- 121
- 30
- 2009-8-18
楼主 |
发表于 2009-8-19 13:57:21
|Error|
显示全部楼层
D1525-00 Standard Test Method for Vicat Softening Temperature of Plastics - (View Full Text)
D1562-98 Standard Classification System for Cellulose Acetate Propionate Molding and Extrusion Compounds - (View Full Text)
D1593-99 Standard Specification for Nonrigid Vinyl Chloride Plastic Film and Sheeting - (View Full Text)
D1600-99 Standard Terminology for Abbreviated Terms Relating to Plastics - (View Full Text)
D1601-99 Standard Test Method for Dilute Solution Viscosity of Ethylene Polymers - (View Full Text)
D1603-01 Standard Test Method for Carbon Black In Olefin Plastics - (View Full Text)
D1621-00 Standard Test Method for Compressive Properties Of Rigid Cellular Plastics - (View Full Text)
D1622-03 Standard Test Method for Apparent Density of Rigid Cellular Plastics - (View Full Text)
D1623-03 Standard Test Method for Tensile And Tensile Adhesion Properties Of Rigid Cellular Plastics - (View Full Text)
D1636-99 Standard Specification for Allyl Molding Compounds - (View Full Text)
D1667-97 Standard Specification for Flexible Cellular Materials-Vinyl Chloride Polymers and Copolymers (Closed-Cell Foam) - (View Full Text)
D1693-01 Standard Test Method for Environmental Stress-Cracking of Ethylene Plastics - (View Full Text)
D1708-02a Standard Test Method for Tensile Properties of Plastics By Use of Microtensile Specimens - (View Full Text)
D1709-03 Standard Test Methods for Impact Resistance of Plastic Film by the Free-Falling Dart Method - (View Full Text)
D1710-02 Standard Specification for Extruded and Compression Molded Polytetrafluoroethylene (PTFE) Rod and Heavy-Walled Tubing - (View Full Text)
D1712-03 Standard Practice for Resistance of Plastics to Sulfide Staining - (View Full Text)
D1746-03 Standard Test Method for Transparency of Plastic Sheeting - (View Full Text)
D1755-92(2001) Standard Specification for Poly(Vinyl Chloride) Resins - (View Full Text)
D1763-00 Standard Specification for Epoxy Resins - (View Full Text)
D1784-03 Standard Specification for Rigid Poly(Vinyl Chloride) (PVC) Compounds and Chlorinated Poly(Vinyl Chloride) (CPVC) Compounds - (View Full Text)
D1786-01 Standard Specification for Toluene Diisocyanate - (View Full Text)
D1790-02 Standard Test Method for Brittleness Temperature of Plastic Sheeting by Impact - (View Full Text)
D1822-99 Standard Test Method for Tensile-Impact Energy to Break Plastics and Electrical Insulating Materials - (View Full Text)
D1823-95(2001) Standard Test Method for Apparent Viscosity of Plastisols and Organosols at High Shear Rates by Extrusion Viscometer - (View Full Text)
D1824-95(2002) Standard Test Method for Apparent Viscosity of Plastisols and Organosols at Low Shear Rates - (View Full Text)
D1894-01 Standard Test Method for Static and Kinetic Coefficients of Friction of Plastic Film and Sheeting - (View Full Text)
D1895-96(2003) Standard Test Methods for Apparent Density, Bulk Factor, and Pourability of Plastic Materials - (View Full Text)
D1896-99 Standard Practice for Transfer Molding Test Specimens of Thermosetting Compounds - (View Full Text)
D1921-01 Standard Test Methods for Particle Size (Sieve Analysis) of Plastic Materials - (View Full Text) |
