- 3875
- 80
- 2007-1-28
一、设置打印机
开始/程序/ugnx2/unigraphics tools/pqmgr;
Connecting to Plot Queuing System at Node: lcy ... Connected.
Plot Queue Manager 1.0.0.21
Enter Command or "help"
PQM_lcy-*>qmod ljet3
Accept Defaults With A Carriage Return
Enter Queue Name (16 Char. Max.)
Default = LJET3
Enter Despooler Name (8 Char. Max.)
Default = UGIIHP
Enter Plotter Vendor (16 Char. Max.)
Default = HEWLETT-PACKARD
Enter Plotter Type (E=Electrostatic; P=Pen)
Default = E
Enter Plotter Model (16 Char. Max.)
Default = 7600
Enter Plotter Switches (132 Char. Max.)
Default = /2/LJ/SP=MW/AR
Enter Media Control (C=Continuous; N=Non-Continuous)
Default = C
Enter Distance Between Plots
Default = 0
1 = Direct
2 = System Queue
3 = Disk File
4 = Both Direct And File
5 = Both Queue And File
Enter Output Mode
Default = 2
3 &&此处选3,保存到磁盘
Enter Directory Pathname (132 Char. Max.)
Default =
e:\plot &&此处指定保存路径和文件夹
Enter Message Com Line (16 Char. Max.)
Default =
Enter Steps Per Inch
Default = 1016
LJET3
Despooler Name = UGIIHP
Plotter Vendor = HEWLETT-PACKARD
Plotter Type = Electrostatic
Number Of Pens = 16
Controller ID =
Plotter Model = 7600
Plotter Switches = /2/LJ/SP=MW/AR
Media Control = Continuous Form
Distance Between Plots = 0
Output Mode = Disk File
Plotter Com Line =
System Queue Name = \\MYNODE\LJET3_QUEUE
Directory Pathname = E:\PLOT
Tape Density = 1600
Message Interval =
Message Com Line =
Horizontal Maximum = 0
Vertical Maximum = 0
Steps Per Inch = 1016
Optimization Level = None
PQM_lcy-*>Start ljet3 启动打印机
PQM_lcy-*>Bye 退出打印设置
二、生成hpp打印文件
1、 打开图纸
2、 File - plot…
3、 Plot Quenes on Node 选 Ljet3
4、 Build plot file
三、打印文件
用ViewCompanion软件打开E:\PLOT\的hpp文件,即可打印 |
