查看: 4559|回复: 6
[文章] 塑料缩写 代码 大全
发表于 2007-4-4 19:30:42 |Error| 显示全部楼层 |阅读模式
ABA          Acrylonitrile-butadiene-acrylate 丙烯腈/丁二烯/丙烯酸酯共聚物
ABS          Acrylonitrile-butadiene-styrene 丙烯腈/丁二烯/苯乙烯共聚物
AES          Acrylonitrile-ethylene-styrene 丙烯腈/乙烯/苯乙烯共聚物
AMMA          Acrylonitrile/methyl Methacrylate 丙烯腈/甲基丙烯酸甲酯共聚物
ARP          Aromatic polyester 聚芳香酯
AS          Acrylonitrile-styrene resin 丙烯腈-苯乙烯树脂
ASA          Acrylonitrile-styrene-acrylate 丙烯腈/苯乙烯/丙烯酸酯共聚物
CA          Cellulose acetate 醋酸纤维塑料
CAB          Cellulose acetate butyrate 醋酸-丁酸纤维素塑料
CAP          Cellulose acetate propionate 醋酸-丙酸纤维素
CE          Cellulose plastics, general" 通用纤维素塑料
CF          Cresol-formaldehyde 甲酚-甲醛树脂
CMC          Carboxymethyl cellulose 羧甲基纤维素
CN          Cellulose nitrate 硝酸纤维素
CP          Cellulose propionate 丙酸纤维素
CPE        Chlorinated polyethylene 氯化聚乙烯
CPVC      Chlorinated poly(vinyl chloride) 氯化聚氯乙烯
CS          Casein 酪蛋白
CTA        Cellulose triacetate 三醋酸纤维素
EC          Ethyl cellulose 乙烷纤维素
EEA        Ethylene/ethyl acrylate 乙烯/丙烯酸乙酯共聚物
EMA        Ethylene/methacrylic acid 乙烯/甲基丙烯酸共聚物
EP          "Epoxy, epoxide" 环氧树脂
EPD         Ethylene-propylene-diene 乙烯-丙烯-二烯三元共聚物
EPM         Ethylene-propylene polymer 乙烯-丙烯共聚物
EPS         Expanded polystyrene 发泡聚苯乙烯
ETFE        Ethylene-tetrafluoroethylene 乙烯-四氟乙烯共聚物
EVA         Ethylene/vinyl acetate 乙烯-醋酸乙烯共聚物
EVAL      Ethylene-vinyl alcohol 乙烯-乙烯醇共聚物
FEP        Perfluoro(ethylene-propylene) 全氟(乙烯-丙烯)塑料
FF          Furan formaldehyde 呋喃甲醛
HDPE     High-density polyethylene plastics 高密度聚乙烯塑料
HIPS      High impact polystyrene 高冲聚苯乙烯
IPS        Impact-resistant polystyre ne 耐冲击聚苯乙烯
LCP        Liquid crystal polymer 液晶聚合物
LDPE      Low-density polyethylene plastics 低密度聚乙烯塑料
LLDPE     Linear low-density polyethylene 线性低密聚乙烯
LMDPE    Linear medium-density polyethylene 线性中密聚乙烯
MBS       Methacrylate-butadiene-styrene 甲基丙烯酸-丁二烯-苯乙烯共聚物
MC         Methyl cellulose 甲基纤维素
MDPE      Medium-density polyethylene 中密聚乙烯
MF         Melamine-formaldehyde resin 密胺-甲醛树脂
MPF       Melamine/phenol-formaldehyde 密胺/酚醛树脂
PA          Polyamide (nylon) 聚酰胺(尼龙)
PAA       Poly(acrylic acid) 聚丙烯酸
PADC      Poly(allyl diglycol carbonate) 碳酸-二乙二醇酯· 烯丙醇酯树脂
PAE        Polyarylether 聚芳醚
PAEK      Polyaryletherketone 聚芳醚酮
PAI        Polyamide-imide 聚酰胺-酰亚胺
PAK        Polyester alkyd 聚酯树脂
PAN       Polyacrylonitrile 聚丙烯腈
PARA      Polyaryl amide 聚芳酰胺
PASU      Polyarylsulfone 聚芳砜
PAT        Polyarylate 聚芳酯
PAUR      Poly(ester urethane) 聚酯型聚氨酯
PB          Polybutene-1 聚丁烯-[1]
PBA        Poly(butyl acrylate) 聚丙烯酸丁酯
PBAN      Polybutadiene-acrylonitrile 聚丁二烯-丙烯腈
PBS        Polybutadiene-styrene 聚丁二烯-苯乙烯
PBT       Poly(butylene terephthalate) 聚对苯二酸丁二酯
PC         Polycarbonate 聚碳酸酯
PCTFE    Polychlorotrifluoroethylene 聚氯三氟乙烯
PDAP     Poly(diallyl phthalate) 聚对苯二甲酸二烯丙酯
PE         Polyethylene 聚乙烯
PEBA     Polyether block amide 聚醚嵌段酰胺
PEBA     Thermoplastic elastomer polyether 聚酯热塑弹性体
PEEK     Polyetheretherketone 聚醚醚酮
PEI       Poly(etherimide) 聚醚酰亚胺
PEK       Polyether ketone 聚醚酮
PEO      Poly(ethylene oxide) 聚环氧乙烷
PES      Poly(ether sulfone) 聚醚砜
PET      Poly(ethylene terephthalate) 聚对苯二甲酸乙二酯
PETG     Poly(ethylene terephthalate) glycol 二醇类改性PET
PEUR      Poly(ether urethane) 聚醚型聚氨酯
PF          Phenol-formaldehyde resin 酚醛树脂
PFA        Perfluoro(alkoxy alkane) 全氟烷氧基树脂
PFF        Phenol-furfural resin 酚呋喃树脂
PI          Polyimide 聚酰亚胺
PIB        Polyisobutylene 聚异丁烯
PISU      Polyimidesulfone 聚酰亚胺砜
PMCA     Poly(methyl-alpha-chloroacrylate) 聚α-氯代丙烯酸甲酯
PMMA     Poly(methyl methacrylate) 聚甲基丙烯酸甲酯
PMP       Poly(4-methylpentene-1) 聚4-甲基戊烯-1
PMS       Poly(alpha-methylstyrene) 聚α-甲基苯乙烯
POM      Polyoxymethylene, polyacetal" 聚甲醛
PP         Polypropylene 聚丙烯
PPA       Polyphthalamide 聚邻苯二甲酰胺
PPE       Poly(phenylene ether) 聚苯醚
PPO       Poly(phenylene oxide) deprecated 聚苯醚
PPOX     Poly(propylene oxide) 聚环氧(丙)烷
PPS       Poly(phenylene sulfide) 聚苯硫 醚
PPSU      Poly(phenylene sulfone) 聚苯砜
PS         Polystyrene 聚苯乙烯
PSU       Polysulfone 聚砜
PTFE      Polytetrafluoroethylene 聚四氟乙烯
PUR        Polyurethane 聚氨酯
PVAC      Poly(vinyl acetate) 聚醋酸乙烯
PVAL      Poly(vinyl alcohol) 聚乙烯醇
PVB         Poly(vinyl butyral) 聚乙烯醇缩丁醛
PVC        Poly(vinyl chloride) 聚氯乙烯
PVCA     Poly(vinyl chloride-acetate) 聚氯乙烯醋酸乙烯酯
PVCC     chlorinated poly(vinyl chloride)(*CPVC) 氯化聚氯乙烯
PVI       poly(vinyl isobutyl ether) 聚(乙烯基异丁基醚)
PVM     poly(vinyl chloride vinyl methyl ether) 聚(氯乙烯-甲基乙烯基醚)
RAM     restricted area molding 窄面模塑
RF        resorcinol-formaldehyde resin 甲苯二酚-甲醛树脂
RIM      reaction injection molding 反应注射模塑
RP        reinforced plastics 增强塑料
RRIM     reinforced reaction injection molding 增强反应注射模塑
RTP      reinforced thermoplastics 增强热塑性塑料
S/AN     styrene-acryonitrile copolymer 苯乙烯-丙烯腈共聚物
SBS       styrene-butadiene block copolymer 苯乙烯-丁二烯嵌段共聚物
SI          silicone 聚硅氧烷
SMC       sheet molding compound 片状模塑料
S/MS      styrene-α-methylstyrene copolymer 苯乙烯-α-甲基苯乙烯共聚物
TMC       thick molding compound 厚片模塑料
TPE         thermoplastic elastomer 热塑性弹性体
TPS         toughened polystyrene 韧性聚苯乙烯
TPU         thermoplastic urethanes 热塑性聚氨酯
TPX          ploymethylpentene 聚-4-甲基-1戊烯
VG/E        vinylchloride-ethylene copolymer 聚乙烯-乙烯共聚物
VC/E/MA   vinylchloride-ethylene-methylacrylate copolymer 聚乙烯-乙烯-丙烯酸甲酯共 聚物
VC/E/VCA  vinylchloride-ethylene-vinylacetate copolymer 氯乙烯-乙烯-醋酸乙烯酯共 聚物
PVDC         Poly(vinylidene chloride) 聚(偏二氯乙烯)
PVDF         Poly(vinylidene fluoride) 聚(偏二氟乙烯)
PVF           Poly(vinyl fluoride) 聚氟乙烯
PVFM        Poly(vinyl formal) 聚乙烯醇缩甲醛
PVK          Polyvinylcarbazole 聚乙烯咔唑
PVP          Polyvinylpyrrolidone 聚乙烯吡咯烷酮
S/MA        Styrene-maleic anhydride plastic 苯乙烯-马来酐塑料
SAN         Styrene-acrylonitrile plastic 苯乙烯-丙烯腈塑料
SB            Styrene-butadiene plastic 苯乙烯-丁二烯塑料
Si             Silicone plastics 有机硅塑料
SMS         Styrene/alpha-methylstyrene plastic 苯乙烯-α-甲基苯乙烯塑料
SP            Saturated polyester plastic 饱和聚酯塑料
SRP           Styrene-rubber plastics 聚苯乙烯橡胶改性塑料
TEEE         Thermoplastic Elastomer,Ether-Ester" 醚酯型热塑弹性体
TEO          Thermoplastic Elastomer, Olefinic" 聚烯烃热塑弹性体
TES          Thermoplastic Elastomer, Styrenic" 苯乙烯热塑性弹性体
TPEL         Thermoplastic elastomer 热塑(性)弹性体
TPES         Thermoplastic polyester 热塑性聚酯
TPUR         Thermoplastic polyurethane 热塑性聚氨酯
TSUR         Thermoset polyurethane 热固聚氨酯
UF             Urea-formaldehyde resin 脲甲醛树脂
UHMWPE     Ultra-high molecular weight PE 超高分子量聚乙烯
UP             Unsaturated polyester 不饱和聚酯
VCE           Vinyl chloride-ethylene resin 氯乙烯/乙烯树脂
VCEV         Vinyl chloride-ethylene-vinyl 氯乙烯/乙烯/醋酸乙烯共聚物
VCMA         Vinyl chloride-methyl acrylate 氯乙烯/丙烯酸甲酯共聚物
VCMMA       Vinyl chloride-methylmethacrylate 氯乙烯/甲基丙烯酸甲酯共聚物
VCOA          Vinyl chloride-octyl acrylate resin 氯乙烯/丙烯酸辛酯树脂
VCVAC        Vinyl chloride-vinyl acetate resin 氯乙烯/醋酸乙烯树脂
VCVDC        Vinyl chloride-vinylidene chloride 氯乙烯/偏氯乙烯共聚物
[ 本帖最后由 magic_kok 于 2007-4-4 19:37 编辑 ]
发表于 2007-4-14 11:11:23 |Error| 显示全部楼层
你真是太热心啦!支持!!!
发表于 2007-4-15 13:38:32 |Error| 显示全部楼层
太详细~~了~~~~~~~~~~~~~~~~~~~~~~~~~~~~
发表于 2007-4-17 19:45:23 |Error| 显示全部楼层
一直想找,没想到这有,真是太谢谢了!
发表于 2007-4-25 14:56:21 |Error| 显示全部楼层
如果能加上PMMA是电木的简称之类就更好了!谢谢!
发表于 2007-5-19 18:13:40 |Error| 显示全部楼层
dingddddddddddddddddddddddddddddddddddddddddddddddddddddddddd
发表于 2007-12-14 14:08:18 |Error| 显示全部楼层
正是急需的東東!~~~!
謝,.
GMT+8, 2026-11-4 05:03 , Processed in 0.220337 second(s), 23 queries .
