查看: 1029|回复: 0
[资料手册] The reasons effecting the capacity of Raymond mill are diversity
发表于 2009-5-5 09:58:43 |Error| 显示全部楼层 |阅读模式
    • The hardness of the materials.  The harder the materials are, the harder to grind. The damage of the machine is more serious. The capacity of Raymond mill become small because of the lower rotating.
    • The humidity of the materials.  When the humidity is large, the material is easy to adhere to the inside body of Raymond mill, and block in the process of feeding.
    • The fineness of product.  The higher quality demand lead to lower capacity.
    • The content of the materials.   The fine powder in the raw materials would effect the capacity of the Raymond mill. Because the fine powder would conglutinate so that affect the convey. It is better to make the materials with fine powder to the screen in first.
    • The stringy of the materials.  The stringy of the materials would effect the capacity of the Raymond mill. It is easy to adhere because of the high stringy.
    • The capacity of the quick-wear parts( hammer head, jaw plate) effect the capacity of Raymond mill.
website: http://www.mineral-grinder.com
grinder mill
grinder mill
GMT+8, 2026-10-30 12:10 , Processed in 0.315301 second(s), 32 queries .
