- 1801
- 80
- 2009-8-14
发表于 2011-2-22 23:20:43
|Error|
显示全部楼层
. 安装步骤Installation procedure
5 r# f4 \! ~7 ~$ F; S9 K (*摇臂基础预埋组件安装步骤请参照第Ⅲ节.)* M6 t5 f* E+ m# Q2 \- I
序号. 内容 备注" H5 g4 [+ V; u* {( s) n
1. 预埋组件的固定 6 z" a) D* D, O2 u; n
1) 在灌浆前,将预埋组件(01,02和03) 的位置按照图纸固定.
j7 Z& ?4 A, f6 h2 v2) 具体步骤请参照“预埋组件的安装步骤”。
' A4 u" Z O& G" A" X5 d
7 {3 x) `8 d# c, e7 e' o2. 基础位置的标记和确认
, _) ?( a: z# ^# O; ?9 R1) 在混凝土基础上根据预埋组件的中心标出立磨以及主电机中心线.
* B! p! ]# g2 c2 J8 C+ F C0 N3 k# w+ s2) Mark the positions of foundation bolts and erection liners.标出地脚螺栓的位置以及安装垫铁的位置 , g( U6 I# I# m; {% H7 ~; N
3) Check the height of each foundation using Y-level and steel scale, basing on the bench mark by Civil.根据土建基准点用经纬仪及钢尺检查每个基础的标高
7 x3 k# N! ~5 D/ y8 |& v2 Q6 r2 X4) At the same time, check the depth of foundation bolt holes. If the depth is too short, consult with the civil engineer to repair. 同时,检查地脚螺栓孔的深度,如果深度不够,需要与土建联系处理。 请参考 ME1VM0031 & 0032- i# @, }3 m% s0 f+ ]$ X8 z3 @
6 E/ B, s+ W9 J
3. 安装垫铁Installation of Erection liners Refer to drawing No. ME1VM7200.
% L: a. k: @- n* W. j$ R1) Chip off the concrete surface for the liner positions.将安装垫铁的混凝土面凿毛; 8 M: ]7 U4 F& L$ H
2) Place non-shrink mortar on the chipped surface.灌入无收缩砂浆
) w; W: V- k. N# u8 n" T: y- }3) Set base plates of erection liners on the non-shrink mortar.将垫铁垫板固定在砂浆墩上 # O% J* G: Y% V' Q% V* C( B
4) The height and level of each base plate shall be strictly adjusted using a Y-level, steel scale and spirit level.垫铁垫板的高度要用经纬仪、钢尺以及水准仪调整;0 O0 P* e1 v+ O: s# V) o8 S2 q
Height difference of base plates within one base frame同一底座的不同垫板之间的高差* F2 m/ [2 k# J* P+ R4 ~# K
Level of each base plate不同底座的标高
" ?5 f8 k$ _' U( s3 Y2 K! p# J/ G& Z2 ^( c; w6 Q+ R2 L
≦1mm
% V* q% B' h6 Z/ c7 q2 J≦0.1mm/M
" y& `( G/ r* M1 H0 L* h A' D4) After curing, put taper liners on the base plates.砂浆墩养护好后,安装斜垫铁。、! v- s% D. E$ P* k( W, `: e
内容 Q+ | o. K, J7 r
4.减速机底座、电机底座以及液压缸底座的安装 Installation of Base frame for Reducer, Motor base and cylinder base3 h3 M/ ^' ]7 n! K$ ~3 [+ {* \ z
将减速机底座(MEIVM1201)、电机底座(ME1VM3201)以及液压缸底座(ME1VM1231)在斜垫铁上固定好Set the base frames for mill reducer (ME1VM1201) and the motor base (ME1VM3201) and the cylinder base (ME1VM1231) on the erection liners." \$ ~0 N, f. g
各底座的平面位置及标高必须严格按照图纸进行最大程度的调整The plane position of base frame shall be strictly adjusted and its height position shall be approximately adjusted..6 T" B* u3 z' E# F! R
在地脚螺栓孔内灌入无收缩砂浆Place the non-shrink mortar into the anchor bolt holes.6 e/ X% ^( I% ]" u. J& k
底座的标高及水平度必须用经纬仪、钢尺以及水准仪严格按照图纸验收。The height and level of base frame shall be strictly adjusted using a Y-level, steel scale and spirit level. * k# ?+ x/ [- J6 i7 A+ i' d+ F4 c
Height of base frame高度
# {' y" J/ f4 [$ ~* s+ DLevel of base plate平面度 |
