatigue in flexometer testing--Part 1: Basic principles
314 GB/T 15846-1995 集装箱门框密封条 The door gasket for freight containers
315 GB/T 15902-1995 织物芯输送带弹性模量试验方法 Conveyor belts--Determination of elastic modulus
316 GB/T 15904-1995 橡胶中聚异戊二烯含量的测定 Rubber--Determination of polyisoprene content
317 GB/T 15905-1995 硫化橡胶湿热老化试验方法 Rubber, vulcanized--Test method of damp heat aging
318 GB/T 15906-1995 橡胶中丁基橡胶或聚异丁烯含量的测定 Rubber--Determination of isoprene--isobutylene rubber or poly isobutylene content
319 GB/T 15907-1995 橡胶、塑料软管 燃烧试验方法 Rubber and plastics hoses--Method of test for flammability
320 GB/T 15908-1995 织物增强液压型热塑性塑料软管和软管组合件 Plastics hose and hose assemblies--Thermoplastics, textile-reinforced, hydraulic type
321 GB/T 16412-1996 输送带丙烷燃烧器燃烧试验方法 Test method for burn test of conveyor belt using propane burner
322 GB/T 16583-1996 不饱和橡胶中饱和橡胶的鉴定 第一部分 酸消化法 Rubbers saturated--Identification in unsaturated rubbers--Part 1: by acid digestion
323 GB/T 16584-1996 橡胶 用无转子硫化仪测定硫化特性 Rubber--Measurement of vulcanization characteristics with rotorless curemeters
324 GB/T 16585-1996 硫化橡胶人工气候老化(荧光紫外灯)试验方法 Rubber,vulcanized--Test method of resistance to artificial weathering (Fluorescent UV lamp)
325 GB/T 16586-1996 硫化橡胶与钢丝帘线粘合强度的测定 Rubber,vulcanized--Determination of adhesion to wire cord
326 GB/T 16588-1996 工业用多楔带及带轮尺寸 (PH、PJ、PK、PL和PM型 ) V-ribbed belts and pulleys for industrial applications--Dimensions (PH PJ PK PL and PM profiles)
327 GB/T 16589-1996 硫化橡胶分类 橡胶材料 Rubber, vulcanized--Classification--Rubber materials
328 GB/T 16590.1-1996 消防用不可折叠型橡胶和塑料软管 第1部分: 定位应急设施用轴卷半硬性软管 Rubber and plastics hoses, non-collapsible, for fire-fighting service--Part 1: Semi-rigid reel hose for fixed first-aid installations
329 GB/T 16591-1996 输送无水氨用橡胶软管及软管组合件 Rubber hose and hose assemblies for transferring anhydrous ammonia
330 GB/T 16593-1996 旋转轴唇形密封圈术语 Rotary shaft lip type seals--Vocabulary
331 GB/T 16622-1996 压配式实心轮胎系列 Series of pressed-on solid tyres
332 GB/T 16623-1996 压配式实心轮胎 Pressed-on solid tyres
333 GB/T 7377-1997 力车轮胎系列 Series of cycle tyres
334 GB 9743-1997 轿车轮胎 Passenger car tyres
335 GB 9744-1997 载重汽车轮胎 Truck tyres
336 GB 7036.1-1997 充气轮胎内胎 第1部分: 汽车轮胎内胎 Inner tube of pneumatic tyres Part 1: Inner tube of automobile tyres
337 GB 7036.2-1997 充气轮胎内胎 第2部分: 摩托车轮胎内胎 Inner tube of pneumatic tyres--Part 2: Inner tube of motorcycle tyres
338 GB/T 2978-1997 轿车轮胎系列 Series of passenger car tyres
339 GB/T 2977-1997 载重汽车轮胎系列 Series of truck tyres
340 GB/T 1702-1997 力车轮胎 Cycle tyres
341 GB/T 1703-1997 力车内胎 Cycle inner tubes
342 GB/T 3780.15-1997 橡胶用炭黑甲苯抽出物透光率的测定 快速法 Carbon black for use in the rubber industry--Determination of light transmittance of toluene extract--Rapid method
343 GB/T 3780.20-1997 橡胶用炭黑甲苯抽出物透光率的测定 产品鉴定方法 Carbon black for use in the rubber industry--Determination of light transmittance of toluene extract--Method for product evaluation
344 GB/T 16996-1997 硫化橡胶暴露于自然气候或人工光后性能变化的评定 Rubber,vulcanized--Assessment of changes in properties after exposure to natural weathering or artificial light
345 GB/T 6039-1997 橡胶物理试验和化学试验术语 Rubber physical tests and chemical tests--Terms
346 GB/T 9869-1997 橡胶胶料硫化特性的测定(圆盘振荡硫化仪法) Rubber--Measurement of vulcanization characteristics with the oscillating disc curemeter
347 GB/T 4499-1997 硫化橡胶中防老化剂的测定 薄层色谱法 Vulcanized rubber--Determination of antidegradant content-Thin layer chromatographic method
348 GB/T 532-1997 硫化橡胶或热塑性橡胶与织物粘合强度的测定 Rubber,vulcanized or thermoplastic--Determination of adhesion to textile fabric
349 GB 9764-1997 轮胎气门嘴芯腔 Tyre valves--Core chambers
350 GB 9765-1997 轮胎气门嘴螺纹 Tyre valve threads
351 GB/T 9762-1997 力车轮胎耐久性能试验方法(转鼓法) Endurance test for cycle tyres (Drum method)
352 GB/T 9763-1997 力车轮胎脱圈水压试验方法 Unseat by water pressure testing method for cycle tyres
353 GB/T 9749-1997 力车轮胎强度性能试验方法 Strength performance testing method for cycle tyres
354 GB/T 17042-1997 航空轮胎胎圈耐高温试验方法 Test method of resisting high temperature for bead base of aircraft tyre
355 GB/T 17043-1997 航空轮胎环境温度试验方法 Test method of environmental temperature for aircraft tyre
356 GB/T 17044-1997 钢丝绳芯输送带覆盖层与带芯层粘合强度试验方法 Steel cord conveyor belts--Adhesion strength test of the cover to the core layer
357 GB/T 6737-1997 生橡胶 挥发分含量的测定 Rubber,raw--Determination of volatile-matter Content
358 GB/T 4498-1997 橡胶 灰分的测定 Rubber--Determination of ash
359 GB/T 2983-1997 摩托车轮胎系列 Series of motorcycle tyres
360 GB/T 12839-1997 轮胎气门嘴 术语及其定义 Tyre valves--Terms and definitions
361 GB/T 3900-1997 轮胎气门嘴系列 Tyre valve series
362 GB/T 11544-1997 普通V带和窄V带尺寸 Classical and narrow V-belts--Dimensions
363 GB/T 7986-1997 输送带滚筒摩擦试验方法 Conveyor belts--Drum friction--Method of test
364 GB/T 518-1997 摩托车轮胎 Motorcycle tyres
365 GB 13552-1998 汽车多楔带 Automotive V-ribbed belts
366 GB 13651-1998 翻新航空轮胎 Retreaded aircraft tyre
367 GB/T 11193-1998 航空轮胎外缘尺寸测量方法 Method of mesuring pneumatic ircraft tyre peripheral dimensions
368 GB/T 4502-1998 轿车轮胎耐久性试验方法 转鼓法 Endurance test for passenger car tyres Drum method
369 GB/T 7034-1998 轿车轮胎高速性能试验方法 转鼓法 High speed test for passenger car tyres Drum method
370 GB/T 4504-1998 轿车无内胎轮胎脱圈阻力试验方法 Bead unseating resistance test for tubeless passenger car tyres
371 GB/T 4501-1998 戴重汽车轮胎耐久性试验方法 转鼓法 Endurance test for truck and bus tyres Drum method
372 GB/T 3686-1998 V带拉伸强度和伸长率试验方法 V-btlts--Tensile strength and elongation test method
373 GB/T 3688-1998 V带线绳粘合强度试验方法 V-belt--Cord adhesion test method
374 GB/T 17516.1-1998 V带和多楔带传动 测定节面位置的动态试验方法 第1部分: V带 V-and ribbed belt drives--Dynamic test to determine pitch zone location--Part 1: V-belts
375 GB/T 17516.2-1998 V带和多楔带传动 测定节面位置的动态试验方法 第2部分: 多楔带 V-and ribbed belt drives--Dynamic test to determine pitch zone location--Part 2: V-ribbed belts
376 GB/T 11195-1998 航空有内胎轮胎胎圈密合压力试验方法 Bead fit test method for tube aircraft tyre
377 GB/T 6031-1998 硫化橡胶或热塑性橡胶硬度的测定(10~100IRHD) Rubber,Vulcanized or thermoplastic--Determination of hardness (hardness between 10 IRHD and 100IRHD)
378 GB/T 528-1998 硫化橡胶或热塑性橡胶拉伸应力应变性能的测定 Rubber,vulcanized or thermoplastic-Determination of tensile stress-strain properties
379 GB/T 9872-1998 氧瓶燃烧法测定橡胶和橡胶制品中溴和氯的含量 Rubber and rubber products-Determination of bromine and chlorine content-Oxygen flask combustion technique
380 GB/T 17531-1998 橡胶与橡胶制品 化学试验方法准确度和偏差的确定 Rubber and rubber products--Determination of accuracy and bias of Chemical test methods
381 GB/T 7530-1998 橡胶或塑料涂覆织物 术语 Rubber-or plastics-coated fabrics-Glossary of terms
382 GB/T 3780.6-1998 橡胶用炭黑着色强度试验方法 Carbon black used in rubber products--Tinting strength test method
383 GB/T 3780.18-1998 炭黑在天然橡胶中配方及鉴定方法 Carbon black in natural rubber--Recipe and evaluation method
384 GB/T 9579-1998 炭黑在丁苯橡胶中配方及鉴定方法 Carbon black in SBR(Styrene-butadiene rubber)-Recipe and evaluation method
385 GB/T 3780.1-1998 橡胶用炭黑吸碘值试验方法 Carbon black used in rubber products--Test method for iodine adsorption number
386 GB/T 17604-1998 橡胶 管道接口用密封圈制造质量的建议 疵点分类与类别 Rubber--Recommendations for the workmanship of pipe joint rings--Description and classification of imperfections |
