Scenario:Below are some 2D parts from a machinery company.
The firm’s part as axial surface roughness
does not meet requirements,
or the form of marked and tolerance are inaccurate, and so on.
Update the modified blocks and
he form of marked load into drawing.
Part 1:
Load a drawing file source from a machinery company, including IGES and DXF files,
which a learner should understand and edit.
Part 2:
The machine's long use of some mechanical parts, surface roughness and some size can not meet the requirements, the need for improved and the size of re-labeling.
Part 3:
Components need to be modified to re-size and surface roughness on record, compared to the original data for analysis and processing machinery factory in the future.
Required:Task 1 is part 1. Task 2 is part 2. Task 3.4 make up part 3.For task 4 you should produce and print report and drawing to show your data. Besides, for the other tasks and questions, you should give your answers using a total formal report, including all the points covering the issues described.
