查看: 1783|回复: 10
100刮板机尾滑板
发表于 2009-5-9 12:32:56 |Error| 显示全部楼层 |阅读模式
图纸
图纸名称:
图号:
文件格式: DWG (AUTO CAD)
附件贴图: -
100刮板机尾滑板
TGSS100.1.2.rar
18.33 KB, 下载次数: 63
发表于 2009-5-14 15:11:20 |Error| 显示全部楼层
谢谢楼主,楼主为什么不在一个贴中发呢?
发表于 2009-6-2 13:27:36 |Error| 显示全部楼层
发表于 2009-6-6 09:42:48 |Error| 显示全部楼层
Drilling machines with multiple spindles (gang drilling) are used Jot high-production-rate operations. These machines are capable of drilling, in one cycle,as many as 50 holes of varying sizes, depths, and locations. They also are used for reaming and counterboring operations. However, with advances in machine took, gang-drilling machines now are being replaced with numerical-control turret drilling machines. Special drilling machines, such as those used to produce holes in continuous hinges (piano hinges), use twist drills 1 mm in diameter. These machines usually are horizontal and produce holes in up to 3-m long segments on one cycle.
 楼主| 发表于 2009-6-6 17:03:05 |Error| 显示全部楼层
回复 4楼 13834130418 的帖子
本人英语水平有限,看不懂呀
发表于 2009-6-27 17:44:33 |Error| 显示全部楼层
谢谢和前面的配合
发表于 2009-7-5 01:59:38 |Error| 显示全部楼层
下载了,顶一下,谢谢楼主
发表于 2009-12-21 12:31:44 |Error| 显示全部楼层
没有参考价值,必须配合装配图
发表于 2012-9-2 14:52:19 |Error| 显示全部楼层
没有参考价值,必须配合装配图
发表于 2012-9-3 08:47:09 |Error| 显示全部楼层
单一的只是一个部件只是适合某种型号没有很大用处希望楼主能配合装配图一起发出来!
发表于 2012-10-1 09:23:51 |Error| 显示全部楼层
只一个小部件  楼主有新型的东西不
GMT+8, 2026-11-1 09:25 , Processed in 0.346924 second(s), 33 queries .
