- 6
- 20
- 2007-2-12
钢铁类词汇
碳素结构钢 Carbon Construction Steel 碳素工具钢 Carbon Tool Steel 合金结构钢 Alloy Construction Steel 合金工具钢 Alloy Tool Steel 高速工具钢 High Speed Tool Steel 弹簧钢 Spring Steel 不锈耐热钢 Stainless & Heat Resisting Steel 轴承钢 Bearing Steel 工字钢 Ibeam 普通圆钢 Round Steel 槽钢 Channel 扁钢 Flat Steel Bar 等边角钢 Equal Angle Steel 不等边角钢 Unequal Angle Steelh 型钢 Hbeam 钢坯 Billet,Bloom 钢筋混凝土用变形钢筋 High Strength Deformed Steel Bar 窗框钢 Window Sash 中厚钢板 Steel Plate 热轧钢板(卷) Hot Rolled Steel Coil 冷轧钢板(卷) Cold Rolled Steel Sheel or Coil 镀锌钢板(卷) Galvanized Steel Coil 钢带 Steel Strip 线材 Wire Rod Coil 无缝钢管 Seamless Steel Pipe 锅炉管 Boiler Tube 石油套管 Pipe For Oil Field 高压管 Pressure Pipe 高压气瓶用管 Tube for High-Pressure Vessel 地质钻探用管 Seamless Steel Pipe For Geological Drill In 镀锌焊管 Galvanized Welded Pipe 石油钻探杆 Drill Pipe For Oil Field 铸铁管 Cast Iron Pipe 重轨 Heavy Rail 轻轨 Light Rail 炼钢生铁 Basic Pig Iron 铸造生铁 foundry Pig Iron 普通圆钢钉 Round Nails for General Uses 镀锌底碳钢丝 Galvanized Low Carbon Steel Wire. 钢丝绳 Steel Wire Rope 钢绞线 Stranded Wire 预应力混凝土钢丝 Steel Wire For Prestressed Concrete 窗纱 Window Screen 车轮 Wheel Tyre 轮筛 Wheel Circle iron and steel industry 钢铁工业ironworks 铁厂foundry 铸造车间steelworks, steel mill 钢厂coking plant 炼焦厂electrometallurgy 电冶金学powder metallurgy 粉末冶金学blast furnace 鼓风炉mouth, throat 炉口hopper, chute 料斗stack 炉身belly 炉腰bosh 炉腹crucible 炉缸slag tap 放渣口taphole 出铁口,出渣口pig bed 铸床mould 铸模 (美作:mold)tuyere, nozzle 风口ingot mould 锭模 (美作:ingot mold)floor 平台hearth 炉底charger 装料机ladle 铁水包,钢水包dust catcher 除尘器washer 洗涤塔converter 转炉hoist 卷扬机compressor 压缩机tilting mixer 可倾式混铁炉regenerator 蓄热室heat exchanger 热交换器gas purifier 煤气净化器turbocompressor 涡轮压缩机burner 烧嘴cupola 化铁炉,冲天炉emptier 排空装置trough 铁水沟,排渣沟skip 料车rolling mill 轧机,轧钢机blooming mill 初轧机roller 辊bed 底座rolling-mill housing 轧机机架drawbench 拔管机,拉丝机drawplate 拉模板shaft furnace 竖炉refining furnace 精炼炉reverberatory furnace 反射炉hearth furnace 床式反射炉firebrick lining 耐火砖衬retort 反应罐muffle 马弗炉roof, arch 炉顶forge 锻造press 压锻pile hammer 打桩锤drop hammer 落锤die 拉模blowlamp 吹炬 (美作:blowtorch)crusher 破碎机iron ore 铁矿石coke 焦炭bauxite 铁钒土alumina 铝cryolite 冰晶石flux 熔剂limestone flux 石灰石溶剂haematite 赤铁矿 (美作:hematite)gangue 脉石cast iron 铸铁cast iron ingot 铸铁锭slag 炉渣soft iron 软铁pig iron 生铁wrought iron 熟铁iron ingot 铁锭puddled iron 搅炼熟铁round iron 圆铁scrap iron 废铁steel 钢crude steel 粗钢mild steel, soft steel 软钢,低碳钢hard steel 硬钢cast steel 坩埚钢,铸钢stainless steel 不锈钢electric steel 电工钢,电炉钢high-speed steel 高速钢moulded steel 铸钢refractory steel 热强钢,耐热钢alloy steel 合金钢plate, sheet 薄板corrugated iron 瓦垅薄钢板tinplate, tin 马口铁finished product 成品,产品semifinished product 半成品,中间产品ferrous products 铁制品coiled sheet 带状薄板bloom 初轧方坯metal strip, metal band 铁带,钢带billet 坯锭,钢坯shavings 剃边profiled bar 异型钢材shape, section 型钢angle iron 角钢frit 烧结wire 线材ferronickel 镍铁elinvar 镍铬恒弹性钢ferrite 铁氧体,铁醇盐cementite 渗碳体,碳化铁pearlite 珠光体charging, loading 装料,炉料fusion, melting, smelting 熔炼remelting 再熔化,重熔refining 精炼casting 出铁to cast 出铁tapping 出渣,出钢,出铁to insufflate, to inject 注入heating 加热preheating 预热tempering 回火temper 回火hardening 淬水annealing 退火reduction 还原cooling 冷却decarbonization, decarburization 脱碳coking 炼焦slagging, scorification 造渣carburization 渗碳case hardening 表面硬化cementation 渗碳fritting, sintering 烧结puddling 搅炼pulverization 粉化,雾化nitriding 渗氮alloy 合金floatation, flotation 浮选patternmaking 制模moulding 成型 (美作:molding)calcination 煅烧amalgamation 汞齐化rolling 轧制drawing 拉拔extrusion 挤压wiredrawing 拉丝stamping, pressing 冲压die casting 拉模铸造forging 锻造turning 车削milling 铣削machining, tooling 加工autogenous welding, fusion welding 氧炔焊arc welding 电弧焊electrolysis 电解trimming 清理焊缝blowhole 气孔
