- 542
- 70
- 2007-12-12
椭圆受内压作用模型计算错误求教!2010-3-10
Pi=0.8MPa,Di=2000,厚度10,椭圆型封头,封头上端施加轴向平衡面载荷,封头中间线上施加x方向的约束,内表面施加压力载荷.。
计算后显示Error:
The value of UY at node 614 is 1121429.85. It is greater than the
current limit of 1000000. This generally indicates rigid body motion
as a result of an unconstrained model. Verify that your model is
properly constrained.
说我的约束有问题,我的约束如图1所示。
然后,我将封头中间线上施加x、y方向的约束, 其余设置相同,却可以计算,如图2。希望高手指教此处封头中间线上约束的施加等问题!谢谢! |
