查看: 633|回复: 1
[文章] sinter plant
发表于 2009-6-23 11:42:38 |Error| 显示全部楼层 |阅读模式
Process description
By sintering, the pelletisation of fine-grained, smeltable ores, iron ore in particular, to
compact lumps by heating nearly to the melting or softening point is understood. Melting
tendencies at the grain boundaries lead to a caking of the material.
sinter_plants.pdf
23.97 KB, 阅读权限: 30, 下载次数: 1
 楼主| 发表于 2009-6-23 11:44:26 |Error| 显示全部楼层
sintering of ultra high molecular weight polyethylene
Abstract. Ultra high molecular weight polyethylene (UHMWPE) is a high performance polymer having low
coefficient of friction, good abrasion resistance, good chemical resistance etc. It is used in shipbuilding, textile
industries and also in biomedical applications. UHMWPE is processed by powder processing technique because
of its high melt viscosity at the processing temperature. Powder processing technique involves compaction of
polymeric powder under pressure and sintering of the preforms at temperature above its melting point. In this
study, we report our results on compaction and sintering behaviour of two grades of UHMWPE with reference
to the powder morphology, sintering temperatures and strength development.
221.pdf
189.43 KB, 阅读权限: 30, 下载次数: 0
GMT+8, 2026-11-1 08:11 , Processed in 0.293133 second(s), 30 queries .
