查看: 3088|回复: 12
[样本] ALSTOM活塞脉冲阀OPTIPOW
发表于 2009-6-11 14:51:46 |Error| 显示全部楼层 |阅读模式
OPTIPOW的外型要比膜片式的脉冲阀小得多。两个OPTIPOW脉冲阀的最短距离可以到160mm。
Pulse Jet Fabric FiltersThe Optipulse® LKP Fabric Filter is suited for most applications requiring a large filtering capacity, such a coal-fired boilers for power plants and waste-to-energy plants.
Key benefits
  • Compact and flexible design and the use of longer bags makes Optipulse® LKP ideal of ESP retrofits
  • Optipulse® LKP is specifically designed for on-line cleaning using "Modulated Pulse Cleaning"
  • Unaffected by dust variations
  • Enhanced gas absorption capacity with fine particle separation
  • Low operating costs due to energy efficient pulse filter cleaning process, with low filter pressure drop and resulting in lower fan energy consumption
  • Easy, low-cost maintenance due to plugging of defective bags and easily accessible service area from above, requiring minimum shut down and service
Features
> Gas cleaning method
Raw gas enters the filter compartments via inlet ducts equipped with guide vanes that distribute the gas uniformly across the filter bags. This arrangement creates a downward gravimetric gas flow along the filter bags, precipitating the dust into the hopper below.
> Pulse Jet filter cleaning
The filter bags are cleaned by means of compressed air pulses. The pulse of compressed air expands the bag, at high speed, so that dust collected on the outside of the bag is dislodged when the bag stops at its outer position. The compressed air is directed down into the bags by a tube equipped with nozzles which reduce pressure losses to a minimum and distribute the pulse pressure evenly along the row of filter bags.
> Enhanced gas absorption capacity and fine particle separation
The Optipulse® LKP filter has the major advantage that further absorption of gaseous components, such as acid pollutants, take place in the dust layer formed on the bags. This layer contains reactive absorbent, resulting in enhanced absorption of acid pollutants, as well as better utilisation of sorbent material.
[ 本帖最后由 ALPS 于 2009-6-11 17:04 编辑 ]
optipow spare parts drawings and code.pdf
120.54 KB, 下载次数: 59
OPTIPOW 活塞式脉冲阀
发表于 2009-6-12 16:07:03 |Error| 显示全部楼层
学习!比较!谢谢!!!!
 楼主| 发表于 2009-6-12 17:24:04 |Error| 显示全部楼层
回复 2楼 lzwlmkb 的帖子
大家也上传些其他的资料共同学习,比如ASCO,GOYU
 楼主| 发表于 2009-7-3 14:38:52 |Error| 显示全部楼层
人气很少阿
发表于 2009-7-7 22:10:37 |Error| 显示全部楼层
我要采购ALSTOM的除尘阀
我要采购ALSTOM的除尘阀,到哪里去买呀,能告诉我一下吗,谢谢,我的邮箱hongfeng12@126.com
发表于 2009-7-8 21:57:31 |Error| 显示全部楼层
什么东东哦,的翻译的吗
发表于 2009-7-10 08:23:06 |Error| 显示全部楼层
采购ALSTOM的脉冲阀
我要采购ALSTO脉冲阀,有价格优势的请和我联系,请将联系信息发到hongfeng12@126.com,我会及时的和您联系的,谢谢!
 楼主| 发表于 2009-8-19 17:06:12 |Error| 显示全部楼层
回复 7楼 hongfeng12 的帖子
010-8460 9264
 楼主| 发表于 2009-9-1 15:47:41 |Error| 显示全部楼层
发表于 2009-9-3 17:54:26 |Error| 显示全部楼层
这怎么看得懂呀?
 楼主| 发表于 2010-2-4 00:22:30 |Error| 显示全部楼层
没人气啊 没人气
发表于 2010-2-4 09:57:56 |Error| 显示全部楼层
价格有没有优势呀
 楼主| 发表于 2010-2-8 23:16:33 |Error| 显示全部楼层
回复 13# jlhzsm
  活塞式阀门使用寿命更长,更节省空间,减低钢耗。
价格与其他进口阀门相当
GMT+8, 2026-11-4 03:44 , Processed in 0.281916 second(s), 31 queries .
