查看: 4051|回复: 3
[资料手册] 关于多重插入块--怎么分解
发表于 2010-4-27 13:23:14 |Error| 显示全部楼层 |阅读模式
1、先在图层管理器里将锁定图层打开
2、选中该“多重插入块”,在其属性里将行、列均改为“1"
3、将下段保存为"exm.lsp"     (DEFUN C:exm () (setvar "cmdecho" 0) (SETQ STM (car (ENTSEL "\n点取多重块"))) (while stm (setq e (entget stm)) (setq stlx (cdr (assoc 0 e))) (if (= stlx "INSERT") (PROGN (setq r_zm70 (assoc 70 e)) (setq c_zm71 (assoc 71 e)) (setq r_dist_zm44 (assoc 44 e)) (setq c_dist_zm45 (assoc 45 e)) (setq e (subst (cons 44 0) r_dist_zm44 e)) (setq e (subst (cons 45 0) c_dist_zm45 e)) (setq e (subst (cons 70 0) r_zm70 e)) (setq e (subst (cons 71 0) c_zm71 e)) (setq e (subst (list 100 "AcDbBlockReference") (list 100 "AcDbMInsertBlock") e)) (entmake e) (entdel stm) )) (SETQ STM (car (ENTSEL "\n点取下一多重块"))) ) (setvar "cmdecho" 1) )
4、在打开了含有多重插入块的图形文件里加载“exm.lsp”,运行“exm”根据提示选中多重插入块
5、运行“explode”就可以将 多重插入块分解,修改了。
注:该程序引用自网易暖通huawencai大侠 版权归其所有。
发表于 2010-5-4 10:56:36 |Error| 显示全部楼层
支持楼住~谢谢分享!!!!
发表于 2011-1-26 15:23:29 |Error| 显示全部楼层
很有用,很强大,我试过了,这个方法可行:victory:
发表于 2011-8-12 20:57:34 |Error| 显示全部楼层
怎么搞完后用explode一炸图形就不见了,请楼主指教指教啊,多谢!
GMT+8, 2026-11-1 07:25 , Processed in 0.243557 second(s), 23 queries .
