- 3
- 10
- 2007-3-23
发表于 2007-3-23 16:48:27
|Error|
显示全部楼层
你看看这个安装说明
PTC Wildfire 3.0 M040
1. In the crack directory open the file called ptc.dat and host to your computer name
and 00-00-00-00-00-00 to you host ID. Run keygen.bat which will create a license.dat.
1. 用记事本打开ptc.dat,将HOST改为你的电脑名,将00-00-00-00-00-00改为你的HOST ID(这些信息可在软件安装界面上找到),保存。
然后运行Keygen.bat生成一个License.dat文件。
2. Run setup and Install the Ptc License manager. Browse to the license.dat file created
in step #1.
2. 安装PTC Licnese Manager,并指向第一步生成的License.dat文件
3. Run setup and install Pro/e, Pro Mechanica and Distributed Services.
3. 安装M040,以及选择性的安装Pro Mechanica 和 Distributed Services
4. Copy the "PTC-WF3-M040.exe" patcher to the following directories and run it:
- Pro/e: x:\Program Files\proeWildfire 3.0\i486_nt\obj
- Pro/Mechanica: x:\Program Files\mechWildfire 3.0\i486_nt\bin
- Distributed Services: x:\Program Files\ptc_distributed_services\i486_nt\obj
4. 安装好后将"PTC-WF3-M040.exe"分别复制到如下目录下并分别运行进行破解。
5. To full license Vericut copy "WF3-Vericut-5.4.4.exe" to x:\Program Files\proeWildfire 3.0
\i486_nt\obj and run it. Also edit "x:\Program Files\proeWildfire 3.0\bin\proev.bat" and edit the 3rd
to last line in the file (add the comment "PTC_KEY=0").
- e.g. %start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;
%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0
5. 如果想破解Vericut,将"WF3-Vericut-5.4.4.exe"复制到 x:\Program Files\proeWildfire 3.0
\i486_nt\obj 运行并破解。并用记事本编辑"x:\Program Files\proeWildfire 3.0\bin\proev.bat" 在第三行的最后加入:"PTC_KEY=0"这个值即可。搞定。全功能破解版本。
有什么安装上的疑问请联系我们。
之前的3.0版本的安装方法只做个参考。直接使用上面的方法即可。 |
