- 153
- 30
- 2008-9-22
A 514-00. High-Yield-Strength, Quenched and Tempered St, A 516-01. Pressure Vessel Plates, Carbon Steel, for Mod, A 529-01. High Strength Carbon Manganese Steel of Struc, A 572-01. High-Strength Low Alloy Columbium Vanadium St, A 578-96(01). Straight Beam UT of Plain and Clad Steel, A 586-98. Zinc-Coated Parallel & Helical Steel Wire Str, A 603-98(03). Zinc-Coated Steel Structure Wire Ropes |
ASTM A 514-00. High-Yield-Strength, Quenched and Tempered St.pdf
28.34 KB, 下载次数: 13
ASTM A 516-01. Pressure Vessel Plates, Carbon Steel, for Mod.pdf
16.13 KB, 下载次数: 8
ASTM A 529-01. High Strength Carbon Manganese Steel of Struc.pdf
12.74 KB, 下载次数: 4
ASTM A 572-01. High-Strength Low Alloy Columbium Vanadium St.pdf
39.05 KB, 下载次数: 10
ASTM A 578-96(01). Straight Beam UT of Plain and Clad Steel .pdf
40.14 KB, 下载次数: 6
ASTM A 586-98. Zinc-Coated Parallel & Helical Steel Wire Str.pdf
39.6 KB, 下载次数: 8
ASTM A 603-98(03). Zinc-Coated Steel Structure Wire Ropes..pdf
45.21 KB, 下载次数: 9
