查看: 738|回复: 0
[教程] CDRS的安装
发表于 2009-5-18 12:04:14 |Error| 显示全部楼层 |阅读模式
[讨论]cdrs2001datecode 2002450的安装方法!
How to Make a license:
1) Open ptc.dat in txt editor and where it say: HOSTID=PTC_HOSTID=00-00-00-00-00-00
   Replace 0's with your own mac address.
2) Save the changes and run keygen.bat to generate a license
CDRS 2001 Build 450:
1) Run setup and deselect license management and then select help
   and animator.
2) Select all options to install.
3) Hit the add button for "Specify license Server" and select node lock options.
   Point the browser to the license file you created.
4) Configure the cdrs2001 by selecting the start command line and then hit edit. Define the
   paths and the start commands for the other ptc products if applicable.
5) For the rest of the installation use the defaults unless you know what your doing.
注:显卡要支持3D硬件加速,支持openGL,direct3d加速,agp等!更新你的驱动程式,
下载新的directX请到microsoft.com下载!!!最新的为directX9.0
相关帖子
GMT+8, 2026-11-4 03:45 , Processed in 0.220193 second(s), 23 queries .
