查看: 1431|回复: 3
[求助] preo打开出现警告框关闭。上上个月还正常使用过
发表于 2010-1-7 14:28:51 |Error| 显示全部楼层 |阅读模式
下面是警告框的内容,以前可以正常使用。元旦后就打不开了。
License request failed for feature PROE_1233781: -15:
Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature:       PROE_1233781
Server name:   jsb102
License path:  7788@jsb102;
FLEXlm error:  -15,10.  System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXlm End User Manual,
available at "www.globetrotter.com".
Failed to initialize communications.  Some features are disabled.
Option Chinese_Translation not ordered, please contact your sales representative.
LANG being reset to USASCII
请高手指出问题所在。正好有时间想学习一下PORE又出现这种问题
发表于 2010-1-10 16:03:53 |Error| 显示全部楼层
许可证失败.不能接通许可证服务器....中文翻译没有注册...
看来是没有彻底解密,只好重装了.
发表于 2010-4-6 15:29:04 |Error| 显示全部楼层
等待答案中,我的也成这样了/
发表于 2010-4-7 05:41:14 |Error| 显示全部楼层
这种问题我没有遇到过,楼主是不是将许可证文件给删除了,或者网卡变了。重新生成一下许可证看看吧!
GMT+8, 2026-10-30 09:05 , Processed in 0.228282 second(s), 22 queries .
