查看: 969|回复: 1
[已解决] LISPZHUAN
发表于 2010-5-24 12:49:50 |Error| 显示全部楼层 |阅读模式
图纸
图纸名称: LISP程序
图号:
文件格式: DWG (AUTO CAD)
附件贴图: -
有没有动态延长直线的LISP程序呢
发表于 2015-3-16 22:54:34 |Error| 显示全部楼层
  1. (defun c:ff ( / ka01 pt1 KENT KENTLIST karc knea ka1 ka2 ka3 ka4 klj pt11 )
  2.    (setq ka01 (entsel "请选择直线或圆弧:"))(if ka01
  3. (progn(setq  KENT (car ka01))(setq KENTLIST (entget KENT))
  4. (if(not(or(eq "ARC" (cdr(assoc 0 KENTLIST)))(eq "LINE" (cdr(assoc 0 KENTLIST)))))
  5.      (princ "\n您选择的不是直线或圆弧!")        (progn(princ "\n按右键显示路径.")
  6.    (setq pt1 (cadr ka01))(setq  KENT (car ka01))(setq KENTLIST (entget KENT))
  7.    (if (eq "ARC" (cdr(assoc 0 KENTLIST)))(setq karc t)(setq karc nil))
  8.    (setq ka1 (vlax-ename->vla-object KENT))
  9.    (if (<(distance pt1 (vlax-curve-getStartPoint ka1))(distance pt1
  10.          (vlax-curve-getEndPoint ka1)))(setq knea t)(setq knea nil))
  11.    (while ka1
  12.      (setq ka2 (grread t 12 2) ka3 (car ka2)  ka4 (cadr ka2))
  13.       (if (= ka3 25)(if klj(setq klj nil)(setq klj t)))
  14.      (cond ((= ka3 5)
  15.             (progn (setq pt11 (vlax-curve-getClosestPointTo ka1 ka4 t))
  16.     (if(not karc)(if knea
  17.                    (if (> (distance pt11 (vlax-curve-getEndPoint ka1)) 0.1)
  18.                    (vla-put-StartPoint ka1 (vlax-3d-point pt11)))
  19.                    (if(> (distance pt11 (vlax-curve-getStartPoint ka1)) 0.1)
  20.            (vla-put-EndPoint ka1 (vlax-3d-point pt11)))
  21.                    )
  22.          (if knea(vlax-put-property ka1 'StartAngle (angle (cdr(assoc 10 KENTLIST))pt11))
  23.             (vlax-put-property ka1 'EndAngle (angle (cdr(assoc 10 KENTLIST))pt11))))
  24.                        (if klj (progn(redraw)(grdraw ka4 pt11 2 4)))
  25.                        )
  26.             )
  27.            ((= ka3 3)(setq ka1 nil))
  28.            ;((= ka3 25)(princ ka3)(princ ka4))
  29.            ;(t (princ ka2)(princ "  "))
  30.            ;(t (princ ka3)(princ ",")(princ ka4)(princ " "))
  31.            )) )) )) (redraw) (princ)
  32.      )
复制代码
GMT+8, 2026-11-1 18:43 , Processed in 0.278085 second(s), 26 queries .
