- 0
- 10
- 2006-10-7
发表于 2009-6-17 14:36:39
|Error|
显示全部楼层
First step:
a. Clamp the steel cord of return belt, as much as close to the pulley which to be replaced.
Note: for cline or descending belt, several belt clamps may be used, clamp the belt to avoid belt sliding.
Fix and anchor the belt clam, or directly fix it to the rigid parts of conveyor frame, or fix it to anchoring chains. For detail, please refer to drawings.
最后,确保皮带松弛地环绕在滚筒表面,这时就可以拆卸掉滚筒了。
Finally, ensure the belt surround the surface of pulley in loosen condition, then the pulley can be disassembled. |
