查看: 3713|回复: 12
[美国标准] ASTM-volume05.01-Petroleum Products and Lubricants (I)
发表于 2009-8-29 11:24:32 |Error| 显示全部楼层 |阅读模式
Volume 05.01, February 2004 Petroleum Products and Lubricants (I) D56-02a Standard Test Method for Flash Point by Tag Closed Tester - (View Full Text) D61-75(1999) Standard Test Method for Softening Point of Pitches (Cube-in-Water Method) - (View Full Text) D71-94(1999) Standard Test Method for Relative Density of Solid Pitch and Asphalt (Displacement Method) - (View Full Text) D86-03 Standard Test Method for Distillation of Petroleum Products at Atmospheric Pressure - (View Full Text) D87-87(1999) Standard Test Method for Melting Point of Petroleum Wax (Cooling Curve) - (View Full Text) D91-02 Standard Test Method for Precipitation Number of Lubricating Oils - (View Full Text) D92-02b Standard Test Method for Flash and Fire Points by Cleveland Open Cup Tester - (View Full Text) D93-02a Standard Test Methods for Flash-Point by Pensky-Martens Closed Cup Tester - (View Full Text) D94-02 Standard Test Methods for Saponification Number of Petroleum Products - (View Full Text) D95-99e1 Standard Test Method for Water in Petroleum Products and Bituminous Materials by Distillation - (View Full Text) D97-02 Standard Test Method for Pour Point of Petroleum Products - (View Full Text) D127-87(1999) Standard Test Method for Drop Melting Point of Petroleum Wax Including Petrolatum - (View Full Text) D128-98(2003)e1 Standard Test Methods for Analysis of Lubricating Grease - (View Full Text) D129-00 Standard Test Method for Sulfur in Petroleum Products (General Bomb Method) - (View Full Text) D130-94(2000)e1 Standard Test Method for Detection of Copper Corrosion from Petroleum Products by the Copper Strip Tarnish Test - (View Full Text) D156-02 Standard Test Method for Saybolt Color of Petroleum Products (Saybolt Chromometer Method) - (View Full Text) D187-94(2003)e1 Standard Test Method for Burning Quality of Kerosine - (View Full Text) D189-01 Standard Test Method for Conradson Carbon Residue of Petroleum Products - (View Full Text) D217-02 Standard Test Methods for Cone Penetration of Lubricating Grease - (View Full Text) D240-02 Standard Test Method for Heat of Combustion of Liquid Hydrocarbon Fuels by Bomb Calorimeter - (View Full Text) D287-92(2000)e1 Standard Test Method for API Gravity of Crude Petroleum and Petroleum Products (Hydrometer Method) - (View Full Text) D322-97(2002)e1 Standard Test Method for Gasoline Diluent in Used Gasoline Engine Oils by Distillation - (View Full Text) D323-99a Standard Test Method for Vapor Pressure of Petroleum Products (Reid Method) - (View Full Text) D341-93(1998) Standard Viscosity-Temperature Charts for Liquid Petroleum Products - (View Full Text) D381-03 Standard Test Method for Gum Content in Fuels by Jet Evaporation - (View Full Text) D396-02a Standard Specification for Fuel Oils - (View Full Text) D445-03 Standard Test Method for Kinematic Viscosity of Transparent and Opaque Liquids (the Calculation of Dynamic Viscosity) - (View Full Text) D446-00 Standard Specifications and Operating Instructions for Glass Capillary Kinematic Viscometers - (View Full Text) D473-02 Standard Test Method for Sediment in Crude Oils and Fuel Oils by the Extraction Method - (View Full Text) D482-03 Standard Test Method for Ash from Petroleum Products - (View Full Text) D483-00 Standard Test Method for Unsulfonated Residue of Petroleum Plant Spray Oils - (View Full Text) D524-03 Standard Test Method for Ramsbottom Carbon Residue of Petroleum Products - (View Full Text) D525-01 Standard Test Method for Oxidation Stability of Gasoline (Induction Period Method) - (View Full Text) D565-99 Standard Test Method for Carbonizable Substances in White Mineral Oil - (View Full Text) D566-02 Standard Test Method for Dropping Point of Lubricating Grease - (View Full Text) D611-01b Standard Test Methods for Aniline Point and Mixed Aniline Point of Petroleum Products and Hydrocarbon Solvents - (View Full Text) D612-88(1999) Standard Test Method for Carbonizable Substances in Paraffin Wax - (View Full Text) D664-01 Standard Test Method for Acid Number of Petroleum Products by Potentiometric Titration - (View Full Text) D665-03 Standard Test Method for Rust-Preventing Characteristics of Inhibited Mineral Oil in the Presence of Water - (View Full Text) D721-02a Standard Test Method for Oil Content of Petroleum Waxes - (View Full Text) D808-00 Standard Test Method for Chlorine in New and Used Petroleum Products (Bomb Method) - (View Full Text) D873-02 Standard Test Method for Oxidation Stability of Aviation Fuels (Potential Residue Method) - (View Full Text) D874-00 Standard Test Method for Sulfated Ash from Lubricating Oils and Additives - (View Full Text) D892-03 Standard Test Method for Foaming Characteristics of Lubricating Oils - (View Full Text) D893-97(2002)e1 Standard Test Method for Insolubles In Used Lubricating Oils - (View Full Text) D910-03 Standard Specification for Aviation Gasolines - (View Full Text)
 楼主| 发表于 2009-8-29 11:25:44 |Error| 显示全部楼层
D937-97(2002) Standard Test Method for Cone Penetration of Petrolatum - (View Full Text)
D938-92(1998)e1 Standard Test Method for Congealing Point of Petroleum Waxes, Including Petrolatum - (View Full Text)
D942-02 Standard Test Method for Oxidation Stability of Lubricating Greases by the Oxygen Bomb Method - (View Full Text)
D943-02 Standard Test Method for Oxidation Characteristics of Inhibited Mineral Oils - (View Full Text)
D972-02 Standard Test Method for Evaporation Loss of Lubricating Greases and Oils - (View Full Text)
D974-02e1 Standard Test Method for Acid and Base Number by Color-Indicator Titration - (View Full Text)
D975-03 Standard Specification for Diesel Fuel Oils - (View Full Text)
D976-91(2000)e1 Standard Test Methods for Calculated Cetane Index of Distillate Fuels - (View Full Text)
D1015-99 Standard Test Method for Freezing Points of High-Purity Hydrocarbons - (View Full Text)
D1016-99 Standard Test Method for Purity of Hydrocarbons from Freezing Points - (View Full Text)
D1018-00 Standard Test Method for Hydrogen In Petroleum Fractions - (View Full Text)
D1025-00 Standard Test Method for Nonvolatile Residue of Polymerization Grade Butadiene - (View Full Text)
D1091-00 Standard Test Methods for Phosphorus in Lubricating Oils and Additives - (View Full Text)
D1092-99 Standard Test Method for Measuring Apparent Viscosity of Lubricating Greases - (View Full Text)
D1093-98 Standard Test Method for Acidity of Hydrocarbon Liquids and Their Distillation Residues - (View Full Text)
D1094-00 Standard Test Method for Water Reaction of Aviation Fuels - (View Full Text)
D1157-91(2000)e1 Standard Test Method for Total Inhibitor Content (TBC) of Light Hydrocarbons - (View Full Text)
D1159-01 Standard Test Method for Bromine Numbers of Petroleum Distillates and Commercial Aliphatic Olefins by Electrometric Titration - (View Full Text)
D1160-03 Standard Test Method for Distillation of Petroleum Products at Reduced Pressure - (View Full Text)
D1217-93(2003)e1 Standard Test Method for Density and Relative Density (Specific Gravity) of Liquids by Bingham Pycnometer - (View Full Text)
D1218-02 Standard Test Method for Refractive Index and Refractive Dispersion of Hydrocarbon Liquids - (View Full Text)
D1250-80(2002) Standard Guide for Petroleum Measurement Tables - (View Full Text)
D1263-94(1999) Standard Test Method for Leakage Tendencies of Automotive Wheel Bearing Greases - (View Full Text)
D1264-03e1 Standard Test Method for Determining the Water Washout Characteristics of Lubricating Greases - (View Full Text)
D1265-97 Standard Practice for Sampling Liquefied Petroleum (LP) Gases (Manual Method) - (View Full Text)
D1266-98(2003)e1 Standard Test Method for Sulfur in Petroleum Products (Lamp Method) - (View Full Text)
D1267-02 Standard Test Method for Gage Vapor Pressure of Liquefied Petroleum (LP) Gases (LP-Gas Method) - (View Full Text)
D1298-99e2 Standard Test Method for Density, Relative Density (Specific Gravity), or API Gravity of Crude Petroleum and Liquid Petroleum Products by Hydrometer Method - (View Full Text)
D1318-00 Standard Test Method for Sodium in Residual Fuel Oil (Flame Photometric Method) - (View Full Text)
D1319-02a Standard Test Method for Hydrocarbon Types in Liquid Petroleum Products by Fluorescent Indicator Adsorption - (View Full Text)
D1321-02a Standard Test Method for Needle Penetration of Petroleum Waxes - (View Full Text)
D1322-97(2002)e1 Standard Test Method for Smoke Point of Kerosine and Aviation Turbine Fuel - (View Full Text)
D1367-96(2001) Standard Test Method for Lubricating Qualities of Graphites - (View Full Text)
D1401-02 Standard Test Method for Water Separability of Petroleum Oils and Synthetic Fluids - (View Full Text)
D1403-02 Standard Test Methods for Cone Penetration of Lubricating Grease Using One-Quarter and One-Half Scale Cone Equipment - (View Full Text)
D1404/D1404M-99(2003) Standard Test Method for Estimation of Deleterious Particles in Lubricating Grease - (View Full Text)
D1405-01 Standard Test Method for Estimation of Net Heat of Combustion of Aviation Fuels - (View Full Text)
D1465-90(2000) Standard Test Method for Blocking and Picking Points of Petroleum Wax - (View Full Text)
D1478-02 Standard Test Method for Low-Temperature Torque of Ball Bearing Grease - (View Full Text)
D1480-02 Standard Test Method for Density and Relative Density (Specific Gravity) of Viscous Materials by Bingham Pycnometer - (View Full Text)
D1481-02 Standard Test Method for Density and Relative Density (Specific Gravity) of Viscous Materials by Lipkin Bicapillary Pycnometer - (View Full Text)
D1500-03 Standard Test Method for ASTM Color of Petroleum Products (ASTM Color Scale) - (View Full Text)
D1550-94(2000) Standard ASTM Butadiene Measurement Tables - (View Full Text)
D1552-03 Standard Test Method for Sulfur in Petroleum Products (High-Temperature Method) - (View Full Text)
D1655-03 Standard Specification for Aviation Turbine Fuels - (View Full Text)
D1657-02 Standard Test Method for Density or Relative Density of Light Hydrocarbons by Pressure Hydrometer - (View Full Text)
D1662-92(2002) Standard Test Method for Active Sulfur in Cutting Oils - (View Full Text)
D1740-01 Standard Test Method for Luminometer Numbers of Aviation Turbine Fuels - (View Full Text)
D1742-94(2000)e1 Standard Test Method for Oil Separation from Lubricating Grease During Storage - (View Full Text)
D1743-01 Standard Test Method for Determining Corrosion Preventive Properties of Lubricating Greases - (View Full Text)
D1747-99 Standard Test Method for Refractive Index of Viscous Materials - (View Full Text)
D1748-02 Standard Test Method for Rust Protection by Metal Preservatives in the Humidity Cabinet - (View Full Text)
D1796-97(2002) Standard Test Method for Water and Sediment in Fuel Oils by the Centrifuge Method (Laboratory Procedure) - (View Full Text)
D1831-00e1 Standard Test Method for Roll Stability of Lubricating Grease - (View Full Text)
D1832-87(1999) Standard Test Method for Peroxide Number of Petroleum Wax - (View Full Text)
D1833-87(1999) Standard Test Method for Odor of Petroleum Wax - (View Full Text)
D1834-90(2000) Standard Test Method for 20o Specular Gloss of Waxed Paper - (View Full Text)
D1835-03a Standard Specification for Liquefied Petroleum (LP) Gases - (View Full Text)
D1837-02a Standard Test Method for Volatility of Liquefied Petroleum (LP) Gases - (View Full Text)
D1838-03 Standard Test Method for Copper Strip Corrosion by Liquefied Petroleum (LP) Gases - (View Full Text)
D1839-91(2000)e1 Standard Test Method for Amyl Nitrate in Diesel Fuels - (View Full Text)
D1840-03 Standard Test Method for Naphthalene Hydrocarbons in Aviation Turbine Fuels by Ultraviolet Spectrophotometry - (View Full Text)
D2001-92(2002) Standard Test Method for Depentanization of Gasoline and Naphthas - (View Full Text)
D2007-03 Standard Test Method for Characteristic Groups in Rubber Extender and Processing Oils and Other Petroleum-Derived Oils by the Clay-Gel Absorption Chromatographic Method - (View Full Text)
D2008-91(2001) Standard Test Method for Ultraviolet Absorbance and Absorptivity of Petroleum Products - (View Full Text)
D2068-97(2003) Standard Test Method for Filter Blocking Tendency of Distillate Fuel Oils - (View Full Text)
D2070-91(2001) Standard Test Method for Thermal Stability of Hydraulic Oils - (View Full Text)
D2156-94(2003) Standard Test Method for Smoke Density in Flue Gases from Burning Distillate Fuels - (View Full Text)
D2157-94(2003) Standard Test Method for Effect of Air Supply on Smoke Density in Flue Gases From Burning Distillate Fuels - (View Full Text)
D2158-02 Standard Test Method for Residues in Liquefied Petroleum (LP) Gases - (View Full Text)
D2161-93(1999)e2 Standard Practice for Conversion of Kinematic Viscosity to Saybolt Universal Viscosity or to Saybolt Furol Viscosity - (View Full Text)
D2162-99e1 Standard Test Method for Basic Calibration of Master Viscometers and Viscosity Oil Standards - (View Full Text)
D2163-91(1996) Standard Test Method for Analysis of Liquefied Petroleum (LP) Gases and Propene Concentrates by Gas Chromatography - (View Full Text)
 楼主| 发表于 2009-8-29 11:26:53 |Error| 显示全部楼层
D2265-00 Standard Test Method for Dropping Point of Lubricating Grease Over Wide Temperature Range - (View Full Text)
D2266-01 Standard Test Method for Wear Preventive Characteristics of Lubricating Grease (Four-Ball Method) - (View Full Text)
D2268-93(2003)e1 Standard Test Method for Analysis of High-Purity n-Heptane and Isooctane by Capillary Gas Chromatography - (View Full Text)
D2269-99 Standard Test Method for Evaluation of White Mineral Oils by Ultraviolet Absorption - (View Full Text)
D2270-93(1998) Standard Practice for Calculating Viscosity Index From Kinematic Viscosity at 40 and 100°C - (View Full Text)
D2271-94(1999)e1 Standard Test Method for Preliminary Examination of Hydraulic Fluids (Wear Test) - (View Full Text)
D2272-02 Standard Test Method for Oxidation Stability of Steam Turbine Oils by Rotating Pressure Vessel - (View Full Text)
D2273-97(2002)e1 Standard Test Method for Trace Sediment in Lubricating Oils - (View Full Text)
D2274-03 Standard Test Method for Oxidation Stability of Distillate Fuel Oil (Accelerated Method) - (View Full Text)
D2276-00 Standard Test Method for Particulate Contaminant in Aviation Fuel by Line Sampling - (View Full Text)
D2318-98(2003) Standard Test Method for Quinoline-Insoluble (QI) Content of Tar and Pitch - (View Full Text)
D2319-98(2003) Standard Test Method for Softening Point of Pitch (Cube-in-Air Method) - (View Full Text)
D2320-98(2003) Standard Test Method for Density (Relative Density) of Solid Pitch (Pycnometer Method) - (View Full Text)
D2384-83(2000)e1 Standard Test Methods for Traces of Volatile Chlorides in Butane-Butene Mixtures - (View Full Text)
D2386-03 Standard Test Method for Freezing Point of Aviation Fuels - (View Full Text)
D2392-96(2001)e1 Standard Test Method for Color Of Dyed Aviation Gasolines - (View Full Text)
D2415-98(2003) Standard Test Method for Ash in Coal Tar and Pitch - (View Full Text)
D2416-84(1999) Standard Test Method for Coking Value of Tar and Pitch (Modified Conradson) - (View Full Text)
D2420-91(2001) Standard Test Method for Hydrogen Sulfide In Liquefied Petroleum (LP) Gases (Lead Acetate Method) - (View Full Text)
D2421-02 Standard Practice for Interconversion of Analysis of C5 and Lighter Hydrocarbons to Gas-Volume, Liquid-Volume, or Weight Basis - (View Full Text)
D2422-97(2002) Standard Classification of Industrial Fluid Lubricants by Viscosity System - (View Full Text)
D2423-90(2002) Standard Test Method for Surface Wax on Waxed Paper or Paperboard - (View Full Text)
D2425-99 Standard Test Method for Hydrocarbon Types in Middle Distillates by Mass Spectrometry - (View Full Text)
D2426-93(1998) Standard Test Method for Butadiene Dimer and Styrene in Butadiene Concentrates by Gas Chromatography - (View Full Text)
D2427-92(2001) Standard Test Method for Determination of C2 through C5 Hydrocarbons in Gasolines by Gas Chromatography - (View Full Text)
D2500-02 Standard Test Method for Cloud Point of Petroleum Products - (View Full Text)
D2501-91(2000) Standard Test Method for Calculation of Viscosity-Gravity Constant (VGC) of Petroleum Oils - (View Full Text)
D2502-92(2002) Standard Test Method for Estimation of Molecular Weight (Relative Molecular Mass) of Petroleum Oils From Viscosity Measurements - (View Full Text)
D2503-92(2002)e1 Standard Test Method for Relative Molecular Mass (Molecular Weight) of Hydrocarbons by Thermoelectric Measurement of Vapor Pressure - (View Full Text)
D2504-88(1998) Standard Test Method for Noncondensable Gases in C2 and Lighter Hydrocarbon Products by Gas Chromatography - (View Full Text)
D2505-88(1998) Standard Test Method for Ethylene, Other Hydrocarbons, and Carbon Dioxide in High-Purity Ethylene by Gas Chromatography - (View Full Text)
D2509-03 Standard Test Method for Measurement of Load-Carrying Capacity of Lubricating Grease (Timken Method) - (View Full Text)
D2510-94(1998) Standard Test Method for Adhesion of Solid Film Lubricants - (View Full Text)
D2511-93(2003) Standard Test Method for Thermal Shock Sensitivity of Solid Film Lubricants - (View Full Text)
D2532-93(1998) Standard Test Method for Viscosity and Viscosity Change After Standing at Low Temperature of Aircraft Turbine Lubricants - (View Full Text)
D2533-99 Standard Test Method for Vapor-Liquid Ratio of Spark-Ignition Engine Fuels - (View Full Text)
D2534-88(1999) Standard Test Method for Coefficient of Kinetic Friction for Wax Coatings - (View Full Text)
D2549-02 Standard Test Method for Separation of Representative Aromatics and Nonaromatics Fractions of High-Boiling Oils by Elution Chromatography - (View Full Text)
D2569-97(2002) Standard Test Method for Distillation of Pitch - (View Full Text)
D2593-93(1998) Standard Test Method for Butadiene Purity and Hydrocarbon Impurities by Gas Chromatography - (View Full Text)
D2595-96(2002)e1 Standard Test Method for Evaporation Loss of Lubricating Greases Over Wide-Temperature Range - (View Full Text)
D2596-97(2002)e1 Standard Test Method for Measurement of Extreme-Pressure Properties of Lubricating Grease (Four-Ball Method) - (View Full Text)
D2597-94(1999) Standard Test Method for Analysis of Demethanized Hydrocarbon Liquid Mixtures Containing Nitrogen and Carbon Dioxide by Gas Chromatography - (View Full Text)
D2598-02 Standard Practice for Calculation of Certain Physical Properties of Liquefied Petroleum (LP) Gases from Compositional Analysis - (View Full Text)
D2603-01 Test Method for Sonic Shear Stability of Polymer-Containing Oils - (View Full Text)
D2619-95(2002)e1 Standard Test Method for Hydrolytic Stability of Hydraulic Fluids (Beverage Bottle Method) - (View Full Text)
D2622-03 Standard Test Method for Sulfur in Petroleum Products by Wavelength Dispersive X-ray Fluorescence Spectrometry - (View Full Text)
D2624-02 Standard Test Methods for Electrical Conductivity of Aviation and Distillate Fuels - (View Full Text)
D2625-94(2003) Standard Test Method for Endurance (Wear) Life and Load-Carrying Capacity of Solid Film Lubricants (Falex Pin and Vee Method) - (View Full Text)
D2638-91(2002) Standard Test Method for Real Density of Calcined Petroleum Coke by Helium Pycnometer - (View Full Text)
D2649-99e1 Standard Test Method for Corrosion Characteristics of Solid Film Lubricants - (View Full Text)
D2650-99 Standard Test Method for Chemical Composition of Gases By Mass Spectrometry - (View Full Text)
D2669-87(1999) Standard Test Method for Apparent Viscosity of Petroleum Waxes Compounded with Additives (Hot Melts) - (View Full Text)
D2670-95(1999) Standard Test Method for Measuring Wear Properties of Fluid Lubricants (Falex Pin and Vee Block Method) - (View Full Text)
D2709-96(2001)e1 Standard Test Method for Water and Sediment in Middle Distillate Fuels by Centrifuge - (View Full Text)
 楼主| 发表于 2009-8-29 11:27:51 |Error| 显示全部楼层
D2710-99 Standard Test Method for Bromine Index of Petroleum Hydrocarbons by Electrometric Titration - (View Full Text)
D2711-01a Standard Test Method for Demulsibility Characteristics of Lubricating Oils - (View Full Text)
D2712-91(2003)e1 Standard Test Method for Hydrocarbon Traces in Propylene Concentrates By Gas Chromatography - (View Full Text)
D2713-91(2001) Standard Test Method for Dryness of Propane (Valve Freeze Method) - (View Full Text)
D2714-94(2003) Standard Test Method for Calibration and Operation of the Falex Block-on-Ring Friction and Wear Testing Machine - (View Full Text)
D2715-92(2002) Standard Test Method for Volatilization Rates of Lubricants in Vacuum - (View Full Text)
D2717-95(2000) Standard Test Method for Thermal Conductivity of Liquids - (View Full Text)
D2764-99 Standard Test Method for Dimethylformamide-Insoluble (DMF-I) Content of Tar and Pitch - (View Full Text)
D2766-95(2000) Standard Test Method for Specific Heat of Liquids and Solids - (View Full Text)
D2779-92(2002) Standard Test Method for Estimation of Solubility of Gases in Petroleum Liquids - (View Full Text)
D2780-92(2002)e1 Standard Test Method for Solubility of Fixed Gases in Liquids - (View Full Text)
D2782-02 Standard Test Method for Measurement of Extreme-Pressure Properties of Lubricating Fluids (Timken Method) - (View Full Text)
D2783-03 Standard Test Method for Measurement of Extreme-Pressure Properties of Lubricating Fluids (Four-Ball Method) - (View Full Text)
D2784-98(2003)e1 Standard Test Method for Sulfur in Liquefied Petroleum Gases (Oxy-Hydrogen Burner or Lamp) - (View Full Text)
D2786-91(2001)e1 Standard Test Method for Hydrocarbon Types Analysis of Gas-Oil Saturates Fractions by High Ionizing Voltage Mass Spectrometry - (View Full Text)
D2789-95(2000)e1 Standard Test Method for Hydrocarbon Types in Low Olefinic Gasoline by Mass Spectrometry - (View Full Text)
D2878-95(2000)e1 Standard Test Method for Estimating Apparent Vapor Pressures and Molecular Weights of Lubricating Oils - (View Full Text)
D2879-97(2002)e1 Standard Test Method for Vapor Pressure-Temperature Relationship and Initial Decomposition Temperature of Liquids by Isoteniscope - (View Full Text)
D2880-03 Standard Specification for Gas Turbine Fuel Oils - (View Full Text)
D2881-03 Standard Classification for Metal Working Fluids and Related Materials - (View Full Text)
D2883-95(2000)e1 Standard Test Method for Reaction Threshold Temperature of Liquid and Solid Materials - (View Full Text)
D2884-93(2002) Standard Test Method for Yield Stress of Heterogeneous Propellants by Cone Penetration Method - (View Full Text)
D2887-03 Standard Test Method for Boiling Range Distribution of Petroleum Fractions by Gas Chromatography - (View Full Text)
D2889-95(2000) Standard Test Method for Calculation of True Vapor Pressures of Petroleum Distillate Fuels - (View Full Text)
D2890-92(2003) Standard Test Method for Calculation of Liquid Heat Capacity of Petroleum Distillate Fuels - (View Full Text)
D2892-03a Standard Test Method for Distillation of Crude Petroleum (15-Theoretical Plate Column) - (View Full Text)
D2893-03 Standard Test Method for Oxidation Characteristics of Extreme-Pressure Lubrication Oils - (View Full Text)
D2895-88(1999) Standard Test Method for Gloss Retention of Waxed Paper and Paperboard After Storage at 40°C (104°F) - (View Full Text)
D2896-03 Standard Test Method for Base Number of Petroleum Products by Potentiometric Perchloric Acid Titration - (View Full Text)
D2962-97(2002) Standard Test Method for Calculating Volume-Temperature Correction For Coal-Tar Pitches - (View Full Text)
D2981-94(2003) Standard Test Method for Wear Life of Solid Film Lubricants in Oscillating Motion - (View Full Text)
D2982-98e1 Standard Test Methods for Detecting Glycol-Base Antifreeze in Used Lubricating Oils - (View Full Text)
D2983-03 Standard Test Method for Low-Temperature Viscosity of Lubricants Measured by Brookfield
D3104-99 Standard Test Method for Softening Point of Pitches (Mettler Softening Point Method) - (View Full Text)
D3115-95(2000) Standard Test Method for Explosive Reactivity of Lubricants with Aerospace Alloys Under High Shear - (View Full Text)
D3117-03 Standard Test Method for Wax Appearance Point of Distillate Fuels - (View Full Text)
D3120-03a Standard Test Method for Trace Quantities of Sulfur in Light Liquid Petroleum Hydrocarbons by Oxidative Microcoulometry - (View Full Text)
D3227-02a Standard Test Method for (Thiol Mercaptan) Sulfur in Gasoline, Kerosine, Aviation Turbine, and Distillate Fuels (Potentiometric Method) - (View Full Text)
D3228-03 Standard Test Method for Total Nitrogen in Lubricating Oils and Fuel Oils by Modified Kjeldahl Method - (View Full Text)
D3230-99 Standard Test Method for Salts in Crude Oil (Electrometric Method) - (View Full Text)
 楼主| 发表于 2009-8-29 11:30:39 |Error| 显示全部楼层
ASTM-05-01部分,石油化工和润滑油章节,共计6个附件,目录如上。
 楼主| 发表于 2009-8-29 11:43:29 |Error| 显示全部楼层
不知道为啥总上传不上去,。每次三个吧
volume05.01-Petroleum Products and Lubricants (I).part1.rar
3 MB, 下载次数: 36
volume05.01-Petroleum Products and Lubricants (I).part2.rar
3 MB, 下载次数: 27
volume05.01-Petroleum Products and Lubricants (I).part3.rar
3 MB, 下载次数: 33
 楼主| 发表于 2009-8-29 11:52:18 |Error| 显示全部楼层
最后三个
volume05.01-Petroleum Products and Lubricants (I).part4.rar
3 MB, 下载次数: 27
volume05.01-Petroleum Products and Lubricants (I).part5.rar
3 MB, 下载次数: 25
volume05.01-Petroleum Products and Lubricants (I).part6.rar
532.7 KB, 下载次数: 27
 楼主| 发表于 2009-8-29 13:14:28 |Error| 显示全部楼层
volume05.02-Petroleum Products and Lubricants (II).
1~2
volume05.02-Petroleum Products and Lubricants (II).part1.rar
3 MB, 下载次数: 31
volume05.02-Petroleum Products and Lubricants (II).part2.rar
3 MB, 下载次数: 38
 楼主| 发表于 2009-8-29 13:27:53 |Error| 显示全部楼层
3·-~5,0502的第二部分共计5个附件
 楼主| 发表于 2009-8-29 13:39:50 |Error| 显示全部楼层
volume05.02-Petroleum Products and Lubricants (II).part3.rar
3 MB, 下载次数: 38
volume05.02-Petroleum Products and Lubricants (II).part4.rar
3 MB, 下载次数: 28
volume05.02-Petroleum Products and Lubricants (II).part5.rar
2.33 MB, 下载次数: 26
 楼主| 发表于 2009-8-29 13:58:16 |Error| 显示全部楼层
volume05.03-Petroleum Products and Lubricants (III)
共计8个压缩包,每个2m,两次4个
volume05.03-Petroleum Products and Lubricants (III).part01.rar
2 MB, 下载次数: 34
 楼主| 发表于 2009-8-29 14:11:26 |Error| 显示全部楼层
volume05.03-Petroleum Products and Lubricants (III),
共计8个附件,每个2m
2 MB, 下载次数: 29
volume05.03-Petroleum Products and Lubricants (III).part02.rar
2 MB, 下载次数: 32
volume05.03-Petroleum Products and Lubricants (III).part03.rar
2 MB, 下载次数: 24
volume05.03-Petroleum Products and Lubricants (III).part04.rar
2 MB, 下载次数: 37
 楼主| 发表于 2009-8-29 14:30:30 |Error| 显示全部楼层
5~8附件,每个2m
volume05.03-Petroleum Products and Lubricants (III).part05.rar
2 MB, 下载次数: 31
volume05.03-Petroleum Products and Lubricants (III).part06.rar
2 MB, 下载次数: 34
volume05.03-Petroleum Products and Lubricants (III).part07.rar
2 MB, 下载次数: 30
volume05.03-Petroleum Products and Lubricants (III).part08.rar
1.85 MB, 下载次数: 25
GMT+8, 2026-10-30 08:17 , Processed in 0.293447 second(s), 31 queries .
