- 16
- 20
- 2009-4-25
楼主 |
发表于 2009-4-26 01:17:51
|Error|
显示全部楼层
续上
Vertical hydraulic broaching machine 立式油压拉床
Vises 虎钳
Vises,tool-maker 精密平口钳
Wheel dressers 砂轮修整器
Woven-Cutting machines 织麦激光切割机
Wrenches 扳手
铝轮冒口切断机 Overflow cutting machines for aluminium wheels
离心压力机 Presses,eccentric
六角立式铣床 Milling machines,turret vertical
六角车床 Lathes,turret
螺栓,螺帽及螺丝 Bolts,screws & nuts
螺纹磨床 Grinders,thread
冷却机 Coolers
冷锻 Forging,cold
冷锻冲压机 Presses,cold forging
立式双柱加工中心 Machining centers,vertical double-column type
立式铣床 Milling machines,vertical
立式油压拉床 Vertical hydraulic broaching machine
立式刨床 Planing machines vertical
立式车床 Lathes,vertical
立式带锯 Saws,vertical band
立式加工中心 Machining centers,vertical
立式及卧式铣床 Milling machines,vertical & horizontal
立式钻床 Drilling machines,vertical
联轴器 Coupling
连续溶解保温炉 Aluminum continuous melting & holding furnaces
连续冲模 Dies-progressive
链传动 Chain drive
切断机 Cutting-off machines
CNC刀杆 CNC toolings
曲柄压力机 presses,crank
修整机 Finishing machines
舍弃式刀头 Disposable toolholder bits
润滑系统 Lubrication Systems
润滑液 Lubricants
熔热处理炉 Heating treatment funaces
三爪、分割工具头 3-Jaws indexing spacers
伺服冲床 Presses,servo
输送链 Conveying chains
手工具 Hand tools
砂轮修整器 Wheel dressers
蚀刻机 Etching machines
外圆磨床 Grinding machines,cylindrical
搪磨机 Honing machines
搪孔头 Boring heads
卧式铣床 Milling machines,horizontal
卧式带锯 Saws,horizontal band
卧式加工中心 Machining centers,horizontal
卧式及立式加工中心 Machining centers,horizontal & vertical
万能铣床 Milling machines,universal
万能磨床 Grinding machines,universal
镗床 Boring machines
弯曲机 Bending machines
弯管机 Tube bending machines
通用加工中心 Machining centers,general
铜锻 Forging,copper
铣头 Milling heads
铣床 Milling machines
无心磨床 Grinding machines,centerless
无心精研机 Lapping machines,centerless
压模 Pressing dies
压铸冲模 Die casting dies
压铸机 Die casting machines
油冷却器 Oil coolers
造链机 Chain making tools
造线机 Cable making tools
造钉机 Nail making machines
印刷电器板油压冲孔脱料系统 PCB fine piecing systems
摇臂钻床 Drilling machines,radial
硬(软)板(片)材及自由发泡板机组 Hard/soft and free expansion sheet making plant
辗压机 Rolling machines
液压元件 Hydraulic components
液压冲床 Presses,hydraulic
液压动力元件 Hydraulic power units
液压工具 Hydraulic power tools
液压回转缸 Hydraulic rotary cylinders
P型PVC高分子防水 P type PVC waterproof rolled sheet making plant
刨床 Planing machines
牛头刨床 Shapers
其他铸造 Casting,other
其他锻造 Forging,other
模芯 Mold core
模具 Molds
模具维修 Mold repair
模具打磨/磨纹 Mold polishing/texturing
模具单元 Mold & die components
模具加热器/冷却器 Mold heaters/chillers
磨轮 Grinding wheels
磨削工具 Grinding tools
磨床工作台 Grinder bench
平衡设备 Balancing equipment
气油压虎钳 Pneumatic hydraulic clamps
气动冲床 Presses,pneumatic
气动工具 Pneumatic power tools
轴 shafts
轴承 Bearings
轴承配件 Bearing fittings
轴承加工机 Bearing processing equipment
肘杆式压力机 Presses,knuckle joint
铸铝 Casting,aluminium
铸铜 Casting,copper
铸造设备 Foundry equipment
铸钢 Casting,steel
铸灰口铁 Casting,gray iron
织麦激光切割机 Woven-Cutting machines
重力铸造机 Gravity casting machines
重型车床 Lathes,heavy-duty
主轴 spindles
扳手 Wrenches
拔丝机 Drawing machines
保温炉 Heat preserving furnaces
插床 Slotting machines
齿轮 Gears
齿轮切削机 Gear cutting machines
冲压机 Stamping parts
冲子研磨器 Punch formers
超声波打磨机 Grinders,ultrasonic
车床工作台 Lathe bench
磁性工具 Magnetic tools
传动链 Transmitted chains
床身式铣床 Milling machines,bed type
带传动 Belt drive
带锯 Saws,band
带锯床 Sawing machines,band
电脑数控镗床 CNC boring machines
电脑数控弯折机 CNC bending presses
电脑数控铣床 CNC milling machines
电脑数控线切削机 CNC wire-cutting machines
电脑数控磨床 CNC grinding machines
电脑数控车床 CNC lathes
电脑数控电火花线切削机 CNC EDM wire-cutting machines
电脑数控电火花机 CNC electric discharge machines
电脑数控雕刻机 CNC engraving machines
电脑数控机床配件 CNC machine tool fittings
电脑数控剪切机 CNC shearing machines
电脑数控钻床 CNC drilling machines
电动刀具 Electric power tools
电火花机 Electric discharge machines(EDM)
雕刻机 Engraving machines
刀片 Blades
刀具 Cutters
倒角机 Chamfer machines
多轴钻床 Drilling machines,multi-spindle
锻铝 Forging,aluminium
锻压机 Presses,forging
锻模 Forging dies
仿形铣床 Milling machines,duplicating
粉末冶金成型机 Powder metallurgic forming machines
反射炉 Reverberatory furnaces
钢锻 Forging,steel
高速车床 Lathes,high-speed
高速钻床 Drilling machines,high-speed
管筒制造机 Pipe & tube making machines
滚筒 Rollers
工具磨床 Grinders,tools & cutters
攻螺丝机 Tapping machines
弓锯 Saws,hack
虎钳 Vises
换模系统 Mold changing systems
夹盘 Chucks
夹具 Fixture
夹具/支持系统 Clamping/holding systems
剪切机 Shearing machines
加工中心机刀库 A.T.C.system
激光切割 Laser cutting
激光雕刻机 Engraving machines,laser
激光钢板切割机 Laser cutting for SMT stensil
集合管 Manifolds
矫直机 Straightening machines
金属板成型机 Sheet metal forming machines
金属板加工机 Sheet metal working machines
锯片 Blades,saw
锯床 Sawing machines
卷边工具 Crimping tools
晶圆切割机 Dicing saws
精密平口钳 Vises,tool-maker
可锻铸铁 Casting,malleable iron
快速换模系统 Quick mold change systems
卡口 Bayonet
开关及按钮 Switches & buttons
钻石刀具 Diamond cutters
钻头 drills
钻模 Jigs
钻床工作台 Drilling machines bench
自动压力机 Presses,transfer
自动车床 Lathes,automatic
注油机 Lubricators
转台 Rotary tables |
