查看: 5153|回复: 7
[资料手册] AMESim与Matlab/Simulink联合仿真?
发表于 2009-1-10 10:42:11 |Error| 显示全部楼层 |阅读模式
发表于 2011-2-25 11:07:07 |Error| 显示全部楼层
我用amesim与matlab做联合仿真的时候运行amesim中的例子,到编译的时候提示出现错误,我在仿真之前设置了:1amesim的环境变量,2matlab的环境变量,3两个软件的编译器用的是vc++,4工作目录也设置了,请问那位高手知道怎么回事,错误提示如下:Setting environment for using Microsoft Visual C++ tools.
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
cl.exe -c -DWIN32 -DAMESIMULINK -IC:\Program Files\MATLAB/extern/include -IC:\Program Files\MATLAB/simulink/include -IC:\AMESim\v800/interfaces/simulink -nologo -DWIN32 -MT -W3 -Od -D "_MBCS" -GX -Zm1500 -o AMESimulinkStandardInterface_.obj AMESimulinkStandardInterface_.c
Command line warning D4024 : unrecognized source file type 'Files\MATLAB/extern/include', object file assumed
Command line warning D4027 : source file 'Files\MATLAB/extern/include' ignored
Command line warning D4024 : unrecognized source file type 'Files\MATLAB/simulink/include', object file assumed
Command line warning D4027 : source file 'Files\MATLAB/simulink/include' ignored
NMAKE : fatal error U1077: 'cl.exe' : return code '0x2'
Stop.
AMESimulinkStandardInterface_.c(868) : warning C4101: 'rdummy' : unreferenced local variable
AMESimulinkStandardInterface_.c(1026) : warning C4101: 'n' : unreferenced local variable
AMESimulinkStandardInterface_.c(1102) : warning C4101: 'i' : unreferenced local variable
AMESimulinkStandardInterface_.c(1433) : fatal error C1083: Cannot open include file: 'simstruc.h': No such file or directory
- For free edition of Microsoft Developer Studio, you may need to set the MSSDK environment variable to the installation directory of your MS Windows SDK
System build error!
回复 顶 1 踩 0
发表于 2009-7-5 20:26:39 |Error| 显示全部楼层
联合仿真是可以的 但是好像需要一个补丁什么的 我现在也需要这个 哪位大侠帮忙谢谢了
发表于 2009-7-8 18:05:37 |Error| 显示全部楼层
谢谢楼主,下来学习!
发表于 2009-7-24 14:25:30 |Error| 显示全部楼层
我也很想学习
希望大家多多讨论学习
发表于 2010-5-30 08:37:40 |Error| 显示全部楼层
老搞不定,郁闷是
发表于 2010-7-8 15:42:47 |Error| 显示全部楼层
我正烦这个 郁闷
发表于 2010-11-10 15:04:25 |Error| 显示全部楼层
我也是很需要
GMT+8, 2026-11-1 20:52 , Processed in 0.222876 second(s), 24 queries .
