查看: 924|回复: 0
hk01温度测量元件安装图册 ( HK01 )
发表于 2009-3-22 23:28:55 |Error| 显示全部楼层 |阅读模式
图纸
图纸名称:
图号:
文件格式: DWG (AUTO CAD)
附件贴图: -
目      次
CONTENTS
1
温包在钢管道上安装图.............................................................................HK01-1
INSTL . DWG. OF FILLED THERM. BULB ON STEEL PIPE
2
温包在耐酸钢管道上安装.........................................................................HK01-2
INSTL. DWG. OF FILLED THERM. BULB ON ACID-RES. STEEL PIPE
3
温包在钢设备上安装图.............................................................................HK01-3
INSTL. DWG. OF FILLED THERM. BULB ON STEEL EQUIP.
4
温包在耐酸钢设备上安装.........................................................................HK01-4
INSTL. DWG. OF FILLED THERM. BULB ON ACID-RES. STEEL EQUIP.
5
温包在钢肘管上安装图.............................................................................HK01-5
INSTL. DWG. OF FILLED THERM. BULB ON STEEL ELBOW
6
双金属温度计在钢管道、设备上安装图(外螺纹接头)........................HK01-6
INSTL. DWG. OF BIMETAL THERM. ON STEEL PIPE OR EQUIP.(MALE THRD. CONN.)
7
双金属温度计在耐酸钢管道、设备上安装图(外螺纹接头)...................HK01-7
INSTL. DWG. OF BIMETAL THERM. ON ACID-RES. STEEL PIPE OR EQUIP.
(MALE THRD. CONN.)
8
用突面法兰带接头固定的双金属温度计安装图(外螺纹接头)..............HK01-8
INSTL. DWG. OF BIMETAL THERM. FIXED BY RF FLANGE WITH BOSS
(MALE THRD. CONN.)
9
用突面法兰带接头固定的双金属温度计在耐酸钢设备上安装图(外螺纹接头).....HK01-9
INSTL. DWG. OF BIMETAL THERM. ON ACID-RES. STEEL EQUIP.
FIXED BY RF
FLANGE WITH BOSS (MALE THRD. CONN.)
10
双金属温度计在钢管道上斜45°安装图(外螺纹接头).............................HK01-10
hk01温度测量元件安装图册 ( HK01 ).rar
1.45 MB, 下载次数: 21
GMT+8, 2026-11-4 08:07 , Processed in 0.287700 second(s), 33 queries .
