- 129
- 30
- 2006-6-12
楼主 |
发表于 2007-2-14 14:35:48
|Error|
显示全部楼层
手机的跌落测试Osc2U9{\kR)n
Test specification www.iCAx.cnF2u;x}S,n9s
Test name
DROP TEST FOR UNPACKED APPARATUS CAD,CAE,CAM,ICAX,idesign,模具,设计,招聘,培训5h!^W.Bc+RStI{
Evaluate the shock resistance of an apparatus unpacked to resist a series of drop tests. bbs.icax.cn0}7zP$S,b,^
评估无包装的仪器的耐震强度来进行一系列下落测试 (briCQ;uR.V
1. STANDARD标准 CAD/CAM/CAE综合资讯网站论坛9pi(s/Ju
This test is according to the standard NFC 20 732 equivalent to the standard CEI 68-2-32 此测试根据等同于标准cei68-2-32的标准nfc20732。
2. PRINCIPLE原理 bbs.icax.cnI F#P"[`.x
kn
The test samples suffer 14 successive drops with different angles on a pinewood board. 测试样品满足14次连续不同角度下落在松木板上
3. DIRECTIONS FOR USE :使用方向
3.1 Test surface测试表面
Pinewood board of 5 cm thickness 5cm厚度的松木板 7cq"h%E"D
3.2 Dropping height下落高度 iCAx开思论坛TOKc1sumd(~W
The height shall be measured from the part of the specimen nearest to the test surface, when the specimen is suspended prior to letting it fall. O4mNm BFI4Vs]XH
It’s 1.5 m
当样品悬挂好时,下落高度应从最靠近测试表面的样品的部分来测试 CAD/CAM/CAE综合资讯网站论坛~TSD M
O-rQ~G
3.3 Method of release释放方法
The method of releasing the specimen shall be such as to allow free fall from the position of suspension, with a minimum of disturbance at the moment of release.
释放样品的方法应是伴随释放时扰动的最小值,从悬挂处自由落体
3.4 Initial measurements首次测试 www.iCAx.cnM4z&T{F B-i
The specimen shall be visually examinated and electrically and mechanically checked. 样品外观要检查,电力方面和机械方面也要检查
Points to check : s#U3j9J]b"J{S6hy
• Switch on and off the mobile开关手机 CAD,CAE,CAM,ICAX,idesign,模具,设计,招聘,培训F'Qi(lxk-U
• All buttons/keys are functioning.所有的按钮都要检查是否能使用 CAD,CAE,CAM,ICAX,idesign,模具,设计,招聘,培训?t-FN2u
• Transaction with SIM card处理sim卡 xH8p"I&E @y6F"m~u
• Check that all the pixels are functional (Use the specified function of the software for this test. Example for BE1 and BE3, type 000000* then choose the function “checker”). 检查所有像素[使用供测试用的专门软间,比如be1,be3]
• Check the communication检查通讯
3.5 Number of products minimum产品最小值 iCAx开思论坛9L K \C#L
3 apparatus minimum must be tested.三个仪器的最小值必须被检查 +IQ+G#C2m _,pv eL
3.6 During the test测试时
14 consecutive drop tests on all the faces as defined in the diagram : one on each face and corner while the apparatus is working. Even if the apparatus doesn’t fall on the face or corner desired, the drop isn’t done again. CAD,CAE,CAM,ICAX,idesign,模具,设计,招聘,培训U,Eoo$a*Y0e [5s
所有表面上的14个连续下落测试如图表中定义的:当仪器在运转中,每一个表面和角落上的.即使仪器没有下落在理想的表面或角落上,下落也无须再做1次
The battery, unless a contrary request, must not be fixed with an external tool. 除非有相反的要求,否则电池组无须固定在外部工具上
Between each drop, the specimen shall be visually examinated and electrically and mechanically checked. 在每一次下落间, 样品外观要检查,电力方面和机械方面也要检查
Points to check : 7A{s!S;C
• Switch on and off the mobile开关手机 bbs.icax.cn!F1D%o(D#[d X;J^Id
4. JUDGEMENT判断
The specimen shall be visually examinated and electrically and mechanically checked after each drop. 在每一次下落后,样品外观要检查,电力方面和机械方面也要检查 'I+do3b ?
• Checking performances of equipment.检查设备的性能
- Possibility to switch on and off the mobile开关手机
- Mobile stay switched on alone手机保持单独打开 bbs.icax.cnd0^#p#_*hAo(^
- All buttons/keys are functioning. 所有的按钮都要检查是否能使用
- Transaction with SIM card possible. 处理sim卡
- Check that all the pixels are functional (Use the specified function of the software for this test. Example for BE1 and BE3, type 000000* then choose the function “checker”). 检查所有像素[使用供测试用的专门软间,比如be1,be3] bbs.icax.cn7?I3v P)Bjz,D
- Check that communication is possible.检查通讯
• Check the aspect of the equipment after the falling:在下落后,检查仪器的每一方面 www.iCAx.cn9Qzg;Ww
- no injury can be caused due to damage.由于破坏,无损坏被引起 *^3SEf9nw"AB gQN
- damage due to casing must not affect operation.由于装箱的破坏必须不影响操作 interface with all the accessories still functional和所有附件的接口依然有功能。 |
