- 180
- 30
- 2007-4-9
轴承 bearing
螺母 nut
机械 machine
垫圈 washer
工程师 engineer
摩擦 friction
传动 drive/transmission
轴 shaft
电路 circuit
变速箱 gearbox
离合器 clutch
螺钉 screw
功率 power
工件 workpiece
基准 benchmark
锻 forge
焊 weld
装配 assembling
铸造 found
螺纹 thread
螺旋 helix
键 spline
销 pin
滚动轴承 rolling bearing
滑动轴承 sliding bearing
弹簧 spring
十字结联轴节 crosshead
联轴器 coupling
链 chain
皮带 strap
电动机 electromotor
丝杠 screw rod
导轨 lead rail
车间 workshop
机械制图 Mechanical drawing
投影 projection
视图 view
剖视图 profile chart
标准件 standard parts
零件图 part drawing
装配图 assembly drawing
尺寸标注 size marking
技术要求 technical requirements
截面 section
垫圈 washer
垫片 spacer
齿轮 gear
齿轮齿条 pinion and rack
蜗杆蜗轮 worm and worm gear
凸轮 cams
毛坯 rough
定位销 stop pin
半径 radius
展开图 expansion dwg
说明 notes
拉钉枪 Rivet gun
布置图 Layout
输送机 conveyer
提升机 elevator
螺旋输送机 screw conveyer
方垫圈 square washer
圆锥销 taper pins
圆柱销 parallel pins
单耳止动垫圈 tab washers
开口销 split cotter pins
平垫 plain washers
平垫(带倒角) mediun washers
平垫 plain washers
标准弹垫 spring lock washers,square ends
T型头螺栓 T-head bolts
外舌止动垫圈 external tap
小垫圈(用于圆柱头螺钉) washers for cheese head screws
方斜垫圈(U型) square taper washers for U-section
方斜垫圈(I型) square taper washers for I-sections
方垫圈 square washers
六角薄螺母 hexagon thin nuts
活节螺栓B 型 eye bolts form B
内舌止动垫圈 internal tab washers
双耳止动垫圈 washers with two taps
锁紧垫圈 sealing washers
轴用弹性挡圈 retaining rings for shafts(external),circlips
孔用弹性挡圈 retaining rings for bores(internal),circlips
单头螺柱 single end studs
地脚螺栓 masonry bolts
带槽圆螺母 slotted round nuts
端面带孔圆螺母 round nuts with drilled holes in one face
开槽平端紧定螺钉 slotted sit screws with flat point
开槽锥端紧定螺钉 slotted set screws with cone point
六角螺母 hexagon nuts
方螺母-C square nuts
六角头螺钉 hexagon screws
六角头圆柱端紧定螺钉 hexagon set screws with full dog point
薄型方螺母-B square nuts without bevel(pressed nuts)
六角头木螺钉 hexagon head wood screws (coach screws)
吊环螺钉 lifting eye bolts
吊环螺母 lifting eye nuts
六角头螺栓 hexagon bolts
大半圆头方颈螺栓(马车螺栓) mushroom head square neck bolts (carriage bolts)
沉头带插销马车螺栓 flat countersunk nib bolts
沉头长方颈马车螺栓 flat countersunk long square neck bolts
半圆头带插销马车螺栓 cup head nib bolts
沉头短方颈马车螺栓 flat countersunk short square neck bolts
六角头精配螺栓(长螺纹) hexagon fitted bolts,long thread
六角头精配螺栓(短螺纹) hexagon fitted bolts,short thread
滚花平头螺钉 knurled thumb screws thin type
半圆头铆钉 round head rivets
沉头铆钉 contersunk head rivets
半沉头铆钉 raised contersunk head rivets
大扁头铆钉 mushroom head rivets
重型侧面带孔圆螺母 adjusting rings,heavy range (shafting collars)
侧面带孔圆螺母 adjusting rings,light range (shafting collars)
卡头 wire rope clips
T型槽螺钉 T-slot screws
双头螺柱(牙长=2D) studs-metal (end=2d)
内六角锥型闭锁螺钉 hexagon socket pipe plugs,conical thread
内六角直型闭锁螺钉 hexagon socket screw plugs,cyl. thread
外六角锥型闭锁螺钉 hexagon head pipe plugs,conical thread
外六角直型闭锁螺钉 hexagon head screw plugs,cyl.thread
内六角扳手 socket wrenches
内六角圆柱头螺钉 hexagon socket cap screws
内六角平端紧定螺钉 hexagon socket set screws with flat point
内六角尖端紧定螺钉 hexagon socket set screws with cone point
内六角圆柱端紧定螺钉 hexagon socket set screws with dog point
内六角凹端紧定螺钉 hexagon socket set screws with cup point
薄型盲螺母 hexagon cap nuts
开槽小圆柱头螺钉 slotted short cheese head screws
开槽大圆柱头螺钉 slotted large cheese head screws
开槽圆柱头轴肩螺钉 slotted pan head screws with shoulder
开槽无头轴肩螺钉 slotted shoulder screws
焊接方螺母 square weld nuts
焊接六角螺母 hexagon weld nuts
六角头螺栓(半牙) hexagon head screws
六角头螺栓(全牙) hexagon head screws
六角头螺母(1型) hexagon full nuts
细牙六角头螺母(1型) hexagon full nuts
开槽六角螺母 hexagon slotted and castle nuts
六角头薄螺母 hexagon thin nuts
六角头开槽薄螺母 hexagon thin slotted and castle nuts
双头螺距(牙长=1D) studs metal (end=1d)
双头螺距(牙长=1.25D) studs metal (end=1.25d)
双头螺距(牙长=1.5D) studs metal (end=1.5d)
六角头细牙螺栓(半牙) hexagon head bolts,metric fine pitch thread
六角头细牙螺栓(全牙) hexagon head bolts,metric fine pitch thread
头部穿孔六角头螺栓 additional shapes and versions for bolts
开槽沉头螺钉 slotted countersund head screws
开槽半沉头螺钉 slotted raised countersunk oval head screws
十字槽沉头螺钉 cross recessed countersunk head screws
十字槽半沉头螺钉 cross recessed raised countersunk head screws
六角头螺母 hexagon nuts type-1
六角头螺母 hexagon nuts type-2
细牙六角头螺母(2型) hexagon nuts with fine thread
牙条(全螺纹) threaded rods(studdings)
螺纹销 threaded pins(stud bolts)
六角头开槽薄螺母(2型) hexagon thin slotted and castle nuts
全金属六角锁紧螺母(1型) prevailling torque type hexagon nuts,all metall
nuts
圆螺母 locknuts
六角头尼龙锁紧螺母 prevailling torque type hexagon nuts,heavy type ,with
nylon insert
六角头薄型尼龙锁紧螺母 prevailling torque type hexagon nuts,heavy type
,with nylon insert ISO10511
六角盖型尼龙锁紧螺母 prevailling torque typedomed capnuts with nylon
insert
配合垫片 shim rings
木材连接用垫片 washers for timber connectors
沉头钢钉 round plain head nails
销钉专用垫片A型 plain washers for clevis pins(A型)
销钉专用垫片 plain washers for clevis pins
带头销钉 clevis pins with head
圆锥型槽销 grooved pins,taper grooved
圆锥型槽销(半槽) grooved pins,taper grooved half length
平行槽销(带倒角) grooved pins,parallel grooved full length
前端凹槽槽销 grooved pins,reserve grooved half length
中部凹槽槽销 grooved pins,centre grooved
圆头槽销 grooved pins with round head
沉头槽销 grooved pins with countersunk head
六角螺母棒 turnuckles(centre parts),made out of hexagon bar
花篮螺栓 turnuckles with eye bolt and hook bolt
弹性圆柱销 spring pins,heavy type
组合式盖型螺母 hexagon domed cap nuts
开槽圆螺母(配合沟头扳手) slotted round nuts for hook spanner
圆螺母(带插销孔) round nuts with set holes
盘型弹簧垫圈 disc springs
喉箍 hose clamps
润滑油嘴(旋扭头) lubricating nipples,button head
管夹 shackles for conduilts
U型螺栓 stirrup bolts(U-bolts)
球面垫圈 spherical washers,conical seats
圆柱销 parallel pins
厚六角螺母 hexagon nuts ,1.5d
厚六角法兰面螺母 hexagon nuts ,1.5d with collar
长六角螺母 hexagon nuts ,3d
外齿锁紧垫圈 external teeth lock washers
内齿锁紧垫圈 internal teeth lock washers
外锯齿锁紧垫圈 external teeth serrated lock washers
内锯齿锁紧垫圈 internal teeth serrated lock washers
开口挡圈 retaining rings for shafts(E-rings),circlips
平键(A型) parallel keys(form A )
半圆键 woodruff keys
嵌环(支撑环) thimbles
机器螺钉和垫圈组合件 screws and washers assemblies
自攻螺钉和垫圈组合件 tapping screws and washers assemblies
薄型带孔内六角圆柱头螺钉 hexagon socket head cap screws with hole,low head
大六角头螺栓 hexagon head bolts with large head(friction grip bolts)
大六角螺母 hexagon nuts with large wideth across flat(friction grip nuts)
大垫圈 round washers for friction grip bolts
楔型方垫圈 spuare taper washers for friction grip bolts on T-sections
六角法兰面螺母 hexagon flange nuts
全金属六角锁紧螺母(2型) prevailing torque type hexagon nuts,all metallic nuts
开口型抽芯铆钉(沉头、扁圆头) blind rivets
扁平头半空心/全空心铆钉 rivets for brake and clutch lining
螺旋夹紧销 spiral pins
轻型弹性圆柱销 spring pins,light type
重型弹性圆柱销用垫圈 washers for bolts with heavy type spring pinss
公制螺纹螺钉(多种头型) threadforming screws for ISO-metric thread
自攻自钻螺钉(多种头型) self-drilling tapping screws
开槽切削螺纹螺钉(多种头型) thread cutting screws
十字槽切削螺纹螺钉(多种头型) thread cutting screws cross recess
T型四爪螺母 tee nuts with pronge
钢结构用六角头螺栓连接副 hexagon head fitted bolts for steel structures
圆螺母用止退垫圈 tab washers for slotted round nuts
